brkl Posted February 27, 2018 Posted February 27, 2018 Hi! I'm having trouble with one (only one) of the alsamixer settings. 'MIC1 boost AMP gain control' shoots up to 71 every time I launch a program that uses sound, such as alsaloop or arecord. I've done 'sudo alsactl store', so I can get it back to zero by doing 'sudo alsactl restore'. Obviously that's not something I want to do all the time. I don't have any problems with any other settings. The setting in question completely ruins sound quality for my purposes, so I need it to stay at zero. I'm currently running 5.35 user-built Ubuntu 16.04.3 LTS 3.4.113-sun8i. I've tried Debian Jessie as well.
tommy Posted March 1, 2018 Posted March 1, 2018 You may try edit config file by command, sudo nano /var/lib/alsa/asound.state control.4 { iface MIXER name 'MIC1 boost AMP gain control' value 0 # !!! <- change to 0 comment { access 'read write' type INTEGER count 1 range '0 - 7' } } I not sure that this method could solve your problem.
brkl Posted March 2, 2018 Author Posted March 2, 2018 Thanks for the reply. I think I tried that, but the problem is not that it reverts to the saved settings, which are fine. I wouldn't have a problem then. Unfortunately I don't have this installation on hand anymore.
