Skip to content
View in the app
Armbian Community Forums
Helios64 - Kernel 7.3.6 - Lost CPUs... in flight
Featured Replies
My Helios64 is unstable with all kernels above 6.18.10, with or without the CPU DTB patch.
Today I tried Kernel 7.3.6 and I can provide data to debug.
Below you will see my "dmesg" command output.
I saw with the htop command that I lost 1 CPU frozen at 100%, then 2... 3... until a final freeze...
During the instability, a new SSH connection is impossible, but the active one continues to work until the final freeze...
The crash begins when I open my LUKS RAID and mount it.
If this data can help anybody to find the problem, that would be great.
DMESG OUT "with ondemand governor"
[   53.581496] EXT4-fs (dm-2): mounted filesystem 93e08007-ee19-4809-a4a3-0032ff9d1d00 r/w with ordered data mode. Quota mode: none.
[  169.581813] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
[  169.582384] rcu: 4-...0: (1 GPs behind) idle=2704/1/0x4000000000000000 softirq=6249/6250 fqs=2972
[  169.583175] rcu: (detected by 5, t=15003 jiffies, g=10493, q=1489 ncpus=6)
[  169.583789] Sending NMI from CPU 5 to CPUs 4:
[  179.585424] After 10 seconds, these CPUS still haven't responded to the NMI: 4
[  179.586056] rcu: rcu_preempt kthread timer wakeup didn't happen for 2500 jiffies! g10493 f0x0 RCU_GP_WAIT_FQS(5) ->state=I
[  179.587031] rcu: Possible timer handling issue on cpu=2 timer-softirq=2595
[  179.587642] rcu: rcu_preempt kthread starved for 2501 jiffies! g10493 f0x0 RCU_GP_WAIT_FQS(5) ->state=I ->cpu=2
[  179.588527] rcu: Unless rcu_preempt kthread gets sufficient CPU time, OOM is now expected behavior.
[  179.589326] rcu: RCU grace-period kthread stack dump:
[  179.589772] task:rcu_preempt     state:I stack:0     pid:16    tgid:16    ppid:2      task_flags:0x208040 flags:0x00000010
[  179.590746] Call trace:
[  179.590967] __switch_to+0xfc/0x1e8 (T)
[  179.591322] __schedule+0x350/0x1828
[  179.591644] schedule+0x3c/0xe8
[  179.591926] schedule_timeout+0x94/0x130
[  179.592279] rcu_gp_fqs_loop+0x11c/0x7b0
[  179.592631] rcu_gp_kthread+0x1d0/0x310
[  179.592974] kthread+0x138/0x150
[  179.593265] ret_from_fork+0x10/0x20
[  179.593586] rcu: Stack dump where RCU GP kthread last ran:
[  179.594069] Sending NMI from CPU 5 to CPUs 2:
[  179.594461] NMI backtrace for cpu 2 skipped: idling at cpu_idle_poll.isra.0+0x3c/0x120
[  184.825202] xhci-hcd xhci-hcd.0.auto: xHCI host not responding to stop endpoint command
[  184.838839] xhci-hcd xhci-hcd.0.auto: xHCI host controller not responding, assume dead
[  184.838915] xhci-hcd xhci-hcd.0.auto: HC died; cleaning up
[  184.839047] r8152 2-1.4:1.0 enx646266d00123: Stop submitting intr, status -108
[  184.839082] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  184.839193] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  184.839521] usb 1-1: USB disconnect, device number 2
[  184.839551] usb 1-1.2: USB disconnect, device number 3
[  184.839825] usb 2-1: USB disconnect, device number 2
[  184.839848] r8152-cfgselector 2-1.4: USB disconnect, device number 3
[  184.840418] r8152-cfgselector 2-1.4: Failed to read 4 bytes at 0xb400/0x0133 (-110)
[  184.879577] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  184.960177] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  184.980360] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  185.000537] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  185.060976] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  185.081139] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  185.101257] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  185.121371] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  185.141484] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  185.161595] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  185.201783] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  185.221906] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  185.242028] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  245.297890] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  245.338112] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  245.358226] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  245.398404] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  245.478769] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  245.498970] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  245.519080] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  245.579538] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  245.599700] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  245.619864] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  245.640027] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  245.660193] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  245.680357] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  245.720649] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  245.740817] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
[  245.760984] hid-generic 0003:051D:0002.0001: usb_submit_urb(ctrl) failed: -19
DMESG OUT "with performance governor"
[  977.525851] systemd-journald[1552]: Received client request to flush runtime journal.
[  977.618470] systemd-journald[1552]: Received client request to relinquish /var/log/journal/21a29cba476e44048a808d9a655190f3 access.
[ 1133.028633] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 1133.029230] rcu: 5-...0: (1 GPs behind) idle=456c/1/0x4000000000000000 softirq=19042/19044 fqs=3026
[ 1133.030049] rcu: (detected by 1, t=15006 jiffies, g=37889, q=2051 ncpus=6)
[ 1133.030673] Sending NMI from CPU 1 to CPUs 5:
[ 1143.032313] After 10 seconds, these CPUS still haven't responded to the NMI: 5
[ 1143.032965] rcu: rcu_preempt kthread timer wakeup didn't happen for 2500 jiffies! g37889 f0x0 RCU_GP_WAIT_FQS(5) ->state=I
[ 1143.033971] rcu: Possible timer handling issue on cpu=2 timer-softirq=12239
[ 1143.034601] rcu: rcu_preempt kthread starved for 2501 jiffies! g37889 f0x0 RCU_GP_WAIT_FQS(5) ->state=I ->cpu=2
[ 1143.035498] rcu: Unless rcu_preempt kthread gets sufficient CPU time, OOM is now expected behavior.
[ 1143.036308] rcu: RCU grace-period kthread stack dump:
[ 1143.036761] task:rcu_preempt     state:I stack:0     pid:16    tgid:16    ppid:2      task_flags:0x208040 flags:0x00000010
[ 1143.037753] Call trace:
[ 1143.037981] __switch_to+0xfc/0x1e8 (T)
[ 1143.038347] __schedule+0x350/0x1828
[ 1143.038680] schedule+0x3c/0xe8
[ 1143.038971] schedule_timeout+0x94/0x130
[ 1143.039334] rcu_gp_fqs_loop+0x11c/0x7b0
[ 1143.039696] rcu_gp_kthread+0x1d0/0x310
[ 1143.040047] kthread+0x138/0x150
[ 1143.040348] ret_from_fork+0x10/0x20
[ 1143.040680] rcu: Stack dump where RCU GP kthread last ran:
[ 1143.041172] Sending NMI from CPU 1 to CPUs 2:
[ 1143.041571] NMI backtrace for cpu 2 skipped: idling at cpu_idle_poll.isra.0+0x40/0x120
Edited by BipBip1981
Solved by BipBip1981
  • Author
  • Solution
2 hours ago, BipBip1981 said:
[  184.825202] xhci-hcd xhci-hcd.0.auto↗ (External link): xHCI host not responding to stop endpoint command
[  184.838839] xhci-hcd xhci-hcd.0.auto↗ (External link): xHCI host controller not responding, assume dead
[  184.838915] xhci-hcd xhci-hcd.0.auto↗ (External link): HC died; cleaning up
3 hours ago, BipBip1981 said:
With this, setting, stability seen to be back:
helios64@helios64:~$ cat /etc/default/cpufrequtils
ENABLE=true
MIN_SPEED=408000
MAX_SPEED=1420000
GOVERNOR=ondemand
root@helios64:~# cat /boot/armbianEnv.txt
verbosity=7
bootlogo=false
overlay_prefix=rockchip
rootdev=/dev/mapper/armbian-root cryptdevice=UUID=XXXXXXXXXXXXXXX:armbian-root
rootfstype=ext4
overlays=rk3399-helios64-cpu-stability
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
