MasterControl90 Posted May 21, 2018 Share Posted May 21, 2018 Hello there! Maybe mine is a bit of a newbie question so I'll drop it here: My cubox is set as an access point using an Edimax EW7822UAC dongle although it is only in AC mode. Is there a way to set it to run also as a N ap or it requires another usb dongle? Thank you guys Link to comment Share on other sites More sharing options...
Igor Posted May 21, 2018 Share Posted May 21, 2018 2 minutes ago, MasterControl90 said: or it requires another usb dongle Yes. No other way. Link to comment Share on other sites More sharing options...
MasterControl90 Posted May 21, 2018 Author Share Posted May 21, 2018 8 minutes ago, Igor said: Yes. No other way. A reply from the boss himself, I'm honoured. Ok I'll give it a shot as soon as possible and share my experience, thank you! Link to comment Share on other sites More sharing options...
Igor Posted May 21, 2018 Share Posted May 21, 2018 Don't worry. It works You only need to run hostapd with multiple configuration files. Link to comment Share on other sites More sharing options...
MasterControl90 Posted May 21, 2018 Author Share Posted May 21, 2018 9 hours ago, Igor said: Don't worry. It works You only need to run hostapd with multiple configuration files. So... I "yolo'ed" it a little bit, in a nutshell this is what I did: Copied the current /etc/hostpad.conf to /etc/hostpadAC.conf Shutdown the machine Disconnected the current AC dongle and connected the N one in the other usb port remade the hostpad.conf using armbian-config edited /etc/default/hostpad to include both config files like this ---> DAEMON_CONF="/etc/hostapd.conf /etc/hostapdAC.conf" edited /etc/init.d/hostpad to include both config files like this ---> DAEMON_CONF="/etc/hostapd.conf /etc/hostapdAC.conf" Both access points are here but only the N one works, the AC one gets stuck at "gathering ip address" on my smartphone. What this noob (me) did wrong? What is missing? Link to comment Share on other sites More sharing options...
