alex-nt Posted March 30, 2018 Posted March 30, 2018 Hello ! In my project I need use 2 spi bus : /dev/spidev1.0 and /dev/spi2.0 /dev/spidev1.0 for 3.5inch rpi display and /dev/spidev2.0 for 8x8 led matrices, such as MAX7219-8x32-MCU-Drive-LED If I am use legacy kernel (3.4.113-sun7i) both spi buses work well But if use mainline kernel (4.14.18-sunxi), I can use only 1 spi bus This is my armbianEnv.txt: overlays=spi-spidev spi1 spi2 param_spidev_spi_bus=1 In this case I can use /dev/spidev1.0 If I set param_spidev_spi_bus=2 I can use /dev/spidev2.0 How to enable 2 spi buses at the same time ?
Larry Bank Posted April 23, 2018 Posted April 23, 2018 The MAX7219 can easily be driven with bit banging (see my Arduino implementation here: https://github.com/bitbank2/max7219), but you raise a good question. I don't see in the documentation how it would be possible to enable both SPI bus 0 and 1 on AllWinner boards using the device tree overlays text file. @tkaiser Do you know how to specify both buses to be enabled?
