MrEder Posted April 18, 2018 Posted April 18, 2018 Hi, I have a Cubietruck and install Armbian_5.38_Cubietruck_Debian_stretch_next_4.14.14.img from https://www.armbian.com/cubietruck/. Copied with Etcher the unpacked .img-File to a SanDisk Ultra 32GB micro SD HC1. But no system comes up Last message U-Boot 2017,14-armbian (Jan 24 2018 ... . . Loading Device Tree to 49ab5000, end 49b29fff ... OK Starting Kernel No blinking cursour on top of the left side. Nothing go's on! System with Armbian_5.37_Cubieboard2_Debian_stretch_next_4.14.14.img works, but no network with armbian-config, neither static nor DHCP, can configure. (dnsmasq.service not found) LAN-Cable ist pluged. What is the problem?
JBraun Posted March 15, 2019 Posted March 15, 2019 (edited) I have an similar issue. I am using an Cubietruck. It works fine with an older NAND image. I am trying to start ARMBIAN (different versions, e.g. Armbian_5.75_Cubietruck_Debian_stretch_next_4.19.20) from a SD card (2 different ones). I have also used different power supplies. The last message on HDMI and Console is "starting kernel" but nothing happens. Sometimes with an reboot sometimes not. Also an USB mouse and keyboard will not activated. So I assume the kernel is not started. So I reboot to the old installation. After that I can read and manipulate some files. So I assume the card is OK. So have the feeling, that there is something not fine with the configuration or with the NAND (what should not be involved). I have read a lot of web pages, but with no luck to find a solution I have no idea what I can do / check. Best regards Jörg from my console: after the last line will nothing happen (at least some minutes) Spoiler U-Boot SPL 2018.11-armbian (Feb 08 2019 - 09:27:49 +0100) DRAM: 2048 MiB CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC1 U-Boot 2018.11-armbian (Feb 08 2019 - 09:27:49 +0100) Allwinner Technology CPU: Allwinner A20 (SUN7I) Model: Cubietech Cubietruck I2C: ready DRAM: 2 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** HDMI connected: Setting up a 1920x1080 hdmi console (overscan 0x0) Error: no valid bmp image at 66000000 In: serial Out: vga Err: vga Allwinner mUSB OTG (Peripheral) SCSI: SATA link 0 timeout. AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: ncq stag pm led clo only pmp pio slum part ccc apst Net: eth0: ethernet@1c50000 Warning: usb_ether using MAC address from ROM , eth1: usb_ether 230454 bytes read in 20 ms (11 MiB/s) starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 USB2: USB EHCI 1.00 USB3: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3798 bytes read in 11 ms (336.9 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 155 bytes read in 9 ms (16.6 KiB/s) 4921685 bytes read in 289 ms (16.2 MiB/s) 7323200 bytes read in 423 ms (16.5 MiB/s) Found mainline kernel configuration prefetch abort prefetch abort prefetch abort prefetch abort pc : [<00fa3ba8>] lr : [<00fa3bad>] prefetch abort prefetch abort prefetch abort prefetch abort prefetch abort pc : [<00f81d10>] lr : [<bef81d15>] prefetch abort prefetch abort prefetch abort prefetch abort prefetch abort pc : [<00f657e8>] lr : [<00fb5657>] reloc pc : [<8c0017e8>] lr : [<8c051657>] prefetch abort prefetch abort prefetch abort prefetch abort pc : [<00f81d10>] lr : [<bef81d15>] reloc pc : [<8c01dd10>] lr : [<4a01dd15>] prefetch abort prefetch abort prefetch abundefined instruction prefetch abort pc : [<00f81d10>] lr : [<bef81d15>] pre▒etc▒ ab▒rt ▒▒▒▒prefetch abort prefetch abort prefetch abort pc : [<10f657e8>] lr : [<befb5657>] reloc pc : [<9c0017e8>] lr : [<4a051657>] prefetch abort prefetch abort undefined instruction prefetch abort prefetch abort pc : [<00f65982>] lr : [<00f65987>] prefetch abort prefetch abort prefetch abort pc : [<00fa3ba8>] lr : [<00fa3bad>] reloc pc : [<8c03fba8>] lr : [<8c03fbad>] sp : 00f309a0 ip : 0026ca00 fp : 00f80078r10: 00000002 r9 : baf43ed8 r8 : 00fca6c4 prefetch abort prefetch abort pc : [<00fa3ba8>] lr : [<befa3bad>] reloc pc : [<8c03fba8>] lr : [<4a03fbad>] sp : baf2fac8 ip : 000000f0 fp : 00f80078 r10: 00000002 r9 : baf43ed8 r8 : 00f45aa0 r7 : 00000070 r6 : 00000000 r5 : baf2ff2c r4 : 00000400 r3 : baf2fad8 r2 : 00000400 r1 : 00000400 r0 : 0000000f Flags: nzCv IRQs on FIQs on Mode SVC_32 Code: 00000000 00000000 00000000 00000000 (00000000) Resetting CPU ... resetting ... U-Boot SPL 2018.11-armbian (Feb 08 2019 - 09:27:49 +0100) DRAM: 2048 MiB CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC1 U-Boot 2018.11-armbian (Feb 08 2019 - 09:27:49 +0100) Allwinner Technology CPU: Allwinner A20 (SUN7I) Model: Cubietech Cubietruck I2C: ready DRAM: 2 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** HDMI connected: Setting up a 1920x1080 hdmi console (overscan 0x0) In: serial Out: vga Err: vga Allwinner mUSB OTG (Peripheral) SCSI: SATA link 0 timeout. AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: ncq stag pm led clo only pmp pio slum part ccc apst Net: eth0: ethernet@1c50000 Warning: usb_ether using MAC address from ROM , eth1: usb_ether 230454 bytes read in 21 ms (10.5 MiB/s) starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 USB2: USB EHCI 1.00 USB3: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3798 bytes read in 12 ms (308.6 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 155 bytes read in 9 ms (16.6 KiB/s) 4921685 bytes read in 289 ms (16.2 MiB/s) 7323200 bytes read in 424 ms (16.5 MiB/s) Found mainline kernel configuration 40903 bytes read in 27 ms (1.4 MiB/s) 5845 bytes read in 34 ms (167 KiB/s) Applying kernel provided DT fixup script (sun7i-a20-fixup.scr) ## Executing script at 44000000 ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 4921621 Bytes = 4.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 EHCI failed to shut down host controller. EHCI failed to shut down host controller. Loading Ramdisk to 49b4e000, end 49fff915 ... OK reserving fdt memory region: addr=43000000 size=70000 Loading Device Tree to 49adb000, end 49b4dfff ... OK Starting kernel ... Uncompressing Linux... Edited March 15, 2019 by lanefu Place console code inside "spoiler" to keep readability up on forum
