I'm using nanopi-neo-air board and I have patched the Armbian build script for select uart1 as system console.
When I have changed the kernel boot args in boot-sunxi.cmd, script says the:
[ warn ] Can't update since you made changes to:
config/bootscripts/boot-sunxi.cmd
Press <Ctrl-C> to abort compilation, <Enter> to ignore and continue
How to normal modify config/bootscripts/boot-sunxi.cmd ?
Thank you.
If you can't use /boot/armbianEnv.txt, you might try using customize-image.sh and overlay.  Although, I'd probably just create a patch, git pull/checkout, and reapply patch.
This will not go this simple. You need to dig into u-boot.
