I notice also that one must reboot in order to reconnect to specific access points in xenial_next, however, the problem is alleviated in the default release. Seems like a regression...
11 minutes ago, HarambeLives said:
Let me know if there is anything else that I can do to help!!
There could be some possibly better drivers out there at github.com (need to search) and someone needs to test them ... once they are tested, we can move them inside the kernel tree and replace this one. If you ask us to do all the work, you will wait months.
1 hour ago, HarambeLives said:
I am more than happy to do the testing but would you please point me to the drivers you recommend that I try?
This is the best what I can give you: https://github.com/search?q=8723 ... check which looks best supported, most updated. Remember to blacklist the one inside the kernel when you get to the testing part.
