umiddelb Posted February 2, 2018 Posted February 2, 2018 Just for curiosity, I've updated my Armbian on my Pine64 to the latest release. The latest u-boot for Pine64 (U-Boot SPL 2017.11-armbian (Jan 25 2018 - 08:32:21) seems to have an issue with the persistent u-boot environment. Once I've written a custom environment back to MMC using `saveenv´ the board hangs during boot. Environment size: 10335/131068 bytes => saveenv Saving Environment to MMC... Writing to MMC(0)... done => reset resetting ... INFO: PSCI Affinity Map: INFO: AffInst: Level 0, MPID 0x0, State ON INFO: AffInst: Level 0, MPID 0x1, State OFF INFO: AffInst: Level 0, MPID 0x2, State OFF INFO: AffInst: Level 0, MPID 0x3, State OFF U-Boot SPL 2017.11-armbian (Jan 25 2018 - 08:32:21) DRAM: 2048 MiB Trying to boot from MMC1 NOTICE: BL3-1: Running on A64/H64 (1689) in SRAM A2 (@0x44000) NOTICE: Configuring SPC Controller NOTICE: BL3-1: v1.0(debug):aa75c8d NOTICE: BL3-1: Built : 08:32:15, Jan 25 2018 NOTICE: Configuring AXP PMIC NOTICE: PMIC: Output power control 2 is an unexpected 0xd9 ERROR: PMIC: setup failed: -3 INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address: 0x4a000000, SPSR: 0x3c9 This might be an edge case for most of the Armbian users, since Armbian doesn't rely on a custom u-boot environment in oder to boot. I prefer to use my own u-boot framework instead, but it needs the capability to store a permanent custom u-boot environment. So if there is a chance to fix this issue I'd really appreciate it.
zador.blood.stained Posted February 2, 2018 Posted February 2, 2018 I can't find the start of the relevant discussion on the mailing list, but TL;DR saving the environment partially overwrites the u-boot binary, several fixes and safeguards were added to the current stable u-boot release and an ongoing environment migration efforts are planned for next stable releases. Regarding Armbian - this will be an issue until we migrate to a newer u-boot version.
umiddelb Posted February 2, 2018 Author Posted February 2, 2018 (edited) OK, thanks. I can live perfectly with the 5.24 u-boot release (U-Boot 2017.01-g0675f99 (Jan 20 2017 - 23:04:59 +0100)). Does this issue affect other boards using mainline u-boot as well? - The 5.35 u-boot release (U-Boot 2017.09-armbian (Nov 22 2017 - 17:09:56 +0100)) works as well. Edited February 2, 2018 by umiddelb
