Greetings. For anyone interested FriendlyArm have a Github repo which contains a working AW CSI driver. and has device tree files for NanoPi M1+ and Neo Air.
See https://github.com/friendlyarm/linux.git. The branch is sunxi-4.16.y
This is a work in progress but the setup is vastly simplified compared to the VFE subsystem in the 3.4/3.10 kernels. The OV5640 driver does produce video but I'm getting some odd images at the moment. Possibly colorspace related.
As a bonus USB OTG is also working ...
fa@FriendlyELEC:~/src$ v4l2-compliance
Driver Info:
        Driver name   : sun6i-video
        Card type     : sun6i-csi
        Bus i[59399.088082] sun6i-csi 1cb0000.camera: =================  START STATUS  =================
nfo      : platform:camera
        Driver version: 4.16.0
        Capabiliti[59399.102740] sun6i-csi 1cb0000.camera: ==================  END STATUS  ==================
es  : 0x84200001
                Video Capture
                Streaming
                Extended Pix Format
                Device Capabilities
        Device Caps   : 0x04200001
                Video Capture
                Streaming
                Extended Pix Format
Compliance test for device /dev/video0 (not using libv4l2):
Required ioctls:
        test VIDIOC_QUERYCAP: OK
Allow for multiple opens:
        test second video open: OK
        test VIDIOC_G/S_PRIORITY: OK
Debug ioctls:
        test VIDIOC_DBG_G/S_REGISTER: OK (Not Supported)
        test VIDIOC_LOG_STATUS: OK
Input ioctls:
        test VIDIOC_G/S_TUNER/ENUM_FREQ_BANDS: OK (Not Supported)
        test VIDIOC_G/S_FREQUENCY: OK (Not Supported)
        test VIDIOC_S_HW_FREQ_SEEK: OK (Not Supported)
        test VIDIOC_ENUMAUDIO: OK (Not Supported)
        test VIDIOC_G/S/ENUMINPUT: OK
        test VIDIOC_G/S_AUDIO: OK (Not Supported)
        Inputs: 1 Audio Inputs: 0 Tuners: 0
Output ioctls:
        test VIDIOC_G/S_MODULATOR: OK (Not Supported)
        test VIDIOC_ENUMAUDOUT: OK (Not Supported)
        test VIDIOC_G/S/ENUMOUTPUT: OK (Not Supported)
        test VIDIOC_G/S_AUDOUT: OK (Not Supported)
        Outputs: 0 Audio Outputs: 0 Modulators: 0
Input/Output configuration ioctls:
        test VIDIOC_ENUM/G/S/QUERY_STD: OK (Not Supported)
        test VIDIOC_ENUM/G/S/QUERY_DV_TIMINGS: OK (Not Supported)
        test VIDIOC_DV_TIMINGS_CAP: OK (Not Supported)
        test VIDIOC_G/S_EDID: OK (Not Supported)
Test input 0:
        Control ioctls:
                test VIDIOC_QUERYCTRL/MENU: OK
                test VIDIOC_G/S_CTRL: OK
                test VIDIOC_G/S/TRY_EXT_CTRLS: OK
                test VIDIOC_(UN)SUBSCRIBE_EVENT/DQEVENT: OK
                test VIDIOC_G/S_JPEGCOMP: OK (Not Supported)
                Standard Controls: 14 Private Controls: 0
        Format ioctls:
                fail: v4l2-test-formats.cpp(259): duplicate format 32314d48
                test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: FAIL
                test VIDIOC_G/S_PARM: OK (Not Supported)
                test VIDIOC_G_FBUF: OK (Not Supported)
                fail: v4l2-test-formats.cpp(314): !colorspace
                fail: v4l2-test-formats.cpp(417): testColorspace(pix.pixelformat, pix.colorspace)
                test VIDIOC_G_FMT: FAIL
                test VIDIOC_TRY_FMT: OK (Not Supported)
                test VIDIOC_S_FMT: OK (Not Supported)
                test VIDIOC_G_SLICED_VBI_CAP: OK (Not Supported)
        Codec ioctls:
                test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported)
                test VIDIOC_G_ENC_INDEX: OK (Not Supported)
                test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported)
        Buffer ioctls:
                test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: OK
                fail: v4l2-test-buffers.cpp(500): q.has_expbuf(node)
                test VIDIOC_EXPBUF: FAIL
Total: 38, Succeeded: 35, Failed: 3, Warnings: 0
