Hi All,
I'm using Ubuntu 16.04 as my OS system and i.MX6DL SabreSD as my cpu.
I build my linux kernel with Yocto Project.
Now I'm trying to protect the root filesystem with Overlayroot.
I installed the overlayroot by using apt-get as below.
sudo apt-get install overlayroot
According some research, its lead me to modify "/etc/overlayroot.conf"  to enable overlayroot.
So here I tried to add the line at the bottom.
overlayroot="tmpfs:swap=1,recurse=0"
Then I reboot the system.
After that I tried to check if there was any overlayroot mounted with command `mount` when get into system.
But there was nothing happened, root filesystem still mounted as RW.
Did I miss any steps?
Or is overlayroot have any relation with linux kernel driver?
Yes, check logs for: [failure]: missing kernel module overlayfs
Thanks for reply.
I had check logs by running below command.
dmesg | grep -rIn "overlayfs" *
But can not find any failure that relate to overlayfs.
I doubt that it did not even execute overlayroot.conf.
Any Advice?
Thanks in Advanced!
Any Advice?
overlayroot is very picky and I could not make it work under Debian ... so it only works on Ubuntu. Xenial is tested, while I dont't recall testing it on Bionic. It's not just kernel but probably some libraries. I am not familiar with Yocto, so can't help you to fix it there but if you need this functionality and don't want to spent a lot of time fixing this, switch to Armbian Xenial version. It works there out of the box. Well, you will need to construct/copy a kernel/u-boot for your board ... so it's not very simple to decide the best route.
I can not switch to Armvian Xenial version cause customer need Ubuntu and kernel build from Yocto.
What I know now is that there is some kernel driver configuration that I have to open.
After that it is all about Ubuntu 16.04 LTS.
And When I test overlayroot on my Ubuntu 16.04 which installed on Oracle VM VirtualBox, It success.
So I do the exactly same way on my armbased board but things not going quite well.
I think I have to do more research on this.
Any way thanks for your help.
For a  quick ask, do you know which kernel driver configuration I have to open?
