spierepf Posted May 4, 2018 Posted May 4, 2018 I am having some difficulty producing audio on an orangepi zero using the images listed here: https://www.armbian.com/orange-pi-zero/ No matter what I do, I cannot get any audio devices to show up in /proc/asound/cards There are a number of posts on here that suggest that audio doesn't work on version 4.x kernels. Is this still the case? And if so, where can I download an armbian image that does support audio?
Igor Posted May 4, 2018 Posted May 4, 2018 1 hour ago, spierepf said: And if so, where can I download an armbian image that does support audio? AFAIK audio is disabled on those boards by default. You need to enable it. With modern kernel, you can use armbian-config -> system -> hardware. Enable, save and reboot.
