plus90 Posted June 22, 2018 Posted June 22, 2018 Hi, I get this line on my welcome screen of my Orange Pi Zero: Welcome to ARMBIAN 5.38 stable Ubuntu 16.04.4 LTS 3.4.113-sun8i When I checked the download page, I see this as the file name: Armbian_5.38_Orangepizero_Debian_stretch_next_4.14.14 I got confused about the numbers 3.4.113 and 4.14.14 What do they mean? Is my installation behind the latest version? Can I upgrade to it?
guidol Posted June 23, 2018 Posted June 23, 2018 Your version is a armbian LTS (Long Time Service) Ubuntu with a legacy kernel version 3.4.113 The other download is a Debian Stretch with an actual mainline-kernel version 4.14.14 (maybe sometime 4.17.x) The legacy kernel 3.4.113 will run out of support (or is already unsupported). So your installation is behind the latest version and NO you cant upgrade directly, because there is a difference between Ubuntu and debian. BUT maybe there is an upgrade-path to the newer Ubuntu Xenial with kernel 4.14.14 A image for a fresh install is here https://dl.armbian.com/orangepizero/archive/Armbian_5.38_Orangepizero_Ubuntu_xenial_next_4.14.14.7z and there is a DEV(eloper)-Ubuntu image of the new coming Ubuntu Bionic with Kernel 4.17https://dl.armbian.com/orangepizero/nightly/Armbian_5.47.180622_Orangepizero_Ubuntu_bionic_dev_4.17.2.7z So maybe its easier to do a fresh install depending which additional services you did install onto your LTS Ubuntu. You also have to check if all your services or additional hardware is supported behind the kernel 3.4.113
plus90 Posted June 25, 2018 Author Posted June 25, 2018 Thanks a lot I was hoping I can avoid a fresh install since I have lots of torrents to move, but it shouldn't be too hard to move them.
