Heisath Posted March 2, 2018 Posted March 2, 2018 Hi, I am currently using the back side push button on my clearfog pro for bringing the device to poweroff / halt. The easiest way to configure it like that seemed to change the button_0 entry in the device tree From: button_0 { label = "Rear Button"; gpios = <0x23 0x2 0x1>; linux,can-disable; linux,code = <0x100>; }; To: button_0 { label = "Rear Button"; gpios = <0x23 0x2 0x1>; linux,can-disable; linux,code = <0x74>; }; The linux code 0x74 signals the device to perform a graceful shutdown. Unfortunately I have to readjust the device tree after every update. I wouldn't suggest to change it to 0x74 for everyone, but would a config switch or a device tree overlay be possible for that? I prepared this, but am unsure how to compile / integrate it. // Switch back button event id /dts-v1/; /plugin/; / { compatible = "solidrun,clearfog-a1", "marvell,armada388", "marvell,armada385", "marvell,armada380"; fragment@0 { target = <&button_0>; __overlay__ { linux,code = <0x74>; }; }; }; Greetings, count-doku
zador.blood.stained Posted March 2, 2018 Posted March 2, 2018 U-boot overlays are supported only in the mainline u-boot (Armbian "dev" branch, dev u-boot can be used with all kernel branches with some limitations) Kernel overlays cannot be used since configfs overlays patch was not added to Clearfogs sources. I guess you could use the default button code and just map a shutdown command to it using daemons like "triggerhappy"
