I have a nanopi duo and i want to use it usb to communicate with my quadcopter crazyflie .
But when i connecting them , duo has no response for crazyflie.
crazyflie usb with computer(ubuntu16.04)
Bus 002 Device 002: ID 8087:8000 Intel Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:8008 Intel Corp.
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 007: ID 0bda:b002 Realtek Semiconductor Corp.
Bus 003 Device 108: ID 0483:5740 STMicroelectronics STM32F407
Bus 003 Device 104: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 003 Device 107: ID 1c4f:0002 SiGma Micro Keyboard TRACER Gamma Ivory
the computer can find STM.
I have tried duo micro usb and dm2 dp2 dm3 dp3 pin . But it also can't find STM.
I'm a new man for linux. I need help .
Thank you very much!
Edited by zador.blood.stained
Moved and renamed
Connecting via powered USB hub? Is there anything in the log (dmesg) at the moment you plug it to the USB?
also can't find anything change.
with no crazyfle
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.11.2 (root@wwd) (gcc version 4.9.3 (ctng-1.21.0-229g-FA) ) #163 SMP Mon Nov 13 14:05:49 CST 2017
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: FriendlyElec NanoPi-Duo
[    0.000000] cma: Reserved 16 MiB at 0x5ec00000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 131072
[    0.000000] free_area_init_node: node 0, pgdat c0b5ae80, node_mem_map de800000
[    0.000000]   Normal zone: 1024 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 131072 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: Using PSCI v0.1 Function IDs from DT
[    0.000000] percpu: Embedded 16 pages/cpu @dff60000 s33152 r8192 d24192 u65536
[    0.000000] pcpu-alloc: s33152 r8192 d24192 u65536 alloc=16*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
[    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rootfstype=ext4 rw rootwait fsck.repair=yes panic=10 fbcon=map:0
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 486956K/524288K available (7168K kernel code, 366K rwdata, 1584K rodata, 1024K init, 288K bss, 20948K reserved, 16384K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
                   lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
                   pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                   modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                     .text : 0xc0008000 - 0xc0800000   (8160 kB)
                     .init : 0xc0a00000 - 0xc0b00000   (1024 kB)
                     .data : 0xc0b00000 - 0xc0b5ba80   ( 367 kB)
                      .bss : 0xc0b5d000 - 0xc0ba5060   ( 289 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 32.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=4
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000018] Switching to timer-based delay loop, resolution 41ns
[    0.000189] Console: colour dummy device 80x30
[    0.000219] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000234] pid_max: default: 32768 minimum: 301
[    0.000355] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000365] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000923] CPU: Testing write buffer coherency: ok
[    0.001306] CPU0: update cpu_capacity 1024
[    0.001319] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.001633] Setting up static identity map for 0x40100000 - 0x40100058
[    0.002238] smp: Bringing up secondary CPUs ...
[    0.012904] CPU1: update cpu_capacity 1024
[    0.012910] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.023609] CPU2: update cpu_capacity 1024
[    0.023614] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.034287] CPU3: update cpu_capacity 1024
[    0.034292] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.034347] smp: Brought up 1 node, 4 CPUs
[    0.034374] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.034380] CPU: All CPU(s) started in HYP mode.
[    0.034385] CPU: Virtualization extensions available.
[    0.035131] devtmpfs: initialized
[    0.040330] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.040559] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.040579] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.041321] pinctrl core: initialized pinctrl subsystem
[    0.042295] NET: Registered protocol family 16
[    0.043673] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.044948] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.044960] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.060134] gpio-regulator gpio-regulator: could not find pctldev for node /soc/pinctrl@01f02c00/regulator_pins@0, deferring probe
[    0.060458] SCSI subsystem initialized
[    0.060695] libata version 3.00 loaded.
[    0.060944] usbcore: registered new interface driver usbfs
[    0.061002] usbcore: registered new interface driver hub
[    0.061062] usbcore: registered new device driver usb
[    0.061259] pps_core: LinuxPPS API ver. 1 registered
[    0.061266] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.061287] PTP clock support registered
[    0.061506] Advanced Linux Sound Architecture Driver Initialized.
[    0.063039] clocksource: Switched to clocksource arch_sys_counter
[    0.063141] VFS: Disk quotas dquot_6.6.0
[    0.063211] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.071597] NET: Registered protocol family 2
[    0.072225] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.072280] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[    0.072343] TCP: Hash tables configured (established 4096 bind 4096)
[    0.072437] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.072479] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.072674] NET: Registered protocol family 1
[    0.073097] RPC: Registered named UNIX socket transport module.
[    0.073109] RPC: Registered udp transport module.
[    0.073115] RPC: Registered tcp transport module.
[    0.073120] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.073406] Unpacking initramfs...
[    0.223500] Initramfs unpacking failed: junk in compressed archive
[    0.228336] Freeing initrd memory: 5120K
[    0.230350] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[    0.238962] NFS: Registering the id_resolver key type
[    0.239003] Key type id_resolver registered
[    0.239010] Key type id_legacy registered
[    0.239026] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.239033] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.240069] fuse init (API version 7.26)
[    0.243797] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.243811] io scheduler noop registered
[    0.243818] io scheduler deadline registered
[    0.243985] io scheduler cfq registered (default)
[    0.243994] io scheduler mq-deadline registered
[    0.249362] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.251151] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[    0.305347] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.308226] console [ttyS0] disabled
[    0.328396] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 44, base_baud = 1500000) is a U6_16550A
[    0.999855] console [ttyS0] enabled
[    1.026298] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 45, base_baud = 1500000) is a U6_16550A
[    1.037427] sun8i-de2 1000000.de-controller: bound 1c0c000.lcd-controller (ops 0xc0843758)
[    1.203081] sun8i-de2 1000000.de-controller: bound 1ee0000.hdmi (ops 0xc0843a24)
[    1.210472] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.217096] [drm] No driver support for vblank timestamp query.
[    1.223060] [drm] Cannot find any crtc or sizes - going 1920x1080
[    1.263434] Console: switching to colour frame buffer device 240x67
[    1.295681] sun8i-de2 1000000.de-controller: fb0:  frame buffer device
[    1.302599] [drm] Initialized sun8i-de2 1.0.0 20161101 for 1000000.de-controller on minor 0
[    1.314397] libphy: Fixed MDIO Bus: probed
[    1.318504] CAN device driver interface
[    1.323723] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.330247] ehci-platform: EHCI generic platform driver
[    1.335651] ehci-platform 1c1a000.usb: EHCI Host Controller
[    1.341257] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    1.349358] ehci-platform 1c1a000.usb: irq 27, io mem 0x01c1a000
[    1.383043] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    1.389960] hub 1-0:1.0: USB hub found
[    1.393774] hub 1-0:1.0: 1 port detected
[    1.398196] ehci-platform 1c1b000.usb: EHCI Host Controller
[    1.403803] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 2
[    1.411794] ehci-platform 1c1b000.usb: irq 29, io mem 0x01c1b000
[    1.443071] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
[    1.449874] hub 2-0:1.0: USB hub found
[    1.453666] hub 2-0:1.0: 1 port detected
[    1.458056] ehci-platform 1c1c000.usb: EHCI Host Controller
[    1.463661] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 3
[    1.471616] ehci-platform 1c1c000.usb: irq 31, io mem 0x01c1c000
[    1.505398] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[    1.512199] hub 3-0:1.0: USB hub found
[    1.515989] hub 3-0:1.0: 1 port detected
[    1.520372] ehci-platform 1c1d000.usb: EHCI Host Controller
[    1.525976] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 4
[    1.533986] ehci-platform 1c1d000.usb: irq 33, io mem 0x01c1d000
[    1.563833] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
[    1.570646] hub 4-0:1.0: USB hub found
[    1.574438] hub 4-0:1.0: 1 port detected
[    1.578788] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.584992] ohci-platform: OHCI generic platform driver
[    1.590408] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    1.597054] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 5
[    1.604982] ohci-platform 1c1a400.usb: irq 28, io mem 0x01c1a400
[    1.677687] hub 5-0:1.0: USB hub found
[    1.681479] hub 5-0:1.0: 1 port detected
[    1.686382] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
[    1.693033] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
[    1.700937] ohci-platform 1c1b400.usb: irq 30, io mem 0x01c1b400
[    1.777650] hub 6-0:1.0: USB hub found
[    1.781428] hub 6-0:1.0: 1 port detected
[    1.785778] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[    1.792402] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
[    1.800424] ohci-platform 1c1c400.usb: irq 32, io mem 0x01c1c400
[    1.877670] hub 7-0:1.0: USB hub found
[    1.881448] hub 7-0:1.0: 1 port detected
[    1.885782] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
[    1.892405] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
[    1.900412] ohci-platform 1c1d400.usb: irq 34, io mem 0x01c1d400
[    1.977667] hub 8-0:1.0: USB hub found
[    1.981443] hub 8-0:1.0: 1 port detected
[    1.985933] usbcore: registered new interface driver usb-storage
[    1.992367] mousedev: PS/2 mouse device common for all mice
[    1.998387] ads7846 spi0.1: spi0.1 supply vcc not found, using dummy regulator
[    2.006014] ads7846 spi0.1: touchscreen, irq 91
[    2.011105] input: ADS7846 Touchscreen as /devices/platform/soc/1c68000.spi/spi_master/spi0/spi0.1/input/input0
[    2.022075] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0
[    2.028876] sun6i-rtc 1f00000.rtc: RTC enabled
[    2.033482] i2c /dev entries driver
[    2.038248] thermal thermal_zone0: failed to read out thermal zone (-16)
[    2.045457] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    2.054830] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    2.113053] sunxi-mmc 1c0f000.mmc: base:0xe0871000 irq:25
[    2.120273] usbcore: registered new interface driver usbhid
[    2.125904] usbhid: USB HID core driver
[    2.129796] fbtft_of_value: buswidth = 8
[    2.133736] fbtft_of_value: debug = 0
[    2.137394] fbtft_of_value: rotate = 90
[    2.141224] fbtft_of_value: fps = 33
[    2.266491] random: fast init done
[    2.295974] graphics fb1: fb_st7789v frame buffer, 320x240, 150 KiB video memory, 4 KiB buffer memory, fps=33, spi0.0 at 50 MHz
[    2.308912] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01f015c0 not registered
[    2.316860] sun4i-codec 1c22c00.codec: Failed to register our card
[    2.320403] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.322294] mmc0: Problem switching card into high-speed mode!
[    2.322401] mmc0: new SDHC card at address 0001
[    2.322965] mmcblk0: mmc0:0001 SD16G 14.6 GiB
[    2.324594]  mmcblk0: p1 p2
[    2.349593] Initializing XFRM netlink socket
[    2.353912] NET: Registered protocol family 17
[    2.358371] can: controller area network core (rev 20120528 abi 9)
[    2.364623] NET: Registered protocol family 29
[    2.369063] can: raw protocol (rev 20120528)
[    2.373347] can: broadcast manager protocol (rev 20161123 t)
[    2.379005] can: netlink gateway (rev 20130117) max_hops=1
[    2.384881] Key type dns_resolver registered
[    2.389335] Registering SWP/SWPB emulation handler
[    2.400794] thermal thermal_zone0: failed to read out thermal zone (-16)
[    2.408841] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
[    2.633045] sunxi-mmc 1c10000.mmc: base:0xe0ca8000 irq:26
[    2.640571] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    2.649702] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01 00:00:08 UTC (8)
[    2.657948] vcc3v0: disabling
[    2.660919] vcc5v0: disabling
[    2.663913] ALSA device list:
[    2.666877]   #0: H3 Audio Codec
[    2.673813] Freeing unused kernel memory: 1024K
[    2.688914] mmc2: new high speed SDIO card at address 0001
[    4.483251] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    4.503432] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[    5.035881] systemd[1]: System time before build time, advancing clock.
[    5.175769] NET: Registered protocol family 10
[    5.220366] Segment Routing with IPv6
[    5.280348] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[    5.298874] systemd[1]: Detected architecture arm.
[    5.344620] systemd[1]: Set hostname to <NanoPi-Duo>.
[    5.808612] systemd[1]: Reached target Remote File Systems (Pre).
[    5.843216] systemd[1]: Reached target Remote File Systems.
[    5.873145] systemd[1]: Reached target Swap.
[    5.903292] systemd[1]: Listening on udev Kernel Socket.
[    5.933381] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    5.973308] systemd[1]: Listening on Journal Socket (/dev/log).
[    6.003191] systemd[1]: Reached target Encrypted Volumes.
[    6.602900] udc-core: couldn't find an available UDC - added [g_mass_storage] to list of pending drivers
[    7.855232] systemd-journald[184]: Received request to flush runtime journal from PID 1
[    9.011765] xradio_wlan: loading out-of-tree module taints kernel.
[    9.443121] random: crng init done
[    9.838508] xradio_wlan mmc2:0001:1:    Input buffers: 30 x 1632 bytes
                  Hardware: 7.9
                  WSM firmware ver: 8, build: 43, api: 1060, cap: 0x0003
[    9.838538] xradio_wlan mmc2:0001:1: Firmware Label:XR_C01.08.0043 Jun  6 2016 20:41:04
[    9.861436] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[    9.868318] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   15.169697] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   15.170604] ieee80211 phy0: Interface ID:0 of type:2 added
[   15.171371] ieee80211 phy0: vif 0, configuring tx
[   15.171863] ieee80211 phy0: vif 0, configuring tx
[   15.172345] ieee80211 phy0: vif 0, configuring tx
[   15.172750] ieee80211 phy0: vif 0, configuring tx
[   15.173301] ieee80211 phy0: ignore IEEE80211_CONF_CHANGE_MONITOR (1)IEEE80211_CONF_CHANGE_IDLE (1)
[   15.173518] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   15.253783] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   15.264406] sun8i-emac 1c30000.ethernet: EMAC reset timeout
[   15.374324] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   15.410544] libphy: 1c30000.ethernet: probed
[   15.426966] Generic PHY 1c30000.ethernet-0:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=1c30000.ethernet-0:01, irq=-1)
[   15.426997] sun8i-emac 1c30000.ethernet: device MAC address slot 0 02:42:e3:0a:49:aa
[   15.430165] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[   15.430204] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   15.702284] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   15.733175] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[   15.733201] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[   15.733528] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[   15.733546] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[   15.733559] sun8i-emac 1c30000.ethernet: device MAC address slot 3 33:33:ff:63:eb:70
[   15.936798] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   17.697095] wlan0: authenticate with 02:1a:11:fc:7d:7a
[   17.697186] ieee80211 phy0: ignore IEEE80211_CONF_CHANGE_MONITOR (0)IEEE80211_CONF_CHANGE_IDLE (1)
[   17.697205] ieee80211 phy0: Freq 2412 (wsm ch: 1).
[   17.697665] wlan0: send auth to 02:1a:11:fc:7d:7a (try 1/3)
[   17.929685] wlan0: authenticated
[   17.933112] wlan0: associate with 02:1a:11:fc:7d:7a (try 1/3)
[   17.937914] wlan0: RX AssocResp from 02:1a:11:fc:7d:7a (capab=0x411 status=0 aid=2)
[   17.938023] ieee80211 phy0: vif 0, configuring tx
[   17.938629] ieee80211 phy0: vif 0, configuring tx
[   17.939228] ieee80211 phy0: vif 0, configuring tx
[   17.939806] ieee80211 phy0: vif 0, configuring tx
[   17.943178] wlan0: associated
[   17.943394] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   18.007352] ieee80211 phy0: CCMP_PAIRWISE keylen=16!
[   57.884915] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[   57.884939] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[   57.885003] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[   57.885131] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   57.930165] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[   57.952064] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   57.953761] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[   57.953785] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[   57.954146] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[   57.954163] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[   57.954176] sun8i-emac 1c30000.ethernet: device MAC address slot 3 33:33:ff:63:eb:70
[  103.074091] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  103.074116] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[  103.074177] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  103.074385] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  103.125720] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  103.147236] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  103.148467] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  103.148487] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[  103.148818] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  103.148834] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[  103.148847] sun8i-emac 1c30000.ethernet: device MAC address slot 3 33:33:ff:63:eb:70
use micro usb
                  Hardware: 7.9
[  148.096746] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  148.096820] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[  148.097015] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  148.097430] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  148.257475] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  148.324074] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  148.328497] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  148.328565] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[  148.329476] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  148.329537] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[  148.329587] sun8i-emac 1c30000.ethernet: device MAC address slot 3 33:33:ff:63:eb:70
[  194.028577] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  194.028655] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[  194.028848] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  194.029261] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  493.962924] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  494.030301] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  494.034183] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  494.034248] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[  494.035106] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  494.035167] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[  494.035217] sun8i-emac 1c30000.ethernet: device MAC address slot 3 33:33:ff:63:eb:70
[  538.827400] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  538.827477] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[  538.827669] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  538.828085] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  538.989977] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  539.057730] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  539.061552] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  539.061620] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[  539.062505] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  539.062565] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[  539.062616] sun8i-emac 1c30000.ethernet: device MAC address slot 3 33:33:ff:63:eb:70
[  584.402529] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  584.402605] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[  584.402801] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  584.403220] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  584.590328] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  584.657029] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  584.660910] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  584.660979] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[  584.662728] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  584.662792] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[  584.662842] sun8i-emac 1c30000.ethernet: device MAC address slot 3 33:33:ff:63:eb:70
[  630.669517] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  630.669559] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[  630.669662] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  630.670306] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  630.752681] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  630.791855] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  630.794159] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  630.794219] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[  630.795152] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[  630.795186] sun8i-emac 1c30000.ethernet: device MAC address slot 2 33:33:00:00:00:01
[  630.795212] sun8i-emac 1c30000.ethernet: device MAC address slot 3 33:33:ff:63:eb:70
[  641.302369] xradio_wlan mmc2:0001:1: missed interrupt
I think maybe i need some settings with pi?
What about downloading Armbian image and check if it is working there?
