Lucas Schiochet Posted April 18, 2018 Posted April 18, 2018 Hi, We are testing our orange pi one in critical external environments like warehouses, manufacturing and other. In some cases, even if the good case there is a misconnection between the sd card and the orange pi one. Connected in ssh i can access the orange pi but a lot of command cannot responde anymore, like ls, top, htop, tail and others. Even the reboot shows me the input-output-error, and the only way to reboot the hardware is using "echo b > /proc/sysrq-trigger". When this happens, i tried create a cron with 'at' or background jobs using sh like './script.sh &' with the content "echo b > /proc/sysrq-trigger" but still not works. My question is, when i remove the sd card from the board a lot of i/o features are disable. How can i identity and reboot when this happen automatically? i am using orange pi one based on linux 4.14 ubuntu xenial. Thanks
chwe Posted April 19, 2018 Posted April 19, 2018 21 hours ago, Lucas Schiochet said: In some cases, even if the good case there is a misconnection between the sd card and the orange pi one wouldn't it make sense to figure out why you lose connection instead of finding a fallback for a situation which might differ from time to time on which state you lost contact to the SD-Card. So is it a hardware issue - means that the physically lost connection (cause the SD-Card connector is damaged) or cause your cards gets corrupted due to bad quality or to much writing to it that they get destroyed by your usage? There must be a reason why you lost connection to your card. And figuring out why that happens might be solve your problem better not?
olivluca Posted April 21, 2018 Posted April 21, 2018 FWIW I had the same kind of error after my RCCB tripped 5 times in a row in a few minutes. The strange thing is, the error didn't happen until the next day when I restarted a daemon, and cutting power again has apparently fixed it
