Christian_ Posted May 13, 2018 Posted May 13, 2018 Hello. Please could someone help me to solve this issue? I have a wifi dongle recognized as: Bus 002 Device 002: ID 148f:5572 Ralink Technology, Corp. RT5572 Wireless Adapter I am trying to use it on my Rock64 and ARMBIAN 5.42 testing Debian GNU/Linux 9 (stretch) 4.4.124-rk3328 uname -a: Linux rock64 4.4.124-rk3328 #24 SMP Wed Mar 28 17:15:52 CEST 2018 aarch64 GNU/Linux It seems it is recognized correctly: Spoiler lsmod: rt2800usb 28672 0 rt2800lib 81920 1 rt2800usb rt2x00usb 20480 1 rt2800usb rt2x00lib 49152 3 rt2x00usb,rt2800lib,rt2800usb dmesg: [ 14.576374] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5592, rev 0222 detected [ 14.606007] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 000f detected [ 14.607477] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht' [ 14.610153] systemd[1]: Starting Load/Save RF Kill Switch Status... [ 14.611640] usbcore: registered new interface driver rt2800usb ... [ 14.657918] rt2800usb 2-1:1.0 wlx441ca87f7a19: renamed from wlan0 ... [ 17.964407] IPv6: ADDRCONF(NETDEV_UP): wlx441ca87f7a19: link is not ready [ 17.964729] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin' [ 17.992211] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.36 [ 18.346244] IPv6: ADDRCONF(NETDEV_UP): wlx441ca87f7a19: link is not ready Using Network Manager had no luck, the device was always listed as disconnected. So I tried to configure it manually in /etc/network/interfaces, adding this entry: auto wlx441ca87f7a19 iface wlx441ca87f7a19 inet dhcp wpa-ssid mySSID wpa-psk [key removed] Still no luck, this is the log of networking service: Spoiler mag 13 15:07:43 rock64 systemd[1]: Starting Raise network interfaces... mag 13 15:07:44 rock64 wpa_supplicant[4717]: Successfully initialized wpa_supplicant mag 13 15:07:45 rock64 dhclient[4732]: Internet Systems Consortium DHCP Client 4.3.5 mag 13 15:07:45 rock64 dhclient[4732]: Copyright 2004-2016 Internet Systems Consortium. mag 13 15:07:45 rock64 ifup[4683]: Internet Systems Consortium DHCP Client 4.3.5 mag 13 15:07:45 rock64 ifup[4683]: Copyright 2004-2016 Internet Systems Consortium. mag 13 15:07:45 rock64 ifup[4683]: All rights reserved. mag 13 15:07:45 rock64 ifup[4683]: For info, please visit https://www.isc.org/software/dhcp/ mag 13 15:07:45 rock64 dhclient[4732]: All rights reserved. mag 13 15:07:45 rock64 dhclient[4732]: For info, please visit https://www.isc.org/software/dhcp/ mag 13 15:07:45 rock64 dhclient[4732]: mag 13 15:07:45 rock64 dhclient[4732]: Listening on LPF/wlx441ca87f7a19/44:1c:a8:7f:7a:19 mag 13 15:07:45 rock64 dhclient[4732]: Sending on LPF/wlx441ca87f7a19/44:1c:a8:7f:7a:19 mag 13 15:07:45 rock64 ifup[4683]: Listening on LPF/wlx441ca87f7a19/44:1c:a8:7f:7a:19 mag 13 15:07:45 rock64 ifup[4683]: Sending on LPF/wlx441ca87f7a19/44:1c:a8:7f:7a:19 mag 13 15:07:45 rock64 ifup[4683]: Sending on Socket/fallback mag 13 15:07:45 rock64 ifup[4683]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 6 mag 13 15:07:45 rock64 dhclient[4732]: Sending on Socket/fallback mag 13 15:07:45 rock64 dhclient[4732]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 6 mag 13 15:07:51 rock64 dhclient[4732]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 14 mag 13 15:07:51 rock64 ifup[4683]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 14 mag 13 15:08:05 rock64 dhclient[4732]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 13 mag 13 15:08:05 rock64 ifup[4683]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 13 mag 13 15:08:18 rock64 dhclient[4732]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 15 mag 13 15:08:18 rock64 ifup[4683]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 15 mag 13 15:08:33 rock64 dhclient[4732]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 8 mag 13 15:08:33 rock64 ifup[4683]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 8 mag 13 15:08:41 rock64 dhclient[4732]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 5 mag 13 15:08:41 rock64 ifup[4683]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 5 mag 13 15:08:46 rock64 dhclient[4732]: No DHCPOFFERS received. mag 13 15:08:46 rock64 dhclient[4732]: No working leases in persistent database - sleeping. mag 13 15:08:46 rock64 ifup[4683]: No DHCPOFFERS received. mag 13 15:08:46 rock64 ifup[4683]: No working leases in persistent database - sleeping. mag 13 15:08:46 rock64 avahi-autoipd(wlx441ca87f7a19)[4798]: Found user 'avahi-autoipd' (UID 105) and group 'avahi-autoipd' (GID 109 mag 13 15:08:46 rock64 avahi-autoipd(wlx441ca87f7a19)[4798]: Successfully called chroot(). mag 13 15:08:46 rock64 avahi-autoipd(wlx441ca87f7a19)[4798]: Successfully dropped root privileges. mag 13 15:08:46 rock64 avahi-autoipd(wlx441ca87f7a19)[4798]: Starting with address 169.254.6.79 mag 13 15:08:51 rock64 avahi-autoipd(wlx441ca87f7a19)[4798]: Callout BIND, address 169.254.6.79 on interface wlx441ca87f7a19 mag 13 15:08:51 rock64 avahi-autoipd(wlx441ca87f7a19)[4799]: client: RTNETLINK answers: Numerical result out of range mag 13 15:08:51 rock64 avahi-autoipd(wlx441ca87f7a19)[4799]: Script execution failed with return value 2 mag 13 15:08:55 rock64 avahi-autoipd(wlx441ca87f7a19)[4798]: Successfully claimed IP address 169.254.6.79 mag 13 15:08:56 rock64 systemd[1]: Started Raise network interfaces. I also tried to add: options rt2800usb nohwcrypt=y in /etc/modprobe.d/rt2800usb.conf, as I read somewhere and removed and reloaded the modules, no change Trying the scan manually I get no results: wlx441ca87f7a19 IEEE 802.11abgn ESSID:off/any Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm Retry short limit:7 RTS thr:off Fragment thr:off Encryption key:off Power Management:off sudo iwlist wlx441ca87f7a19 scan wlx441ca87f7a19 No scan results I also connected the module to my laptop (running Ubuntu 17.10) to be sure it works, and from there I can connect to my wifi just fine (using Network Manager). I also can connect to wifi using another usb adapter (Realtek 8188EU USB) on Rock64 with Network Manager. Any idea? Thanks in advance.
Igor Posted May 13, 2018 Posted May 13, 2018 31 minutes ago, Christian_ said: Any idea? Blacklist in-kernel driver and search around for more recent known to work drivers (sources), install headers and compile the module. Repeat until you find a working one. When you find a good working one, we can once replace them with those shipped with the kernel. Ideally: send a patch against kernel source.
Christian_ Posted May 15, 2018 Author Posted May 15, 2018 The problem was the wifi region setting unset, this prevented to tune the radio to channel 1. 1
