1 1
Technicavolous
HC1 - Size of file not what server reported
W: Size of file /var/lib/apt/lists/apt.armbian.com_dists_jessie_jessie-utils_binary-armhf_Packages.gz is not what the server reported 5780 5784
W: Size of file /var/lib/apt/lists/httpredir.debian.org_debian_dists_jessie-backports_main_binary-armhf_Packages.gz is not what the server reported 1122303 1123712
Get this when first doing apt update after fresh install. HC1 Jesse.
I assumed at first it was network error, but this is consistent. Have downloaded and checksummed successful. Assumed then it was the SD card, replaced and have now tried several. Power supply is solid. I believe the hardware and bandwidth / router are fine.
Simply repeat apt update and everything appears to go well.
Did it ignore the erroneous entry or get a proper one??
armbianmonitor -u output
http://ix.io/19Nz
Share this post
Link to post
Share on other sites
I have the same issue for ODroid HC1 (ARMBIAN 5.60 stable Debian GNU/Linux 8 (jessie) 4.14.69-odroidxu4
W: Size of file /var/lib/apt/lists/apt.armbian.com_dists_jessie_jessie-desktop_binary-armhf_Packages.gz is not what the server reported 19879 19884
Just noticed that the packedge name changes time to time.
Have you found any solution?
Thanks,
Pavel
Share this post
Link to post
1 1
