Hi there,
the attempt to mount an smb-share does not work. The attempt ends with the messages
mount error: cifs filesystem not supported by the system
mount error(19): No such device
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
The output of
uname -r
is
4.13.16-cubox
cifs-utils are installed.
Am I missing something here?
Thanks in advance,
Christoph
Thanks for the reply. The command gives the output
/lib/modules/4.14.14-cubox/kernel/fs/cifs/cifs.ko
Are there any steps to somehow activate this?
Thanks in advance,
Christoph
This means you are not running the expected kernel since it is there for 4.14.14-cubox, but "uname -a" reported 4.13.16-cubox.
Make sure that the /boot/zImage symbolic link is pointing to proper kernel image.
In /boot I have
zImage -> vmlinuz-4.14.14-cubox
So this seems to be the correct image. What do I have to do somehow update the image?
Thanks in advance,
Christoph
There a two boot directories:
/boot
/boot/boot
After the initial installation I moved the root-directory to an usb stick. May this be the problem?
