GusAntoniassi Posted April 22, 2018 Posted April 22, 2018 Greetings all. I've bought an Orange Pi PC recently, along with this screen, and I wanted to make the touch screen work on it. I have tried following this tutorial and this one, but so far I was only able to get the screen working. Currently installed image is: Armbian_5.35_Orangepipc_Debian_jessie_default_3.4.113. When I run `evtest` the only devices detected are `vmouse`, `sunxi-gpiokey` and `sunxi-ths`. I tried installing a GUI with xorg, lightdm and xfce. To show the GUI on the display I am using the following command: FRAMEBUFFER=/dev/fb8 startx But touch still isn't working. This is the output of armbianmonitor -u: http://ix.io/18t5 This is my armbianEnv.txt: Spoiler verbosity=1 console=both overlay_prefix=sun8i-h3 rootdev=UUID=4e480977-eceb-4d3c-a360-936d4336ded5 rootfstype=ext4 overlays=spi-spidev spi-add-cs1 param_spidev_spi_bus=0 param_spidev_spi_cs=1 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u This is my orangepipc.fex Spoiler [product] version = "100" machine = "Xunlong Orange Pi PC" [platform] debug_mode = 1 eraseflag = 1 next_work = 2 [target] boot_clock = 1008 storage_type = -1 [key_detect_en] keyen_flag = 0 [fel_key] fel_key_max = 7 fel_key_min = 2 [card_boot] logical_start = 40960 sprite_work_delay = 500 sprite_err_delay = 200 sprite_gpio0 = port:PL10<1><default><default><default> next_work = 3 [box_start_os] used = 1 start_type = 1 irkey_used = 1 pmukey_used = 1 pmukey_num = 3 led_power = 0 led_state = 0 [boot_init_gpio] used = 1 gpio0 = port:PL10<1><default><default><1> gpio1 = port:PG11<1><default><default><1> [recovery_para] used = 1 mode = 2 recovery_key = port:PL04<0><default><default><default> [pm_para] standby_mode = 1 [card0_boot_para] card_ctrl = 0 card_high_speed = 1 card_line = 4 sdc_d1 = port:PF00<2><1><2><default> sdc_d0 = port:PF01<2><1><2><default> sdc_clk = port:PF02<2><1><2><default> sdc_cmd = port:PF03<2><1><2><default> sdc_d3 = port:PF04<2><1><2><default> sdc_d2 = port:PF05<2><1><2><default> [card2_boot_para] card_ctrl = 2 card_high_speed = 1 card_line = 8 sdc_cmd = port:PC06<3><1><2><default> sdc_clk = port:PC05<3><1><2><default> sdc_d0 = port:PC08<3><1><2><default> sdc_d1 = port:PC09<3><1><2><default> sdc_d2 = port:PC10<3><1><2><default> sdc_d3 = port:PC11<3><1><2><default> sdc_d4 = port:PC12<3><1><2><default> sdc_d5 = port:PC13<3><1><2><default> sdc_d6 = port:PC14<3><1><2><default> sdc_d7 = port:PC15<3><1><2><default> sdc_2xmode = 1 sdc_ddrmode = 1 [twi_para] twi_port = 0 twi_scl = port:PA11<2><default><default><default> twi_sda = port:PA12<2><default><default><default> [uart_para] uart_debug_port = 0 uart_debug_tx = port:PA04<2><1><default><default> uart_debug_rx = port:PA05<2><1><default><default> [force_uart_para] force_uart_port = 0 force_uart_tx = port:PF02<3><1><default><default> force_uart_rx = port:PF04<3><1><default><default> [jtag_para] jtag_enable = 0 jtag_ms = port:PA00<3><default><default><default> jtag_ck = port:PA01<3><default><default><default> jtag_do = port:PA02<3><default><default><default> jtag_di = port:PA03<3><default><default><default> [clock] pll_video = 297 pll_ve = 402 pll_periph0 = 600 pll_gpu = 576 pll_periph1 = 600 pll_de = 864 [dram_para] dram_clk = 624 dram_type = 3 dram_zq = 0x3b3bfb dram_odt_en = 1 dram_para1 = 283377664 dram_para2 = 0 dram_mr0 = 6208 dram_mr1 = 64 dram_mr2 = 24 dram_mr3 = 2 dram_tpr0 = 0x48a192 dram_tpr1 = 0x1c2418d dram_tpr2 = 0x76051 dram_tpr3 = 0x0 dram_tpr4 = 0x0 dram_tpr5 = 0x0 dram_tpr6 = 0x64 dram_tpr7 = 0x0 dram_tpr8 = 0x0 dram_tpr9 = 0x0 dram_tpr10 = 0x0 dram_tpr11 = 0x6aaa0000 dram_tpr12 = 0x7979 dram_tpr13 = 0x800800 [wakeup_src_para] cpu_en = 0 cpu_freq = 48 pll_ratio = 273 dram_selfresh_en = 1 dram_freq = 36 wakeup_src0 = wakeup_src_wl = port:PG10<4><default><default><0> wakeup_src_bt = port:PL03<6><default><default><0> [twi0] twi_used = 1 twi_scl = port:PA11<2><default><default><default> twi_sda = port:PA12<2><default><default><default> [twi1] twi_used = 1 twi_scl = port:PA18<3><default><default><default> twi_sda = port:PA19<3><default><default><default> [twi2] twi_used = 0 twi_scl = port:PE12<3><default><default><default> twi_sda = port:PE13<3><default><default><default> [uart0] uart_used = 1 uart_port = 0 uart_type = 2 uart_tx = port:PA04<2><1><default><default> uart_rx = port:PA05<2><1><default><default> [uart1] uart_used = 0 uart_port = 1 uart_type = 4 uart_tx = port:PG06<2><1><default><default> uart_rx = port:PG07<2><1><default><default> uart_rts = port:PG08<2><1><default><default> uart_cts = port:PG09<2><1><default><default> [uart2] uart_used = 0 uart_port = 2 uart_type = 4 uart_tx = port:PA00<2><1><default><default> uart_rx = port:PA01<2><1><default><default> uart_rts = port:PA02<2><1><default><default> uart_cts = port:PA03<2><1><default><default> [uart3] uart_used = 0 uart_port = 3 uart_type = 4 uart_tx = port:PA13<3><1><default><default> uart_rx = port:PA14<3><1><default><default> uart_rts = port:PA15<3><1><default><default> uart_cts = port:PA16<3><1><default><default> [spi0] spi_used = 1 spi_cs_bitmap = 1 spi_mosi = port:PC00<3><default><default><default> spi_miso = port:PC01<3><default><default><default> spi_sclk = port:PC02<3><default><default><default> spi_cs0 = port:PC03<3><1><default><default> [spi1] spi_used = 1 spi_cs_bitmap = 1 spi_cs0 = port:PA13<2><1><default><default> spi_sclk = port:PA14<2><default><default><default> spi_mosi = port:PA15<2><default><default><default> spi_miso = port:PA16<2><default><default><default> [spi_devices] spi_dev_num = 2 [spi_board0] modalias = "spidev" max_speed_hz = 33000000 bus_num = 0 chip_select = 0 mode = 0 full_duplex = 1 manual_cs = 0 [spi_board1] modalias = "spidev" max_speed_hz = 33000000 bus_num = 2 chip_select = 0 mode = 0 full_duplex = 1 manual_cs = 0 [gpio_para] gpio_used = 0 gpio_num = 0 [leds_para] leds_used = 1 green_led = port:PL10<1><default><default><1> green_led_active_low = 0 red_led = port:PA15<1><default><default><0> red_led_active_low = 0 [ths_para] ths_used = 1 ths_trip1_count = 6 ths_trip1_0 = 75 ths_trip1_1 = 80 ths_trip1_2 = 85 ths_trip1_3 = 90 ths_trip1_4 = 95 ths_trip1_5 = 105 ths_trip1_6 = 0 ths_trip1_7 = 0 ths_trip1_0_min = 0 ths_trip1_0_max = 1 ths_trip1_1_min = 1 ths_trip1_1_max = 2 ths_trip1_2_min = 2 ths_trip1_2_max = 3 ths_trip1_3_min = 3 ths_trip1_3_max = 4 ths_trip1_4_min = 4 ths_trip1_4_max = 8 ths_trip1_5_min = 8 ths_trip1_5_max = 8 ths_trip1_6_min = 0 ths_trip1_6_max = 0 ths_trip2_count = 1 ths_trip2_0 = 105 [cooler_table] cooler_count = 9 cooler0 = "1296000 4 4294967295 0" cooler1 = "1200000 4 4294967295 0" cooler2 = "1008000 4 4294967295 0" cooler3 = "816000 4 4294967295 0" cooler4 = "648000 4 4294967295 0" cooler5 = "480000 4 4294967295 0" cooler6 = "480000 3 4294967295 0" cooler7 = "480000 2 4294967295 0" cooler8 = "480000 1 4294967295 0" [nand0_para] nand_support_2ch = 0 nand0_used = 0 nand0_we = port:PC00<2><default><default><default> nand0_ale = port:PC01<2><default><default><default> nand0_cle = port:PC02<2><default><default><default> nand0_ce1 = port:PC03<2><default><default><default> nand0_ce0 = port:PC04<2><default><default><default> nand0_nre = port:PC05<2><default><default><default> nand0_rb0 = port:PC06<2><default><default><default> nand0_rb1 = port:PC07<2><default><default><default> nand0_d0 = port:PC08<2><default><default><default> nand0_d1 = port:PC09<2><default><default><default> nand0_d2 = port:PC10<2><default><default><default> nand0_d3 = port:PC11<2><default><default><default> nand0_d4 = port:PC12<2><default><default><default> nand0_d5 = port:PC13<2><default><default><default> nand0_d6 = port:PC14<2><default><default><default> nand0_d7 = port:PC15<2><default><default><default> nand0_ndqs = port:PC16<2><default><default><default> [boot_disp] advert_disp = 0 auto_hpd = 1 output_type = 4 hdmi_channel = 0 hdmi_mode = 4 cvbs_channel = 1 cvbs_mode = 11 output_full = 1 hdmi_mode_check = 1 [disp_init] disp_init_enable = 1 disp_mode = 0 screen0_output_type = 3 screen0_output_mode = 5 screen1_output_type = 3 screen1_output_mode = 5 fb0_format = 0 fb0_width = 0 fb0_height = 0 fb1_format = 0 fb1_width = 0 fb1_height = 0 [hdmi_para] hdmi_used = 1 hdmi_power = "vcc-hdmi-18" [tv_para] tv_used = 0 tv_dac_used = 1 tv_dac_src0 = 0 [pwm0_para] pwm_used = 0 pwm_positive = port:PA05<3><0><default><default> [gmac0] gmac_used = 2 gmac_power1 = [csi0] vip_used = 1 vip_mode = 0 vip_dev_qty = 1 vip_define_sensor_list = 0 vip_csi_pck = port:PE00<2><default><default><default> vip_csi_mck = port:PE01<2><default><default><default> vip_csi_hsync = port:PE02<2><default><default><default> vip_csi_vsync = port:PE03<2><default><default><default> vip_csi_d0 = port:PE04<2><default><default><default> vip_csi_d1 = port:PE05<2><default><default><default> vip_csi_d2 = port:PE06<2><default><default><default> vip_csi_d3 = port:PE07<2><default><default><default> vip_csi_d4 = port:PE08<2><default><default><default> vip_csi_d5 = port:PE09<2><default><default><default> vip_csi_d6 = port:PE10<2><default><default><default> vip_csi_d7 = port:PE11<2><default><default><default> vip_csi_sck = port:PE12<2><default><default><default> vip_csi_sda = port:PE13<2><default><default><default> vip_dev0_mname = "gc2035" vip_dev0_pos = "front" vip_dev0_lane = 1 vip_dev0_twi_id = 2 vip_dev0_twi_addr = 120 vip_dev0_isp_used = 0 vip_dev0_fmt = 0 vip_dev0_stby_mode = 0 vip_dev0_vflip = 1 vip_dev0_hflip = 1 vip_dev0_iovdd = "" vip_dev0_iovdd_vol = 2800000 vip_dev0_avdd = "" vip_dev0_avdd_vol = 2800000 vip_dev0_dvdd = "" vip_dev0_dvdd_vol = 1800000 vip_dev0_afvdd = "" vip_dev0_afvdd_vol = 2800000 vip_dev0_power_en = port:PA17<1><default><default><1> vip_dev0_reset = port:PE14<1><default><default><1> vip_dev0_pwdn = port:PE15<1><default><default><0> vip_dev0_flash_en = vip_dev0_flash_mode = vip_dev0_af_pwdn = vip_dev0_act_used = 0 vip_dev0_act_name = "ad5820_act" vip_dev0_act_slave = 24 vip_dev1_mname = "" vip_dev1_pos = "rear" vip_dev1_lane = 1 vip_dev1_twi_id = 0 vip_dev1_twi_addr = vip_dev1_isp_used = 0 vip_dev1_fmt = 1 vip_dev1_stby_mode = 0 vip_dev1_vflip = 0 vip_dev1_hflip = 0 vip_dev1_iovdd = "" vip_dev1_iovdd_vol = 2800000 vip_dev1_avdd = "" vip_dev1_avdd_vol = 2800000 vip_dev1_dvdd = "" vip_dev1_dvdd_vol = 1500000 vip_dev1_afvdd = "" vip_dev1_afvdd_vol = 2800000 vip_dev1_power_en = vip_dev1_reset = vip_dev1_pwdn = vip_dev1_flash_en = vip_dev1_flash_mode = vip_dev1_af_pwdn = [tvout_para] tvout_used = 0 tvout_channel_num = tv_en = 0 [tvin_para] tvin_used = 0 tvin_channel_num = [di_para] di_used = 1 [mmc0_para] sdc_used = 1 sdc_detmode = 3 sdc_buswidth = 4 sdc_clk = port:PF02<2><1><2><default> sdc_cmd = port:PF03<2><1><2><default> sdc_d0 = port:PF01<2><1><2><default> sdc_d1 = port:PF00<2><1><2><default> sdc_d2 = port:PF05<2><1><2><default> sdc_d3 = port:PF04<2><1><2><default> sdc_det = port:PF06<0><1><2><default> sdc_use_wp = 0 sdc_wp = sdc_isio = 0 sdc_regulator = "none" sdc_power_supply = "none" [mmc1_para] sdc_used = 1 sdc_detmode = 4 sdc_buswidth = 4 sdc_clk = port:PG00<2><1><3><default> sdc_cmd = port:PG01<2><1><3><default> sdc_d0 = port:PG02<2><1><3><default> sdc_d1 = port:PG03<2><1><3><default> sdc_d2 = port:PG04<2><1><3><default> sdc_d3 = port:PG05<2><1><3><default> sdc_det = sdc_use_wp = 0 sdc_wp = sdc_isio = 1 sdc_regulator = "none" sdc_power_supply = "none" sdc_2xmode = 1 sdc_ddrmode = 1 [mmc2_para] sdc_used = 0 sdc_detmode = 3 sdc_buswidth = 8 sdc_clk = port:PC05<3><1><2><default> sdc_cmd = port:PC06<3><1><2><default> sdc_d0 = port:PC08<3><1><2><default> sdc_d1 = port:PC09<3><1><2><default> sdc_d2 = port:PC10<3><1><2><default> sdc_d3 = port:PC11<3><1><2><default> sdc_d4 = port:PC12<3><1><2><default> sdc_d5 = port:PC13<3><1><2><default> sdc_d6 = port:PC14<3><1><2><default> sdc_d7 = port:PC15<3><1><2><default> emmc_rst = port:PC16<3><1><2><default> sdc_det = sdc_use_wp = 0 sdc_wp = sdc_isio = 0 sdc_regulator = "none" sdc_power_supply = "none" sdc_2xmode = 1 sdc_ddrmode = 1 [smc_para] smc_used = 0 smc_rst = port:PA09<2><default><default><default> smc_vppen = port:PA20<3><default><default><default> smc_vppp = port:PA21<3><default><default><default> smc_det = port:PA10<2><default><default><default> smc_vccen = port:PA06<2><default><default><default> smc_sck = port:PA07<2><default><default><default> smc_sda = port:PA08<2><default><default><default> [usbc0] usb_used = 1 usb_port_type = 2 usb_detect_type = 0 usb_id_gpio = port:PG12<0><1><default><default> usb_det_vbus_gpio = port:PG12<0><1><default><default> usb_drv_vbus_gpio = port:PL02<1><0><default><0> usb_host_init_state = 1 usb_restrict_gpio = usb_restric_flag = 0 usb_restric_voltage = 3550000 usb_restric_capacity = 5 usb_regulator_io = "nocare" usb_regulator_vol = 0 usb_not_suspend = 0 [usbc1] usb_used = 1 usb_drv_vbus_gpio = usb_restrict_gpio = usb_host_init_state = 1 usb_restric_flag = 0 usb_regulator_io = "nocare" usb_regulator_vol = 0 usb_not_suspend = 0 [usbc2] usb_used = 1 usb_drv_vbus_gpio = usb_restrict_gpio = usb_host_init_state = 1 usb_restric_flag = 0 usb_regulator_io = "nocare" usb_regulator_vol = 0 usb_not_suspend = 0 [usbc3] usb_used = 1 usb_drv_vbus_gpio = usb_restrict_gpio = usb_host_init_state = 1 usb_restric_flag = 0 usb_regulator_io = "nocare" usb_regulator_vol = 0 usb_not_suspend = 0 [usb_feature] vendor_id = 6353 mass_storage_id = 1 adb_id = 2 manufacturer_name = "USB Developer" product_name = "Android" serial_number = "20080411" [msc_feature] vendor_name = "USB 2.0" product_name = "USB Flash Driver" release = 100 luns = 3 [serial_feature] serial_unique = 0 [module_para] module_num = 7 module_power0 = "vcc-wifi-33" module_power0_vol = 0 module_power1 = module_power1_vol = module_power2 = module_power2_vol = module_power3 = module_power3_vol = chip_en = lpo_use_apclk = [wifi_para] wifi_used = 0 wifi_sdc_id = 1 wifi_usbc_id = 5 wifi_usbc_type = 1 wl_reg_on = port:PL07<1><default><default><0> wl_host_wake = port:PG10<0><default><default><0> wl_host_wake_invert = 0 [bt_para] bt_used = 0 bt_uart_id = 1 bt_rst_n = bt_wake = bt_host_wake = bt_host_wake_invert = 0 [pcm0] daudio_used = 0 daudio_master = 4 daudio_select = 1 audio_format = 1 signal_inversion = 1 mclk_fs = 128 sample_resolution = 16 slot_width_select = 32 pcm_lrck_period = 32 pcm_lrckr_period = 1 msb_lsb_first = 0 sign_extend = 0 slot_index = 0 slot_width = 32 frame_width = 0 tx_data_mode = 0 rx_data_mode = 0 i2s_mclk = port:PA18<2><1><default><default> i2s_bclk = port:PA19<2><1><default><default> i2s_dout0 = port:PA20<2><1><default><default> i2s_din = port:PA21<2><1><default><default> [pcm1] daudio_used = 0 daudio_master = 4 daudio_select = 1 audio_format = 1 signal_inversion = 1 mclk_fs = 128 sample_resolution = 16 slot_width_select = 32 pcm_lrck_period = 32 pcm_lrckr_period = 1 msb_lsb_first = 0 sign_extend = 0 slot_index = 0 slot_width = 32 frame_width = 0 tx_data_mode = 0 rx_data_mode = 0 i2s_mclk = port:PG10<2><1><default><default> i2s_bclk = port:PG11<2><1><default><default> i2s_dout0 = port:PG12<2><1><default><default> i2s_din = port:PG13<2><1><default><default> [audio0] audio_used = 1 lineout_vol = 31 cap_vol = 5 audio_hp_ldo = "none" adcagc_used = 0 adcdrc_used = 0 dacdrc_used = 0 adchpf_used = 0 dachpf_used = 0 audio_pa_ctrl = port:PA16<1><default><default><0> [spdif0] spdif_used = 0 spdif_dout = port:PA17<2><1><default><default> [audiohub] hub_used = 0 codec_used = 1 spdif_used = 1 hdmi_used = 1 [s_cir0] ir_used = 1 ir_rx = port:PL11<2><1><default><default> ir_power_key_code0 = 87 ir_addr_code0 = 40704 ir_power_key_code1 = 26 ir_addr_code1 = 64260 ir_power_key_code2 = 20 ir_addr_code2 = 32640 ir_power_key_code3 = 21 ir_addr_code3 = 32640 ir_power_key_code4 = 11 ir_addr_code4 = 63240 ir_power_key_code5 = 3 ir_addr_code5 = 239 ir_power_key_code6 = 159 ir_addr_code6 = 19635 ir_power_key_code7 = 10 ir_addr_code7 = 30536 ir_power_key_code8 = 69 ir_addr_code8 = 48386 ir_power_key_code9 = 77 ir_addr_code9 = 56865 ir_power_key_code10 = 24 ir_addr_code10 = 65025 ir_power_key_code11 = 87 ir_addr_code11 = 65280 ir_power_key_code12 = 77 ir_addr_code12 = 65344 [cir] ir_used = 1 ir_tx = port:PH07<2><default><default><default> [dvfs_table] pmuic_type = 2 pmu_gpio0 = port:PL06<1><1><2><1> pmu_level0 = 11300 pmu_level1 = 1100 extremity_freq = 1296000000 max_freq = 1200000000 min_freq = 480000000 LV_count = 7 LV1_freq = 1296000000 LV1_volt = 1320 LV2_freq = 1200000000 LV2_volt = 1240 LV3_freq = 1104000000 LV3_volt = 1180 LV4_freq = 1008000000 LV4_volt = 1140 LV5_freq = 960000000 LV5_volt = 1080 LV6_freq = 816000000 LV6_volt = 1020 LV7_freq = 480000000 LV7_volt = 980 [gpu_dvfs_table] G_LV_count = 3 G_LV0_freq = 312000000 G_LV0_volt = 1200000 G_LV1_freq = 384000000 G_LV1_volt = 1200000 G_LV2_freq = 456000000 G_LV2_volt = 1200000 [Vdevice] Vdevice_used = 0 Vdevice_0 = port:PH10<5><1><2><default> Vdevice_1 = port:PH11<5><1><2><default> [s_uart0] s_uart_used = 0 s_uart_tx = port:PL02<2><default><default><default> s_uart_rx = port:PL03<2><default><default><default> [s_rsb0] s_rsb_used = 1 s_rsb_sck = port:PL00<2><1><2><default> s_rsb_sda = port:PL01<2><1><2><default> [s_jtag0] s_jtag_used = 0 s_jtag_tms = port:PL04<2><1><2><default> s_jtag_tck = port:PL05<2><1><2><default> s_jtag_tdo = port:PL06<2><1><2><default> s_jtag_tdi = port:PL07<2><1><2><default> [s_powchk] s_powchk_used = -2147483648 s_power_reg = 0 s_system_power = 50 [sim0] scr_used = 0 scr_vccen = port:PA06<2><default><default><default> scr_slk = port:PA07<2><default><default><default> scr_sda = port:PA08<2><default><default><default> scr_rst = port:PA09<2><default><default><default> scr_det = port:PA10<2><default><default><default> [ts0] tsc_used = 0 tsc_clk = port:PE00<3><default><default><default> tsc_err = port:PE01<3><default><default><default> tsc_sync = port:PE02<3><default><default><default> tsc_dvld = port:PE03<3><default><default><default> tsc_d0 = port:PE04<3><default><default><default> tsc_d1 = port:PE05<3><default><default><default> tsc_d2 = port:PE06<3><default><default><default> tsc_d3 = port:PE07<3><default><default><default> tsc_d4 = port:PE08<3><default><default><default> tsc_d5 = port:PE09<3><default><default><default> tsc_d6 = port:PE10<3><default><default><default> tsc_d7 = port:PE11<3><default><default><default> [gpio_power_key] key_used = 1 key_io = port:PL03<6><default><default><0> [key_para] key_used = 0 key_cnt = 5 key1_vol = 222 key2_vol = 444 key3_vol = 666 key4_vol = 857 key5_vol = 2000 [d7s_para] d7s_used = 0 din_gpio = port:PD00<1><default><default><1> clk_gpio = port:PD01<1><default><default><1> stb_gpio = port:PD02<1><default><default><1> [mali_para] mali_used = 1 mali_clkdiv = 1 mali_extreme_freq = 600 mali_extreme_vol = 1400 [w1_para] w1_used = 1 gpio = 20 [corekeeper] corekeeper_enabled = 1 And this is the output of `ls /dev/`. I believe there should be /dev/spi0.0 listed, but there isn't. Spoiler apm_bios audio audio1 autofs block bsg btrfs-control bus cachefiles cedar_dev char console cpu_dma_latency cuse disk disp dsp dsp1 fb0 fb1 fb2 fb3 fb4 fb5 fb6 fb7 fb8 fd full fuse hdmi i2c-0 i2c-1 initctl input ion kmsg log loop0 loop1 loop2 loop3 loop4 loop5 loop6 loop7 loop-control mapper mem misc_fatfs mmcblk0 mmcblk0p1 mqueue net network_latency network_throughput null ppp psaux ptmx pts ram0 ram1 ram2 ram3 ram4 ram5 ram6 ram7 random rfkill rtc rtc0 sda shm snd stderr stdin stdout sunxi-reg sunxi_soc_info tty tty0 tty1 tty10 tty11 tty12 tty13 tty14 tty15 tty16 tty17 tty18 tty19 tty2 tty20 tty21 tty22 tty23 tty24 tty25 tty26 tty27 tty28 tty29 tty3 tty30 tty31 tty32 tty33 tty34 tty35 tty36 tty37 tty38 tty39 tty4 tty40 tty41 tty42 tty43 tty44 tty45 tty46 tty47 tty48 tty49 tty5 tty50 tty51 tty52 tty53 tty54 tty55 tty56 tty57 tty58 tty59 tty6 tty60 tty61 tty62 tty63 tty7 tty8 tty9 ttyS0 tv uhid uinput urandom usbdev1.1 usbdev2.1 usbdev3.1 usbdev4.1 usbdev4.3 usbdev5.1 usbdev6.1 usbdev7.1 usbdev8.1 vcs vcs1 vcs2 vcs3 vcs4 vcs5 vcs6 vcs7 vcsa vcsa1 vcsa2 vcsa3 vcsa4 vcsa5 vcsa6 vcsa7 vmouse watchdog xconsole zero I believe that is all. If I forgot to add some info please tell me and I'll try to get it right away. Thanks in advance for your attention.
chwe Posted April 22, 2018 Posted April 22, 2018 19 minutes ago, GusAntoniassi said: Currently installed image is: Armbian_5.35_Orangepipc_Debian_jessie_default_3.4.113. is not mainline.. that's the old legacy kernel. you might need to know which driver is needed for your display.. and which touchdriver... 1
GusAntoniassi Posted April 23, 2018 Author Posted April 23, 2018 5 hours ago, chwe said: is not mainline.. that's the old legacy kernel. you might need to know which driver is needed for your display.. and which touchdriver... Isn't legacy Armbian_5.38_Orangepipc_Ubuntu_xenial_default_3.4.113_desktop ? That's what I got from the download page. In the box where the display came in there is a label that says "Driver: ILI9486", but from what I've seen this is a waveshare 3.5" display clone, and apparently it works with ADS7846 touch screen driver. The display itself worked with no problems by just configuring fbtft.
chwe Posted April 23, 2018 Posted April 23, 2018 14 hours ago, GusAntoniassi said: Armbian_5.38_Orangepipc_Ubuntu_xenial_default_3.4.113_desktop is based on Allwinners BSP kernel and therefore not mainline. Images based on mainline kernel is for example the right on the downloapage (Debian server – mainline kernel) or the ones under the 'other download options and archive' section called next or dev (whereas the nightly images are mostly untested and therefore only recommended for testing and not production use-cases). You might change the topic name as long as you use a legacy image. from the tutorials you linked to: Quote Legacy Kernel [You can only EITHER use touch or LCD due to issues with spi chip select] I don't know if this statement is still correct or if there's a workaround for it but can this be an issue? The second tutorial you linked is about a HDMI display and from what I saw, yours is a SPI one so this tutorial might be not that useful for you. From what I saw you need to proper defined CS pins (one for the touchscreen one for the display). Are you sure that those pins are properly defined? It's more a generic answer since I haven't this display to test it. Maybe @yam1 a bit more precise can help you, since he did a lot of display stuff : 1
GusAntoniassi Posted April 24, 2018 Author Posted April 24, 2018 Hey chwe, thanks for the replies! I will give Debian_stretch_next a try then when I have a little spare time. Just so I can understand, both Debian_stretch_next and Debian_stretch_next_desktop are mainline, the only difference being the GUI? I was under the impression that GUI images were legacy and CLI images were mainline. I'll post the results as soon as I have something!
chwe Posted April 24, 2018 Posted April 24, 2018 22 minutes ago, GusAntoniassi said: I was under the impression that GUI images were legacy and CLI images were mainline. okay, I try to explain the situation a little bit.. Armbian has 3 different kernels for most SBCs we provide images. Legacy (which is for the H3 board the 3.4.113 BSP kernel), next (kernel from kernel.org currently pinned to 4.14.y) and dev (kernel from kernel.org currently pinned to 4.16.y). On the normal downloadpage the maintainers provide images which are suggested for a different use-case. One of the main reasons why we suggest the legacy kernel for desktop usage is that it has hardware acceleration (e.g. when you use the MPV player, videodecoding happens on the VPU not CPU). In case you only use CLI and no desktop, video acceleration is mostly of minor interest therefore a more recent kernel might be more important than hardware acceleration therefore we often suggest to use the mainline kernel. For example the 3.4 kernel is to old to build debian stretch images, but with the mainline kernel stretch images are possible (and you get the newer packages of some libraries provided by debian stretch). 3.4 Kernel is EOL since a while and doesn't get updates anymore whereas 4.14 should get update at least until 2020. As soon as hardware acceleration is possible with the mainline kernel (see Bootlin mainlining the VPU), legacy images based on Allwinners BSP kernel might get dropped and Armbian will only provide images based on mainline. The reason why there are also legacy CLI images available is due to hardware which do not work at the moment (e.g. the camera interface is not supported by mainline yet). You can also use mainline images with a desktop but you won't have any hardware accelerated videodecoding capabilities and therefore playing videos will be painful, and might only work on low resolution if at all. If you download a mainline image you get this warnig: Cause we can't test everything for all the boards and every use-case armbian users think about, there might be bugs which we didn't found or which are not solved yet. The BSP kernel is better known and therefore devs know most of it's limitations. For mainline, we rely mostly on upstream plus a 'few' (for Sunxi boards this means ~100 ) patches to fix things which aren't mainlined (yet). With every kernelupdate those patches can break things or can get obsolete cause they're no longer needed, you can imaging that this can't be tested for every board and every use case (e.g only for H3, we provide stable images for 15 different boards). Depending on what you want to do on your display, you might not need hardware acceleration that much and mainline is fine for you. Test it and find out if it works well for you. 1
GusAntoniassi Posted May 2, 2018 Author Posted May 2, 2018 Hey @chwe, thanks for the detailed answer! I was having a hard time trying to understand the difference between mainlike and kernel, with their desktop / cli versions, but you explained it very clearly. I managed to get the display working after a while. I've detailed my steps in this thread. Thanks a lot for your help and attention!
