My Development board is Orange Pi zero  plus2 H5.
My bluetooth already in work,but I try to play a .wav for test.this circumstance occurs.
This is my test wav file: 1045.wav
I use :
aplay 1045.wav
Playing WAVE '1045.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
then I record the sounds as mypaly.mp3.
I guess this problem is due to uart Baud rate 115200 is not high enough . How can i fix this?
1045.wav
mypaly.mp3
I solved this problem,I refer to the answer to this question.
This is indeed caused by the serial port baud rate being too low.
I modified /etc/init.d/ap6212-bluetooth
hciattach /dev/$PORT bcm43xx 115200 flow bdaddr $MAC_OPTIONS
to
hciattach /dev/$PORT bcm43xx 1500000 flow bdaddr $MAC_OPTIONS
