lionz Posted April 15, 2018 Posted April 15, 2018 (edited) Hello, I am using the Armbian_5.38_Orangepizero_Debian_stretch_next_4.14.14 image on an OPi zero (H2+ chip). I tried to get "some sound" out of the LINEOUTL and right pins at the expansion port. However, alsa executables like aplay report that there is no sound card. (see below) I testet also with a non-root user (which is in the audio group). My initial guess was that there must some additioanl kernel modules loaded. As I understand, however, the lsmod output, (2) below, should be ok. What it is thing to do to see soundcard(s), e.g. as /dev/dsp? Do I need to set files such as ~/.asoundrc or /etc/asound.conf as a prerequisite (if so what contents) or is this optional and something else is missing? --------------------------- (1) root@orangepizero:~# aplay test.wav ALSA lib pcm_hw.c:1713:(_snd_pcm_hw_open) Invalid value for card aplay: main:788: audio open error: No such device root@orangepizero:~# aplay -l aplay: device_list:270: no soundcards found... (2) root@orangepizero:~# lsmod Module Size Used by sun8i_codec_analog 24576 0 snd_soc_core 118784 3 sun8i_codec_analog,snd_soc_simple_card_utils,snd_soc_simple_card snd_pcm_dmaengine 16384 1 snd_soc_core snd_pcm 65536 2 snd_pcm_dmaengine,snd_soc_core snd_timer 24576 1 snd_pcm snd 45056 3 snd_timer,snd_soc_core,snd_pcm soundcore 16384 1 snd ... (3) ls /lib/modules/4.14.18-sunxi/kernel/sound/soc/* (4) root@orangepizero:~# lsmod snd_soc_simple_card 16384 0 snd_soc_simple_card_utils 16384 1 snd_soc_simple_card ... EDIT: Note 1: Even though I tried all this while a new kernel 4.14.18 was in place, it did not work either with 4.14.14 as far as I recall. Edited April 15, 2018 by lionz added detail
guidol Posted April 15, 2018 Posted April 15, 2018 5 hours ago, lionz said: What it is thing to do to see soundcard(s), e.g. as /dev/dsp? Do I need to set files such as ~/.asoundrc or /etc/asound.conf as a prerequisite (if so what contents) or is this optional and something else is missing? (2) root@orangepizero:~# lsmod Module Size Used bysun8i_codec_analog 24576 0 snd_soc_core 118784 3 sun8i_codec_analog,snd_soc_simple_card_utils,snd_soc_simple_card because codec_analog is already loaded as module I asume, that you did enable the analog_codec as kernel overlay by the command "armbian-config"? armbian-config ==> System ==> Hardware ==> Tick "analog-codec" ==> Save ==> more times Cancel (to get out of armbian-config) ==> reboot
