Run armbian into QEMU
SMAH1
Donate your old hardware to community. Start a giveaway Raffle!
The answer is a bit late, but it may be useful to someone else, because this page is the first in google for "armbian qemu".
Running image for orange-pi one - Armbian_5.90_Orangepione_Ubuntu_bionic_next_4.19.57.7z:
Extrart Armbian image:
7z e Armbian_5.90_Orangepione_Ubuntu_bionic_next_4.19.57.7z Armbian_5.90_Orangepione_Ubuntu_bionic_next_4.19.57.img
Extract kernel, initrd and dtb:
7z e boot/vmlinuz-4.19.57-sunxi boot/initrd.img-4.19.57-sunxi boot/dtb-4.19.57-sunxi/sun4i-a10-cubieboard.dtb
Run qemu:
qemu-system-arm \
  -M cubieboard -m 1024 -cpu cortex-a8 -dtb sun4i-a10-cubieboard.dtb \
  -kernel vmlinuz-4.19.57-sunxi -initrd initrd.img-4.19.57-sunxi \
  -append 'earlyprintk loglevel=8 earlycon=uart8250,mmio32,0x1c28000,115200n8 console=ttyS0 root=/dev/sda1' \
  -nographic -serial stdio -monitor none \
  -drive file=Armbian_5.90_Orangepione_Ubuntu_bionic_next_4.19.57.img,format=raw,if=none,id=d1 \
  -device ide-hd,drive=d1 \
  -nic user,model=allwinner-emac,hostfwd=tcp::50022-:22
It was tested in qemu 3.1
Link to comment
Share on other sites
This answer is even later...
There’s another way to do this, in Linux at least.
Install qemu-user-static and (if not automatically installed) binfmt. Then copy the Armbian rootfs of the Orange Pi model you want to use to a directory on your PC, e.g. opi-rootfs.
You can now chroot into this directory and it will behave (almost) the same as if you’re on a real Orange Pi <Model>
The proper command is ‘sudo chroot opi-rootfs /bin/bash’
You can also mount /dev, /sys, /proc to the same directories in opi-rootfs but for compiling stuff this is not really necessary I think.
Instead of chroot you can also do ‘systemd-nspawn -D opi-rootfs’
Link to comment
