Captain_Glen Posted January 19, 2018 Posted January 19, 2018 Hi I have no /dev/dvb on my UDOO Quad. I'm trying to get MythTV or tvheadend working on my UDOO Quad with Armbian Jessie with kernal 4.4.102 glen@udoo:~$ uname -a Linux udoo 4.4.102-udoo #2 SMP Fri Nov 24 18:49:01 CET 2017 armv7l GNU/Linux I thought that dvb drivers were included in version 3.19 of the kernel and up? Anyway I copied dvb-usb-af9015.fw to /lib/firmware and rebooted. But nothing shows up under /dev/dvb/ I would expect there to be adapter0 and adapter1 Here is my lsusb: glen@udoo:~$ lsusb Bus 001 Device 004: ID 13d3:3226 IMC Networks DigitalNow TinyTwin DVB-T Receiver Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub and my dmesg: [ 8904.731820] usb 1-1.2: USB disconnect, device number 3 [ 9150.501583] usb 1-1.1: new high-speed USB device number 4 using ci_hdrc [ 9150.616876] usb 1-1.1: New USB device found, idVendor=13d3, idProduct=3226 [ 9150.616899] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 9150.616915] usb 1-1.1: Product: DVB-T 2 [ 9150.616928] usb 1-1.1: Manufacturer: Afatech [ 9150.616940] usb 1-1.1: SerialNumber: 010101010600001 [ 9150.630673] input: Afatech DVB-T 2 as /devices/soc0/soc/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb1/1-1/1-1.1/1-1.1:1.1/0003:13D3:3226.0002/input/input1 [ 9150.682765] hid-generic 0003:13D3:3226.0002: input: USB HID v1.01 Keyboard [Afatech DVB-T 2] on usb-ci_hdrc.1-1.1/input1
Igor Posted January 19, 2018 Posted January 19, 2018 2 hours ago, Captain_Glen said: I thought that dvb drivers were included in version 3.19 of the kernel and up? They are but not enabled. https://github.com/armbian/build/commit/866bb6e10ee141c1ed9245393cf2d957630510b5 Build on your own or wait a day and switch to the beta repository.
Captain_Glen Posted January 22, 2018 Author Posted January 22, 2018 On 1/19/2018 at 4:41 PM, Igor said: They are but not enabled. https://github.com/armbian/build/commit/866bb6e10ee141c1ed9245393cf2d957630510b5 Build on your own or wait a day and switch to the beta repository. Thanks Igor! I've been a bit spoiled with Ubuntu, so I haven't compiled anything for a few years (10+)... Are these the steps I should follow: git clone --depth=1 git://linuxtv.org/media_build.git cd media_build ./build make sudo make install Or is this the wrong git hub for armbian?
JMCC Posted January 22, 2018 Posted January 22, 2018 (edited) Hello. I also needed dvb drivers fo the Thinker Board, and compiled them a few days ago. Only that the latest GIT failed to compile with kernel 4.4, so I had to switch to an older commit, more specifically 2017-08-20. So I would try with your suggestion (just remove the "make" after "./build", it is not necessary). In case it fails, try this: git clone git://linuxtv.org/media_build.git cd media_build git checkout b1a305fb27ad5df895356baeff575a1ecb14ebf1 Notice that the build script will try to auto-update the build environment, and also download the latest drivers which won't work. So you need to do some manual edits: "build": Find and remove this part: print "****************************\n"; print "Updating the building system\n"; print "****************************\n"; run("git pull git://linuxtv.org/media_build.git master", "Can't clone tree from linuxtv.org"); "linux/Makefile": Find these lines: LATEST_TAR := http://linuxtv.org/downloads/drivers/linux-media-LATEST.tar.bz2 LATEST_TAR_MD5 := http://linuxtv.org/downloads/drivers/linux-media-LATEST.tar.bz2.md5 and replace with: LATEST_TAR := http://linuxtv.org/downloads/drivers/linux-media-2017-08-08-079c6eaf80d9.tar.bz2 LATEST_TAR_MD5 := http://linuxtv.org/downloads/drivers/linux-media-2017-08-08-079c6eaf80d9.tar.bz2.md5 Then, you are good to go: ./build sudo make install That worked for me. Edited January 22, 2018 by JMCC Mistake
Captain_Glen Posted January 23, 2018 Author Posted January 23, 2018 Thanks for your suggestion. I get: tar: Child returned status 2 tar: Error is not recoverable: exiting now Can't extract dvb-firmwares.tar.bz2 at ./build line 511 When I run ./build See full cmd below: glen@udoo:~/media_build$ ./build Checking if the needed tools for Debian GNU/Linux 8.10 (jessie) are available Needed package dependencies are met. ************************************************************ * This script will download the latest tarball and build it* * Assuming that your kernel is compatible with the latest * * drivers. If not, you'll need to add some extra backports,* * ./backports/<kernel> directory. * * It will also update this tree to be sure that all compat * * bits are there, to avoid compilation failures * ************************************************************ ************************************************************ * All drivers and build system are under GPLv2 License * * Firmware files are under the license terms found at: * * http://www.linuxtv.org/downloads/firmware/ * * Please abort in the next 5 secs if you don't agree with * * the license * ************************************************************ Not aborted. It means that the licence was agreed. Proceeding... make: Entering directory '/home/glen/media_build/linux' wget http://linuxtv.org/downloads/drivers/linux-media-2017-08-08-079c6eaf80d9.tar.bz2.md5 -O linux-media.tar.bz2.md5.tmp --2018-01-23 05:23:54-- http://linuxtv.org/downloads/drivers/linux-media-2017-08-08-079c6eaf80d9.tar.bz2.md5 Resolving linuxtv.org (linuxtv.org)... 130.149.80.248 Connecting to linuxtv.org (linuxtv.org)|130.149.80.248|:80... connected. HTTP request sent, awaiting response... 301 Moved Permanently Location: https://linuxtv.org/downloads/drivers/linux-media-2017-08-08-079c6eaf80d9.tar.bz2.md5 [following] --2018-01-23 05:23:55-- https://linuxtv.org/downloads/drivers/linux-media-2017-08-08-079c6eaf80d9.tar.bz2.md5 Connecting to linuxtv.org (linuxtv.org)|130.149.80.248|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 105 [application/x-bzip2] Saving to: ‘linux-media.tar.bz2.md5.tmp’ linux-media.tar.bz2.md5.tmp 100%[====================================================================>] 105 --.-KB/s in 0s 2018-01-23 05:23:57 (899 KB/s) - ‘linux-media.tar.bz2.md5.tmp’ saved [105/105] make: Leaving directory '/home/glen/media_build/linux' make: Entering directory '/home/glen/media_build/linux' tar xfj linux-media.tar.bz2 rm -f .patches_applied .linked_dir .git_log.md5 make: Leaving directory '/home/glen/media_build/linux' ********************************************************** * Downloading firmwares from linuxtv.org. * ********************************************************** bzip2: Compressed file ends unexpectedly; perhaps it is corrupted? *Possible* reason follows. bzip2: Inappropriate ioctl for device Input file = (stdin), output file = (stdout) It is possible that the compressed file(s) have become corrupted. You can use the -tvv option to test integrity of such files. You can use the `bzip2recover' program to attempt to recover data from undamaged sections of corrupted files. tar: Child returned status 2 tar: Error is not recoverable: exiting now Can't extract dvb-firmwares.tar.bz2 at ./build line 511 glen@udoo:~/media_build$
JMCC Posted January 23, 2018 Posted January 23, 2018 Looks weird. We haven't touched the firmware tarball part. Maybe they were updating the repo, and had some corrupted file in the meantime. I just downloaded it, and seems to be fine. Can you delete the media_build folder and start over again?
Captain_Glen Posted January 24, 2018 Author Posted January 24, 2018 So I had another go. I think my above error, was because I tried ./build multiple times, and it couldn't extract over the top of the files that were already there. Anyway I deleted media_build with rm -rf and re cloned it from git. line 519 of build is make allyesconfig. This is failing for me. I can comment it out and run sudo make install. But I suspect I need to run allyesconfig first? I think my problem is that I am using kernel 4.4.102. You mentioned that you are using a version of Armbian that is older from 2017-08-20. Is this still Debian Jessie? I want to stick with Debian Jessie, as I've managed to get Home-Assistant, mosquitto, NextCloud, OpenMediaVault and Zoneminder all running on this so far. The last piece of the the puzzle is MythtTV or TVheadend. glen@udoo:~$ uname -a Linux udoo 4.4.102-udoo #2 SMP Fri Nov 24 18:49:01 CET 2017 armv7l GNU/Linux glen@udoo:~/media_build$ make allyesconfig make -C /home/glen/media_build/v4l allyesconfig make[1]: Entering directory '/home/glen/media_build/v4l' make[2]: Entering directory '/home/glen/media_build/linux' make[3]: Entering directory '/home/glen/media_build/linux' Unapplying patches patch -s -f -R -p1 -i ../backports/api_version.patch make[3]: Leaving directory '/home/glen/media_build/linux' Applying patches for kernel 4.4.102-udoo patch -s -f -N -p1 -i ../backports/api_version.patch patch -s -f -N -p1 -i ../backports/pr_fmt.patch 1 out of 1 hunk FAILED The text leading up to this was: -------------------------- |diff --git a/drivers/media/pci/ddbridge/ddbridge-main.c b/drivers/media/pci/ddbridge/ddbridge-main.c |index ccac7fe31336..bd85e92ad349 100644 |--- a/drivers/media/pci/ddbridge/ddbridge-main.c |+++ b/drivers/media/pci/ddbridge/ddbridge-main.c -------------------------- No file to patch. Skipping patch. 1 out of 1 hunk ignored Makefile:130: recipe for target 'apply_patches' failed make[2]: *** [apply_patches] Error 1 make[2]: Leaving directory '/home/glen/media_build/linux' Makefile:374: recipe for target 'allyesconfig' failed make[1]: *** [allyesconfig] Error 2 make[1]: Leaving directory '/home/glen/media_build/v4l' Makefile:26: recipe for target 'allyesconfig' failed make: *** [allyesconfig] Error 2 glen@udoo:~/media_build$
JMCC Posted January 25, 2018 Posted January 25, 2018 I'm using Debian Stretch, but that should not be relevant for that error. Maybe the kernel version is (your kernel is not identical to mine) Though, your error is the same I got before making the changes I mention above. So please make sure you are doing exactly this: rm -rf media_build git clone git://linuxtv.org/media_build.git cd media_build git checkout b1a305fb27ad5df895356baeff575a1ecb14ebf1 nano build (edit as described above) nano linux/Makefile (edit as described above) ./build sudo make install
Captain_Glen Posted January 31, 2018 Author Posted January 31, 2018 glen@udoo:~$ rm -rf media_build glen@udoo:~$ git clone git://linuxtv.org/media_build.git Cloning into 'media_build'... remote: Counting objects: 4142, done. remote: Compressing objects: 100% (1134/1134), done. remote: Total 4142 (delta 2982), reused 4112 (delta 2965) Receiving objects: 100% (4142/4142), 720.48 KiB | 252.00 KiB/s, done. Resolving deltas: 100% (2982/2982), done. Checking connectivity... done. glen@udoo:~$ cd media_build glen@udoo:~/media_build$ git checkout b1a305fb27ad5df895356baeff575a1ecb14ebf1 Note: checking out 'b1a305fb27ad5df895356baeff575a1ecb14ebf1'. You are in 'detached HEAD' state. You can look around, make experimental changes and commit them, and you can discard any commits you make in this state without impacting any branches by performing another checkout. If you want to create a new branch to retain commits you create, you may do so (now or later) by using -b with the checkout command again. Example: git checkout -b new_branch_name HEAD is now at b1a305f... build: Added missing "DESTDIR" glen@udoo:~/media_build$ nano b backports/ build glen@udoo:~/media_build$ nano build glen@udoo:~/media_build$ cd linux/ glen@udoo:~/media_build/linux$ nano Makefile glen@udoo:~/media_build/linux$ cd .. glen@udoo:~/media_build$ ./build Checking if the needed tools for Debian GNU/Linux 8.10 (jessie) are available Needed package dependencies are met. ************************************************************ * This script will download the latest tarball and build it* * Assuming that your kernel is compatible with the latest * * drivers. If not, you'll need to add some extra backports,* * ./backports/<kernel> directory. * * It will also update this tree to be sure that all compat * * bits are there, to avoid compilation failures * ************************************************************ ************************************************************ * All drivers and build system are under GPLv2 License * * Firmware files are under the license terms found at: * * http://www.linuxtv.org/downloads/firmware/ * * Please abort in the next 5 secs if you don't agree with * * the license * ************************************************************ Not aborted. It means that the licence was agreed. Proceeding... make: Entering directory '/home/glen/media_build/linux' wget http://linuxtv.org/downloads/drivers/linux-media-2017-08-08-079c6eaf80d9.tar.bz2.md5 -O linux-media.tar.bz2.md5.tmp --2018-01-31 07:41:10-- http://linuxtv.org/downloads/drivers/linux-media-2017-08-08-079c6eaf80d9.tar.bz2.md5 Resolving linuxtv.org (linuxtv.org)... 130.149.80.248 Connecting to linuxtv.org (linuxtv.org)|130.149.80.248|:80... connected. HTTP request sent, awaiting response... 301 Moved Permanently Location: https://linuxtv.org/downloads/drivers/linux-media-2017-08-08-079c6eaf80d9.tar.bz2.md5 [following] --2018-01-31 07:41:10-- https://linuxtv.org/downloads/drivers/linux-media-2017-08-08-079c6eaf80d9.tar.bz2.md5 Connecting to linuxtv.org (linuxtv.org)|130.149.80.248|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 105 [application/x-bzip2] Saving to: ‘linux-media.tar.bz2.md5.tmp’ linux-media.tar.bz2.md5.tmp 100%[====================================================================>] 105 --.-KB/s in 0s 2018-01-31 07:41:12 (1.01 MB/s) - ‘linux-media.tar.bz2.md5.tmp’ saved [105/105] cat: linux-media.tar.bz2.md5: No such file or directory --2018-01-31 07:41:12-- http://linuxtv.org/downloads/drivers/linux-media-2017-08-08-079c6eaf80d9.tar.bz2 Resolving linuxtv.org (linuxtv.org)... 130.149.80.248 Connecting to linuxtv.org (linuxtv.org)|130.149.80.248|:80... connected. HTTP request sent, awaiting response... 301 Moved Permanently Location: https://linuxtv.org/downloads/drivers/linux-media-2017-08-08-079c6eaf80d9.tar.bz2 [following] --2018-01-31 07:41:13-- https://linuxtv.org/downloads/drivers/linux-media-2017-08-08-079c6eaf80d9.tar.bz2 Connecting to linuxtv.org (linuxtv.org)|130.149.80.248|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 6639703 (6.3M) [application/x-bzip2] Saving to: ‘linux-media.tar.bz2’ linux-media.tar.bz2 100%[====================================================================>] 6.33M 422KB/s in 15s 2018-01-31 07:41:29 (441 KB/s) - ‘linux-media.tar.bz2’ saved [6639703/6639703] make: Leaving directory '/home/glen/media_build/linux' make: Entering directory '/home/glen/media_build/linux' tar xfj linux-media.tar.bz2 rm -f .patches_applied .linked_dir .git_log.md5 make: Leaving directory '/home/glen/media_build/linux' ********************************************************** * Downloading firmwares from linuxtv.org. * ********************************************************** --2018-01-31 07:41:38-- http://www.linuxtv.org/downloads/firmware//dvb-firmwares.tar.bz2 Resolving www.linuxtv.org (www.linuxtv.org)... 130.149.80.248 Connecting to www.linuxtv.org (www.linuxtv.org)|130.149.80.248|:80... connected. HTTP request sent, awaiting response... 301 Moved Permanently Location: https://www.linuxtv.org/downloads/firmware//dvb-firmwares.tar.bz2 [following] --2018-01-31 07:41:39-- https://www.linuxtv.org/downloads/firmware//dvb-firmwares.tar.bz2 Connecting to www.linuxtv.org (www.linuxtv.org)|130.149.80.248|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 1235003 (1.2M) [application/x-bzip2] Saving to: ‘dvb-firmwares.tar.bz2’ dvb-firmwares.tar.bz2 100%[====================================================================>] 1.18M 216KB/s in 5.6s 2018-01-31 07:41:46 (216 KB/s) - ‘dvb-firmwares.tar.bz2’ saved [1235003/1235003] as102_data1_st.hex as102_data2_st.hex cmmb_vega_12mhz.inp cmmb_venice_12mhz.inp dvb-fe-bcm3510-01.fw dvb-fe-drxj-mc-1.0.8.fw dvb-fe-drxj-mc-vsb-1.0.8.fw dvb-fe-drxj-mc-vsb-qam-1.0.8.fw dvb-fe-or51132-qam.fw dvb-fe-or51132-vsb.fw dvb-fe-or51211.fw dvb-fe-xc4000-1.4.1.fw dvb-fe-xc5000-1.6.114.fw dvb-fe-xc5000c-4.1.30.7.fw dvb-firmwares.tar.bz2 dvb-ttpci-01.fw-261a dvb-ttpci-01.fw-261b dvb-ttpci-01.fw-261c dvb-ttpci-01.fw-261d dvb-ttpci-01.fw-261f dvb-ttpci-01.fw-2622 dvb-usb-avertv-a800-02.fw dvb-usb-bluebird-01.fw dvb-usb-dib0700-1.20.fw dvb-usb-dibusb-5.0.0.11.fw dvb-usb-dibusb-6.0.0.8.fw dvb-usb-dtt200u-01.fw dvb-usb-it9135-01.fw dvb-usb-it9135-02.fw dvb-usb-terratec-h5-drxk.fw dvb-usb-terratec-h7-az6007.fw dvb-usb-terratec-h7-drxk.fw dvb-usb-umt-010-02.fw dvb-usb-vp702x-01.fw dvb-usb-vp7045-01.fw dvb-usb-wt220u-01.fw dvb-usb-wt220u-02.fw dvb_nova_12mhz.inp dvb_nova_12mhz_b0.inp isdbt_nova_12mhz.inp isdbt_nova_12mhz_b0.inp isdbt_rio.inp sms1xxx-hcw-55xxx-dvbt-02.fw sms1xxx-hcw-55xxx-isdbt-02.fw sms1xxx-nova-a-dvbt-01.fw sms1xxx-nova-b-dvbt-01.fw sms1xxx-stellar-dvbt-01.fw tdmb_nova_12mhz.inp v4l-cx231xx-avcore-01.fw v4l-cx23418-apu.fw v4l-cx23418-cpu.fw v4l-cx23418-dig.fw v4l-cx23885-avcore-01.fw v4l-cx23885-enc-broken.fw v4l-cx25840.fw ****************** * Start building * ****************** make -C /home/glen/media_build/v4l allyesconfig make[1]: Entering directory '/home/glen/media_build/v4l' No version yet, using 4.4.102-udoo make[2]: Entering directory '/home/glen/media_build/linux' Applying patches for kernel 4.4.102-udoo patch -s -f -N -p1 -i ../backports/api_version.patch patch -s -f -N -p1 -i ../backports/pr_fmt.patch patch -s -f -N -p1 -i ../backports/debug.patch patch -s -f -N -p1 -i ../backports/drx39xxj.patch patch -s -f -N -p1 -i ../backports/v4.12_revert_solo6x10_copykerneluser.patch patch -s -f -N -p1 -i ../backports/v4.10_sched_signal.patch patch -s -f -N -p1 -i ../backports/v4.10_fault_page.patch patch -s -f -N -p1 -i ../backports/v4.10_refcount.patch patch -s -f -N -p1 -i ../backports/v4.9_mm_address.patch patch -s -f -N -p1 -i ../backports/v4.9_dvb_net_max_mtu.patch patch -s -f -N -p1 -i ../backports/v4.9_ktime_cleanups.patch patch -s -f -N -p1 -i ../backports/v4.8_user_pages_flag.patch patch -s -f -N -p1 -i ../backports/v4.7_dma_attrs.patch patch -s -f -N -p1 -i ../backports/v4.7_pci_alloc_irq_vectors.patch patch -s -f -N -p1 -i ../backports/v4.6_i2c_mux.patch 1 out of 2 hunks FAILED Makefile:138: recipe for target 'apply_patches' failed make[2]: *** [apply_patches] Error 1 make[2]: Leaving directory '/home/glen/media_build/linux' Makefile:383: recipe for target 'allyesconfig' failed make[1]: *** [allyesconfig] Error 2 make[1]: Leaving directory '/home/glen/media_build/v4l' Makefile:26: recipe for target 'allyesconfig' failed make: *** [allyesconfig] Error 2 can't select all drivers at ./build line 519 glen@udoo:~/media_build$
JMCC Posted January 31, 2018 Posted January 31, 2018 So, as I imagined, it is a problem with your kernel's specific patches. So now, you've got to look among the Git commits, until you find one that might be causing the problem. You need to browse the log: https://git.linuxtv.org/media_build.git/log/ In a quick look, it looks like the patch that is failing is related v4.6_i2c_mux.patch, and there is a commit from 2017/08/14 patching that file. Try reverting to the previous commit, instead of the one I told you. If you click on the link of the prevoius commit, it will show you the id: "3a2afb881d1efadba33831f9c56321c4bcbe7178". So you would need to modify step 4, to look like: git checkout 3a2afb881d1efadba33831f9c56321c4bcbe7178 For step 6, you also need to find a file with a matching date in http://linuxtv.org/downloads/drivers/ But, since the commit is from the same date of the source tarball, it may work with the one you already have. If not, use the immediately previous one (that would be "linux-media-2017-07-29-ec0c3ec497ca.tar.bz2", and corresponding ".md5"). If it fails again, then you'll need to try with another commit, etc.
Captain_Glen Posted February 1, 2018 Author Posted February 1, 2018 Ok so I can't make that work either. I've now tried using Armbian Stretch, as that's what you are using? root@udoo:~# uname -a Linux udoo 4.4.112-udoo #7 SMP Thu Jan 25 08:39:07 CET 2018 armv7l GNU/Linux root@udoo:~# git clone git://linuxtv.org/media_build.git Cloning into 'media_build'... remote: Counting objects: 4142, done. remote: Compressing objects: 100% (1113/1113), done. remote: Total 4142 (delta 2986), reused 4142 (delta 2986) Receiving objects: 100% (4142/4142), 716.87 KiB | 221.00 KiB/s, done. Resolving deltas: 100% (2986/2986), done. root@udoo:~# cd media_build/ root@udoo:~/media_build# git checkout b1a305fb27ad5df895356baeff575a1ecb14ebf1 Checking out files: 100% (29/29), done. Note: checking out 'b1a305fb27ad5df895356baeff575a1ecb14ebf1'. You are in 'detached HEAD' state. You can look around, make experimental changes and commit them, and you can discard any commits you make in this state without impacting any branches by performing another checkout. If you want to create a new branch to retain commits you create, you may do so (now or later) by using -b with the checkout command again. Example: git checkout -b <new-branch-name> HEAD is now at b1a305f... build: Added missing "DESTDIR" root@udoo:~/media_build# nano build root@udoo:~/media_build# cd linux/ root@udoo:~/media_build/linux# nano Makefile root@udoo:~/media_build/linux# cd .. root@udoo:~/media_build# ./build Checking if the needed tools for Debian GNU/Linux 9.3 (stretch) are available ERROR: please install "lsdiff", otherwise, build won't work. You should run: sudo apt-get install patchutils Build can't procceed as 1 dependency is missing at ./build line 274. root@udoo:~/media_build# apt-get install patchutils Reading package lists... Done Building dependency tree Reading state information... Done The following NEW packages will be installed: patchutils 0 upgraded, 1 newly installed, 0 to remove and 3 not upgraded. Need to get 86.2 kB of archives. After this operation, 180 kB of additional disk space will be used. Get:1 http://cdn-fastly.deb.debian.org/debian stretch/main armhf patchutils armhf 0.3.4-2 [86.2 kB] Fetched 86.2 kB in 2s (31.0 kB/s) Selecting previously unselected package patchutils. (Reading database ... 31103 files and directories currently installed.) Preparing to unpack .../patchutils_0.3.4-2_armhf.deb ... Unpacking patchutils (0.3.4-2) ... Setting up patchutils (0.3.4-2) ... Processing triggers for man-db (2.7.6.1-2) ... root@udoo:~/media_build# ./build Checking if the needed tools for Debian GNU/Linux 9.3 (stretch) are available Needed package dependencies are met. ************************************************************ * This script will download the latest tarball and build it* * Assuming that your kernel is compatible with the latest * * drivers. If not, you'll need to add some extra backports,* * ./backports/<kernel> directory. * * It will also update this tree to be sure that all compat * * bits are there, to avoid compilation failures * ************************************************************ ************************************************************ * All drivers and build system are under GPLv2 License * * Firmware files are under the license terms found at: * * http://www.linuxtv.org/downloads/firmware/ * * Please abort in the next 5 secs if you don't agree with * * the license * ************************************************************ Not aborted. It means that the licence was agreed. Proceeding... make: Entering directory '/root/media_build/linux' wget http://linuxtv.org/downloads/drivers/linux-media-2017-08-08-079c6eaf80d9.tar.bz2.md5 -O linux-media.tar.bz2.md5.tmp --2018-02-01 11:42:55-- http://linuxtv.org/downloads/drivers/linux-media-2017-08-08-079c6eaf80d9.tar.bz2.md5 Resolving linuxtv.org (linuxtv.org)... 130.149.80.248 Connecting to linuxtv.org (linuxtv.org)|130.149.80.248|:80... connected. HTTP request sent, awaiting response... 301 Moved Permanently Location: https://linuxtv.org/downloads/drivers/linux-media-2017-08-08-079c6eaf80d9.tar.bz2.md5 [following] --2018-02-01 11:42:55-- https://linuxtv.org/downloads/drivers/linux-media-2017-08-08-079c6eaf80d9.tar.bz2.md5 Connecting to linuxtv.org (linuxtv.org)|130.149.80.248|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 105 [application/x-bzip2] Saving to: ‘linux-media.tar.bz2.md5.tmp’ linux-media.tar.bz2.md5.tmp 100%[==================================================================>] 105 --.-KB/s in 0s 2018-02-01 11:42:57 (581 KB/s) - ‘linux-media.tar.bz2.md5.tmp’ saved [105/105] cat: linux-media.tar.bz2.md5: No such file or directory --2018-02-01 11:42:57-- http://linuxtv.org/downloads/drivers/linux-media-2017-08-08-079c6eaf80d9.tar.bz2 Resolving linuxtv.org (linuxtv.org)... 130.149.80.248 Connecting to linuxtv.org (linuxtv.org)|130.149.80.248|:80... connected. HTTP request sent, awaiting response... 301 Moved Permanently Location: https://linuxtv.org/downloads/drivers/linux-media-2017-08-08-079c6eaf80d9.tar.bz2 [following] --2018-02-01 11:42:58-- https://linuxtv.org/downloads/drivers/linux-media-2017-08-08-079c6eaf80d9.tar.bz2 Connecting to linuxtv.org (linuxtv.org)|130.149.80.248|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 6639703 (6.3M) [application/x-bzip2] Saving to: ‘linux-media.tar.bz2’ linux-media.tar.bz2 100%[==================================================================>] 6.33M 1.36MB/s in 4.7s 2018-02-01 11:43:05 (1.36 MB/s) - ‘linux-media.tar.bz2’ saved [6639703/6639703] make: Leaving directory '/root/media_build/linux' make: Entering directory '/root/media_build/linux' tar xfj linux-media.tar.bz2 rm -f .patches_applied .linked_dir .git_log.md5 make: Leaving directory '/root/media_build/linux' ********************************************************** * Downloading firmwares from linuxtv.org. * ********************************************************** --2018-02-01 11:43:18-- http://www.linuxtv.org/downloads/firmware//dvb-firmwares.tar.bz2 Resolving www.linuxtv.org (www.linuxtv.org)... 130.149.80.248 Connecting to www.linuxtv.org (www.linuxtv.org)|130.149.80.248|:80... connected. HTTP request sent, awaiting response... 301 Moved Permanently Location: https://www.linuxtv.org/downloads/firmware//dvb-firmwares.tar.bz2 [following] --2018-02-01 11:43:19-- https://www.linuxtv.org/downloads/firmware//dvb-firmwares.tar.bz2 Connecting to www.linuxtv.org (www.linuxtv.org)|130.149.80.248|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 1235003 (1.2M) [application/x-bzip2] Saving to: ‘dvb-firmwares.tar.bz2’ dvb-firmwares.tar.bz2 100%[==================================================================>] 1.18M 457KB/s in 2.6s 2018-02-01 11:43:23 (457 KB/s) - ‘dvb-firmwares.tar.bz2’ saved [1235003/1235003] as102_data1_st.hex as102_data2_st.hex cmmb_vega_12mhz.inp cmmb_venice_12mhz.inp dvb-fe-bcm3510-01.fw dvb-fe-drxj-mc-1.0.8.fw dvb-fe-drxj-mc-vsb-1.0.8.fw dvb-fe-drxj-mc-vsb-qam-1.0.8.fw dvb-fe-or51132-qam.fw dvb-fe-or51132-vsb.fw dvb-fe-or51211.fw dvb-fe-xc4000-1.4.1.fw dvb-fe-xc5000-1.6.114.fw dvb-fe-xc5000c-4.1.30.7.fw dvb-firmwares.tar.bz2 dvb-ttpci-01.fw-261a dvb-ttpci-01.fw-261b dvb-ttpci-01.fw-261c dvb-ttpci-01.fw-261d dvb-ttpci-01.fw-261f dvb-ttpci-01.fw-2622 dvb-usb-avertv-a800-02.fw dvb-usb-bluebird-01.fw dvb-usb-dib0700-1.20.fw dvb-usb-dibusb-5.0.0.11.fw dvb-usb-dibusb-6.0.0.8.fw dvb-usb-dtt200u-01.fw dvb-usb-it9135-01.fw dvb-usb-it9135-02.fw dvb-usb-terratec-h5-drxk.fw dvb-usb-terratec-h7-az6007.fw dvb-usb-terratec-h7-drxk.fw dvb-usb-umt-010-02.fw dvb-usb-vp702x-01.fw dvb-usb-vp7045-01.fw dvb-usb-wt220u-01.fw dvb-usb-wt220u-02.fw dvb_nova_12mhz.inp dvb_nova_12mhz_b0.inp isdbt_nova_12mhz.inp isdbt_nova_12mhz_b0.inp isdbt_rio.inp sms1xxx-hcw-55xxx-dvbt-02.fw sms1xxx-hcw-55xxx-isdbt-02.fw sms1xxx-nova-a-dvbt-01.fw sms1xxx-nova-b-dvbt-01.fw sms1xxx-stellar-dvbt-01.fw tdmb_nova_12mhz.inp v4l-cx231xx-avcore-01.fw v4l-cx23418-apu.fw v4l-cx23418-cpu.fw v4l-cx23418-dig.fw v4l-cx23885-avcore-01.fw v4l-cx23885-enc-broken.fw v4l-cx25840.fw ****************** * Start building * ****************** make -C /root/media_build/v4l allyesconfig make[1]: Entering directory '/root/media_build/v4l' No version yet, using 4.4.112-udoo make[2]: Entering directory '/root/media_build/linux' Applying patches for kernel 4.4.112-udoo patch -s -f -N -p1 -i ../backports/api_version.patch patch -s -f -N -p1 -i ../backports/pr_fmt.patch patch -s -f -N -p1 -i ../backports/debug.patch patch -s -f -N -p1 -i ../backports/drx39xxj.patch patch -s -f -N -p1 -i ../backports/v4.12_revert_solo6x10_copykerneluser.patch patch -s -f -N -p1 -i ../backports/v4.10_sched_signal.patch patch -s -f -N -p1 -i ../backports/v4.10_fault_page.patch patch -s -f -N -p1 -i ../backports/v4.10_refcount.patch patch -s -f -N -p1 -i ../backports/v4.9_mm_address.patch patch -s -f -N -p1 -i ../backports/v4.9_dvb_net_max_mtu.patch patch -s -f -N -p1 -i ../backports/v4.9_ktime_cleanups.patch patch -s -f -N -p1 -i ../backports/v4.8_user_pages_flag.patch patch -s -f -N -p1 -i ../backports/v4.7_dma_attrs.patch patch -s -f -N -p1 -i ../backports/v4.7_pci_alloc_irq_vectors.patch patch -s -f -N -p1 -i ../backports/v4.6_i2c_mux.patch 1 out of 2 hunks FAILED Makefile:138: recipe for target 'apply_patches' failed make[2]: *** [apply_patches] Error 1 make[2]: Leaving directory '/root/media_build/linux' Makefile:383: recipe for target 'allyesconfig' failed make[1]: *** [allyesconfig] Error 2 make[1]: Leaving directory '/root/media_build/v4l' Makefile:26: recipe for target 'allyesconfig' failed make: *** [allyesconfig] Error 2 can't select all drivers at ./build line 519
Captain_Glen Posted February 1, 2018 Author Posted February 1, 2018 Thanks for your help so far. I've tried both suggested checkouts as well as the default checkout from git. I've tried these on both Armbian Stretch and Jessie. Neither combination work for me on a Udoo Quad. Perhaps it's not possible to compile on a Udoo Quad?
JMCC Posted February 2, 2018 Posted February 2, 2018 Well, it depends on the specific kernel patches. A solution could be to manually edit the patch that is causing trouble, but that's something that requires high programming skills. Or hit and miss with some other checkouts. Another suggestion would be to switch to another kernel, in case it is possible with your board (I'm not sure whether there are mainline and legacy stable versions for the UDOO Quad).
