1 hour ago1 hr There's no dedicated Armbian image for the BPI-M2 Berry, so many of us run the M2 Ultra (bananapim2ultra) image. It boots, but HDMI and the LEDs don't work properly, because it loads the M2 Ultra device tree.The Berry device tree is already included in the image. You just need to tell the bootloader to use it.Check that it's there:ls /boot/dtb/ | grep berry You should see sun8i-v40-bananapi-m2-berry.dtb.Apply the fix:cp /boot/armbianEnv.txt /boot/armbianEnv.txt.bak echo "fdtfile=sun8i-v40-bananapi-m2-berry.dtb" >> /boot/armbianEnv.txtrebootVerify:cat /proc/device-tree/model # Banana Pi M2 Berry ls /sys/class/leds/ # bananapi:green:user bananapi:red:pwrAfter this, HDMI works and both LEDs can be controlled, for example:echo mmc0 > /sys/class/leds/bananapi:green:user/triggerTested on: Armbian BPI-M2 BerryFill in the "Tested on" line with the output of:grep VERSION /etc/armbian-release uname -r
