Joe_PS Posted January 21, 2018 Posted January 21, 2018 Hi, Many thanks for your support. I installed successfully the OpenMediaVault (OMV) ISO Image on the new Orange Pi Zero Plus (OPI0+): OMV_3_0_91_Orangepizeroplus_4.13.13.img.xz. I mounted an external USB 2.0 HDD. via OMV The OPI0+ is directly connected thru LAN cable to the router (Fritz!Box 7490). Login via PuTTY ssh works also fine. Additionally, I installed miniDLNA and configured folder/file sharing and media streaming. The flac-files are provided quickly, including album cover pictures (jpg). Now, I kindly ask for your support to disable Wi-Fi (WLAN). I thought about blacklisting the module 'cfg80211', but it is already listed as 'Used by' together with the module 'rfkill'. Since I am a newbie regarding Armbian (Debian and Linux), I'd like to know, whether Wi-Fi is currently disabled (rfkill)? Thus, I don't need to do anything? Or is there another Wi-Fi (WLAN) module, which needs to be blacklisted? Many thanks in advance. Regards, Joe
zador.blood.stained Posted January 21, 2018 Posted January 21, 2018 11 minutes ago, Joe_PS said: Or is there another Wi-Fi (WLAN) module, which needs to be blacklisted? The easiest way would be blacklisting 8189fs. 1
Joe_PS Posted January 21, 2018 Author Posted January 21, 2018 1 hour ago, zador.blood.stained said: The easiest way would be blacklisting 8189fs. Done ... Should I crosscheck the 'health' of the OPI0+ - and if yes, how? (With regards to unwanted 'side effects' caused by blacklisting 8189fs) Or, is there no negative side-effect to be expected? Thanks, Joe
