chiefwigms Posted February 17, 2016 Share Posted February 17, 2016 Anyone get ArduinoIDE working on armbian for the Udoo quad? When I try to upload a sketch, i see a java exception for bossac - no such file or directory (when i try to run bossac -h, same error) Edit - the error above was for Udoo's 1.5.8 version. I tried 1.5.4, and now I get errors trying to create GPIO0 and GPIO117 (direction & value). Link to comment Share on other sites More sharing options...
Igor Posted February 17, 2016 Share Posted February 17, 2016 We only provide support on kernel level so you probably need to install some extra libs from Udoo pages. Link to comment Share on other sites More sharing options...
chiefwigms Posted February 19, 2016 Author Share Posted February 19, 2016 I messed around with an earlier version of the ArduinoIDE, and it looks like the reason its failing is because it can't export gpio 0 and 117 (says device/resource is busy). From patrykk's kernel readme, there's a line that says: Arduino with Udoo patch (export gpio 0 and 117: "echo 0 > /sys/class/gpio/export; echo 117 > /sys/class/gpio/export")This is all from the 3.14.28 kernel a while back (just got back to messing around with armbian). I tried loading the latest 5.0/3.14.60 jessie image, but it doesn't boot (my display says video out of sync). I tried loading the latest 5.0/4.2.8 jessie image (keyboard layout is messed up - various characters numeric/<>":"'; are mapped incorrectly), and I get the same error message when trying to export gpio 0 and 117. I believe those lines need to get toggled to erase the sam3x Also - I saw on the same readme that its possible to just recompile the dtb ("make imx6q-udoo.dtb") - this would be really helpful just to add one-wire without recompiling the whole kernel (after original compile). I tried building both udoo and udoo-next, but the version is 4.7. Anyway to add tags in the compile script to mirror what is on the main armbian site? Ideally it'd just be a device tree overlay that you'd be able to append to any build. Thanks for all the hardwork - if not for armbian, the udoo platform would be dead Link to comment Share on other sites More sharing options...
patrykk Posted February 23, 2016 Share Posted February 23, 2016 Hellou whole forum, Please try remove Bossac driver or just test vanilla arduino IDE. I have changed howto. BTW. Please update kernel to 4.4.x version. best regards, Patrykk Link to comment Share on other sites More sharing options...
Igor Posted February 23, 2016 Share Posted February 23, 2016 Will do ASAP. Thanks! Link to comment Share on other sites More sharing options...
marcinozog Posted September 23, 2016 Share Posted September 23, 2016 Replace bossac from /usr/local/lib/udoo-arduino-cli/hardware/tools to https://github.com/UDOOboard/bossac/tree/master/prebuilt/udoo Link to comment Share on other sites More sharing options...
