I am trying to port my app running on legacy OS to Mainline OS and found some problems: I was able to replicate problem with following actions:
1) git cloned fresh copy of source to new directory - OK
2) edited config-default.conf:
KERNEL_ONLY="no"
KERNEL_CONFIGURE="no"
CLEAN_LEVEL="make,debs,oldcache,images"
DEST_LANG="en_US.UTF-8"
BOARD="pine64so"
BRANCH="next"
RELEASE="xenial"
BUILD_DESKTOP="yes"
KERNEL_KEEP_CONFIG="no"            # do not overwrite kernel config before compilation
EXTERNAL="no"                # build and install extra applications and drivers
EXTERNAL_NEW="prebuilt"            # compile and install or install prebuilt additional packages
CREATE_PATCHES="no"            # wait that you make changes to uboot and kernel source and creates patches
BUILD_ALL="no"                # cycle through available boards and make images or kernel/u-boot packages.
3) run ./compile.sh - OK
4) burn image and boot - OK
5) Now I look for armbianEnv.txt - none in any directory - Error??.
6) start sudo armbian-config - OK
7) move to System/Hardware - empty list after several errors:
- cat: /boot/armbianEnv.txt:No such file or directory
Could be i missed some docs explaining this ?
Mike
Workaround adopted:
1) create new armbianEnv.txt
2) added line "overlay-prefix=sun50i-a64
Now it works - even if armbianEnv.txt should be created by system with many other lines ....
Any comment?
Mike
Yes, we don't support mainline kernel for A64 yet since it's still under development/fragile. We are fully loaded and moving things with the best speed possible. Without help, progress can't be faster.
