Has anyone tried to install PiVPN or EasyRSA on a Rock64?  I tried this and had some issues where EasyRSA did not install.  No errors were shown on the install or captured in the install log.  Took me a while to figure out that EasyRSA was not installed.  It even created .opvn files for clients...
I finally figured out what happened.  Did some research and found a suggestion to manually install some packages BEFORE installing PiVPN.  That seems to work, so now I have a working VPN.
I just wanted to see if anyone else is having an issue.  I will also post on the PiVPN Github site to get their input.
Thanks!
Last time I was installing PiVPN it was installing fine ... Which build have you used? It doesn't seem that it's a board specifics problem.
Armbian_5.34.171121_Rock64_Ubuntu_xenial_default_4.4.77.img
May have been User (me) error...
Also the day before, PiVPN was having problems resolving.  Maybe something was hosed.  The reinstall worked, so I may just go with it and not waste any more time troubleshooting.
Thanks!
