When I tried booting the vanilla kernel, downloaded from http://www.armbian.com/hummingboard/, on my Hummingboard i4 Pro, I get the following error message from u-boot:
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
Booting from net
Has anyone else seen the same issue?
Thanks.
You have Hummingboard 2 ?
Thanks for replying. I am kind of new and not aware what is Hummingboard 2. But I have the Hummingboard i4 Pro Quadcore model.
Thanks.
I assume you have v2 which is not directly supported ... some small hack is needed:
cp /boot/dtb/hummingboard.dtb /boot/dtb/hummingboard2.dtb
You will need to mount sd card on some linux ... than it will boot. I will fix this problem in next update ... until then, you can do this.
I only have V1.0 so I am not aware what does work and what not. BTW. You can attach or link a picture to make sure.
Sure, thank you for helping!
