I've burn "Armbian Stretch desktop legacy kernel 4.4.y" on sd card on use nand-sata-install on emmc but when I remove sd card it's no boot.
I read on Pine forum we must put a jumper on "emmc pin" then remove 3/4s after power on. So I've try but no success.
I can see emmc when I boot from sd card but no more.
Expand
No, this way does not work yet. You need to burn an image directly to the eMMC (with SD card adaptor). Then it works.
Ho no ! It was the last piece of my Armbian puzzle !
I search adaptater on the web but I guess it's specific to Pine64. So I'll order one from Pine64 and wait.... :-)
Thanks a lot for your response.
Expand
Odroid's adapter is compatible If you have one around.
BTW. Nice setup! :)
