Hello there!
Maybe mine is a bit of a newbie question so I'll drop it here:
My cubox is set as an access point using an Edimax EW7822UAC dongle although it is only in AC mode. Is there a way to set it to run also as a N ap or it requires another usb dongle?
Thank you guys
Yes. No other way.
8 minutes ago, Igor said:
Yes. No other way.
A reply from the boss himself, I'm honoured.
Ok I'll give it a shot as soon as possible and share my experience, thank you!
Don't worry. It works :)
You only need to run hostapd with multiple configuration files.
So... I "yolo'ed" it a little bit, in a nutshell this is what I did:
Copied the current /etc/hostpad.conf to /etc/hostpadAC.conf
Shutdown the machine
Disconnected the current AC dongle and connected the N one in the other usb port
remade the hostpad.conf using armbian-config
edited /etc/default/hostpad to include both config files like this ---> DAEMON_CONF="/etc/hostapd.conf /etc/hostapdAC.conf"
edited /etc/init.d/hostpad to include both config files like this ---> DAEMON_CONF="/etc/hostapd.conf /etc/hostapdAC.conf"
Both access points are here but only the N one works, the AC one gets stuck at "gathering ip address" on my smartphone.
What this noob (me) did wrong? What is missing?
