mrroland Posted June 6, 2018 Posted June 6, 2018 Hi Guys, I tested both the odroid official and armbian images for the XU4. Both run well, but I prefer the armbian image. I have attached my 800x480 hdmi display, it works, but there's a purple line at the left side of the display. ( I think it's one pixel wide) This is not the case with the odroid official image, so I guess it's a configuration issue. I took a look at the boot. ini file, but I don't see anything that rings a bell. Can somebody point me to the right direction?
JMCC Posted June 6, 2018 Posted June 6, 2018 Most probably a display refresh rate issue. Try to play with xrandr to set different rates. More info here: https://wiki.archlinux.org/index.php/xrandr#Troubleshooting
JMCC Posted June 6, 2018 Posted June 6, 2018 Another possibility is that you use the accelerated display driver, as the official image does (though ours is a little different). You can do it by running the script from this thread:
mrroland Posted June 7, 2018 Author Posted June 7, 2018 Hi, Thanks for the reply. First solution didn't work for me. When I wanted to try the second one I discovered that the armbian image from the download section uses a 3.x kernel, so I can't run the script for the accelerated drivers. I tried to install a desktop environment to the nightly build with 4.x kernel, but I couldn't get it to work... But I think it's a kernel issue because the purple line is visible as soon as the boot sequence starts. This won't happen with the official odroid image. I guess I should stick to the official image for now and compile the kernel modules I'm missing for that version.
