ron123456 Posted June 11, 2018 Posted June 11, 2018 Hello I am new to Nanopi m1 plus development board. I followed the instruction as on friendlyarm's wiki page. I loaded the image from my Ubuntu OS and connected my device to the pc. The blue led was blinking normally. I used Putty to view the logs. While booting it is showing: resize2fs 1.42.12 (29-Aug-2014) resize2fs: Bad magic number in super-block while trying to open /dev/mmcblk0p2 Couldn't find valid filesystem superblock. resize2fs exited with status code 1 done. mount: mounting /dev/mmcblk0p2 on /root failed: Invalid argument done. Target filesystem doesn't have requested /sbin/init. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... mount: mounting /dev on /root/dev failed: No such file or directory done. No init found. Try passing init= bootarg. Rebooting automatically due to panic= boot argument [ 45.460839] reboot: Restarting system I uploaded nanopi-m1-plus_friendlycore-xenial_3.4.y_YYYYMMDD.img.zip image. What is the issue and how can it be resolved?
Igor Posted June 13, 2018 Posted June 13, 2018 On 6/11/2018 at 12:53 PM, ron123456 said: What is the issue and how can it be resolved? Expand The issue is you are not using Armbian. We don't support factory builds. Start here: https://www.armbian.com/nanopi-m1-plus/ and follow the documentation https://docs.armbian.com/User-Guide_Getting-Started/ and you will end up with a much better OS.
