Hello, everybody
I have a task to make "easy install image" to orange pi pc2.
I build already Armbian_5.46_Orangepipc2_Ubuntu_xenial_next_4.14.47_desctop.img and its actualy what i need and now I need to make it "easy install"  - becouse we have a lot of SD card to burning.
Could you recommend me, how to:
1. Scip first boot user creation. (Armbian on the first boot ask to set the new root password and create new user). Can i preinstalled this information? I need that Armbian on first boot just load without some user inputs.
2. Add my program to start up. I have a A ) zip with my program and B ) bash script which unzip program and set it lunch on startup. If i understand correctly - I must do this: "put my zip in userpatches/overlay and access them in /tmp/overlay from customize-image.sh - and here (customize-image.sh) lunch my bash script?
Ideally, I need make Armbian image that I just put in Orange pi pc2 device - and it just start up and lunch my program.
Thank you
On 6/4/2018 at 3:33 PM, Igor said:
Take a look at this example:
https://github.com/igorpecovnik/iot
I did like in this example and get one trouble:
On the first boot system ask my login and password, I successfully authenticated and stay in console. desktop environment dose not start!, but I use parameter BUILD_DESKTOP="yes"
What me to do to start desktop on boot?
if I login by root - system ask me to create normal user and after it desktop environment is start.
but if i login by user, which I add in customize-image.sh, I stay in console and desktop environment dose not start
If you can't work out with those tips, I can only point you to hire help or dig in. Your problems are generic and are not covered by free https://www.armbian.com/donate/ technical support.
I modified /etc/default/nodm in customize-image.sh and its help me
in /etc/default/nodm I set:
NODM_ENABLES = true
NODM_USER = $MY_USER
And now my user autologin on first boot without any input!
