Tsung-Li Wang Posted June 8, 2018 Posted June 8, 2018 Hi All, I'm using Ubuntu 16.04 as my OS system and i.MX6DL SabreSD as my cpu. I build my linux kernel with Yocto Project. Now I'm trying to protect the root filesystem with Overlayroot. I installed the overlayroot by using apt-get as below. sudo apt-get install overlayroot According some research, its lead me to modify "/etc/overlayroot.conf" to enable overlayroot. So here I tried to add the line at the bottom. overlayroot="tmpfs:swap=1,recurse=0" Then I reboot the system. After that I tried to check if there was any overlayroot mounted with command `mount` when get into system. But there was nothing happened, root filesystem still mounted as RW. Did I miss any steps? Or is overlayroot have any relation with linux kernel driver?
Igor Posted June 8, 2018 Posted June 8, 2018 On 6/8/2018 at 3:47 AM, Tsung-Li Wang said: Or is overlayroot have any relation with linux kernel driver? Expand Yes, check logs for: [failure]: missing kernel module overlayfs
Tsung-Li Wang Posted June 8, 2018 Author Posted June 8, 2018 On 6/8/2018 at 4:52 AM, Igor said: Yes, check logs for: [failure]: missing kernel module overlayfs Expand Thanks for reply. I had check logs by running below command. dmesg | grep -rIn "overlayfs" * But can not find any failure that relate to overlayfs. I doubt that it did not even execute overlayroot.conf. Any Advice? Thanks in Advanced!
Igor Posted June 8, 2018 Posted June 8, 2018 On 6/8/2018 at 5:39 AM, Tsung-Li Wang said: Any Advice? Expand overlayroot is very picky and I could not make it work under Debian ... so it only works on Ubuntu. Xenial is tested, while I dont't recall testing it on Bionic. It's not just kernel but probably some libraries. I am not familiar with Yocto, so can't help you to fix it there but if you need this functionality and don't want to spent a lot of time fixing this, switch to Armbian Xenial version. It works there out of the box. Well, you will need to construct/copy a kernel/u-boot for your board ... so it's not very simple to decide the best route.
Tsung-Li Wang Posted June 12, 2018 Author Posted June 12, 2018 On 6/8/2018 at 7:03 AM, Igor said: overlayroot is very picky and I could not make it work under Debian ... so it only works on Ubuntu. Xenial is tested, while I dont't recall testing it on Bionic. It's not just kernel but probably some libraries. I am not familiar with Yocto, so can't help you to fix it there but if you need this functionality and don't want to spent a lot of time fixing this, switch to Armbian Xenial version. It works there out of the box. Well, you will need to construct/copy a kernel/u-boot for your board ... so it's not very simple to decide the best route. Expand I can not switch to Armvian Xenial version cause customer need Ubuntu and kernel build from Yocto. What I know now is that there is some kernel driver configuration that I have to open. After that it is all about Ubuntu 16.04 LTS. And When I test overlayroot on my Ubuntu 16.04 which installed on Oracle VM VirtualBox, It success. So I do the exactly same way on my armbased board but things not going quite well. I think I have to do more research on this. Any way thanks for your help.
Tsung-Li Wang Posted June 12, 2018 Author Posted June 12, 2018 On 6/8/2018 at 7:03 AM, Igor said: overlayroot is very picky and I could not make it work under Debian ... so it only works on Ubuntu. Xenial is tested, while I dont't recall testing it on Bionic. It's not just kernel but probably some libraries. I am not familiar with Yocto, so can't help you to fix it there but if you need this functionality and don't want to spent a lot of time fixing this, switch to Armbian Xenial version. It works there out of the box. Well, you will need to construct/copy a kernel/u-boot for your board ... so it's not very simple to decide the best route. Expand For a quick ask, do you know which kernel driver configuration I have to open?
Igor Posted June 12, 2018 Posted June 12, 2018 On 6/12/2018 at 3:33 AM, Tsung-Li Wang said: I think I have to do more research on this. Expand ... and hire people. https://www.google.com/search?q=hire+freelancers Free technical support applies to Armbian related stuff, stable releases only On 6/12/2018 at 7:09 AM, Tsung-Li Wang said: For a quick ask Expand and comes as is.
