alex-nt Posted March 30, 2018 Share Posted March 30, 2018 Hello ! In my project I need use 2 spi bus : /dev/spidev1.0 and /dev/spi2.0 /dev/spidev1.0 for 3.5inch rpi display and /dev/spidev2.0 for 8x8 led matrices, such as MAX7219-8x32-MCU-Drive-LED If I am use legacy kernel (3.4.113-sun7i) both spi buses work well But if use mainline kernel (4.14.18-sunxi), I can use only 1 spi bus This is my armbianEnv.txt: overlays=spi-spidev spi1 spi2 param_spidev_spi_bus=1 In this case I can use /dev/spidev1.0 If I set param_spidev_spi_bus=2 I can use /dev/spidev2.0 How to enable 2 spi buses at the same time ? Link to comment Share on other sites More sharing options...
Larry Bank Posted April 23, 2018 Share Posted April 23, 2018 The MAX7219 can easily be driven with bit banging (see my Arduino implementation here: https://github.com/bitbank2/max7219), but you raise a good question. I don't see in the documentation how it would be possible to enable both SPI bus 0 and 1 on AllWinner boards using the device tree overlays text file. @tkaiser Do you know how to specify both buses to be enabled? Link to comment Share on other sites More sharing options...
