I am enjoying tinkering with the armbian build tools to customize images. I notice it takes about 2 hours to do a build on my machine. I am just making changes to the customize-image.sh and would like to know if there is an option to retain the default install image and just run the customization process?
Thanks
Neil
If you are using development branch - we are doing changes on a daily base and caches are dropping. In case you are attached to the main branch, things should be cached.
Adjust CLEAN_LEVEL , remove deb from it and kernel will not be rebuilt at next run.
https://docs.armbian.com/Developer-Guide_Build-Options/
