SaiHou Posted June 20, 2018 Posted June 20, 2018 Hello there, I am looking a way to get / write a script for the file to be run on startup. I am running PiAware with dump1090-fa installed. I would like to having the view1090-fa --modeac to be auto run when the system is ON. Is there a way to get this work without my concern in the future? Currently if I need to run this command, I need to run SSH and remote the Pi to run this command from my PC. Thank you in advance. Regards, SaiHou
martinayotte Posted June 20, 2018 Posted June 20, 2018 You may call this command at startup using /etc/rc.local ...
SaiHou Posted June 21, 2018 Author Posted June 21, 2018 On 6/20/2018 at 3:44 PM, martinayotte said: You may call this command at startup using /etc/rc.local ... Expand Hi martinayotte, Thank you for the advise. Is it something like:- sudo nano /etc/rc.local GNU nano 2.7.4 File: /etc/rc.local #!/bin/sh -e # # # This script is executed at the end of each multiuser runlevel. # Make sure that the script will "exit 0" on success or any other # value on error. # # In order to disable this script please use systemd to control the service: # systemctl disable rc-local.service # # By default this script does nothing. view1090-fa --modeac exit 0 Then reboot and the view1090-fa --modeac will run automatically? Thank you once again. Regards, SaiHou
martinayotte Posted June 21, 2018 Posted June 21, 2018 Right ! For other kind of apps which run in background, ampersand need to be added, example : python run_for_ever.py &
SaiHou Posted June 21, 2018 Author Posted June 21, 2018 On 6/21/2018 at 12:22 PM, martinayotte said: Right ! For other kind of apps which run in background, ampersand need to be added, example : python run_for_ever.py & Expand Thanks for the reply. It only works in Armbian Debian Jessie. For the Raspbian Jessie it will not work. Any clue on this to solve it? Thanks once again.
martinayotte Posted June 22, 2018 Posted June 22, 2018 euuh ? /etc/rc.local should exist on both ! I'm don't know what can be wrong in Rasbian ...
SaiHou Posted June 22, 2018 Author Posted June 22, 2018 On 6/22/2018 at 1:03 PM, martinayotte said: euuh ? /etc/rc.local should exist on both ! I'm don't know what can be wrong in Rasbian ... Expand Hi martinayotte, I have no idea. Both OS has this file but only the Armbian is working, Raspbian is not. No clue. Anyway, thank you for sharing info. Regards.
