Heisath Posted March 7, 2018 Posted March 7, 2018 Hi, out of interest I was checking the I²C Devices connected to the ClearfogPro. So this is thought as a small guide to the i2c bus. The second i2c bus goes straight to the mikrobus/click header so there is nothing on default. --- i2cdetect for bus 0 gave me: 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- 4c -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- 64 -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- Device 0x20 ) After checking the device tree and schematics, the device at 0x20 is the IO Expander used by a driver. Device 0x4c ) The 0x4c device is also listed in the dt. As the AD Converter for mikrobus/click header. I confirmed this working. You can use this, to read the current value. i2cget 0 0x4c 0x99 w 0x4c is the bus address. 0x99 is the data address according to the MCP3021 datasheet, w means we want to get a word. It then returns the current value, which can be interpreted by using the formula from the datasheet. Device 0x64 ) I don't know what is on the bus here. Neither the datasheet nor the device tree mentions anything, does anyone know? --- I2C Flash 24AA025UID ) The datasheet mentions the flash chip is only assembled in DNP assembly (checked not on my board) so this device is not available. I hope this helps someone else understand how to use the analog input pin and maybe give me a hint whats at 0x64. Greetings, count-doku
zador.blood.stained Posted March 7, 2018 Posted March 7, 2018 On 3/7/2018 at 11:01 AM, count-doku said: Device 0x64 ) I don't know what is on the bus here. Neither the datasheet nor the device tree mentions anything, does anyone know? Expand There isn't anything there: https://www.spinics.net/lists/devicetree/msg217137.html
Heisath Posted March 9, 2018 Author Posted March 9, 2018 Ah ok thats why I couldnt really talk to the device. Thanks
