SOLVED (POWER RELATED ISSUE) - Orange Pi Win Plus not booting with current stable Armbian Xenial
Hello everybody!
I have an Orange Pi Win Plus and I'm trying to boot the current stable release of the Armbian Xenial but I get no video output on the hdmi and sometimes the board turns itself off. I've tried both server and desktop versions but the issue remains.
My current setup:
5.01V@2.0A PSU;
Usb mouse and keyboard;
Used Etcher to burn the images on the sd card;
Tried to boot using 2 different sd cards, both 8gb, the result is the same;
Tested images are Armbian_5.41_Orangepiwin_Ubuntu_xenial_default_3.10.107_desktop.img and Armbian_5.41_Orangepiwin_Ubuntu_xenial_default_3.10.107.img
The console output on the ttl port shows this:
U-Boot 2014.07 (Feb 11 2018 - 19:21:28) Allwinner Technology
uboot commit : 6f37e5cf6a65b0b10455d12dbd631effabe765ec
rsb: secure monitor exist
[      0.404]pmbus:   ready
[      0.407][ARISC] :arisc initialize
[      0.736][ARISC] :arisc_dvfs_cfg_vf_table: support only one vf_table
[SCP] :sunxi-arisc driver begin startup 2
[SCP] :arisc_para size:1a8
[SCP] :arisc version: [v0.1.76]
[SCP] :sunxi-arisc driver v1.10 is starting
[      0.864][ARISC] :sunxi-arisc driver startup succeeded
[      0.898]PMU: AXP81X
[      0.900]PMU: AXP81X found
bat_vol=0, ratio=100
[      0.906]PMU: dcdc2 1100
[      0.909]PMU: cpux 1008 Mhz,AXI=336 Mhz
PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz AHB2=300Mhz MBus=400Mhz
device_type = 3253, onoff=1
dcdc1_vol = 3300, onoff=1
dcdc2_vol = 1100, onoff=1
dcdc6_vol = 1100, onoff=1
aldo1_vol = 2800, onoff=0
aldo2_vol = 1800, onoff=1
aldo3_vol = 3000, onoff=1
dldo1_vol = 3300, onoff=0
dldo2_vol = 3300, onoff=0
dldo3_vol = 2800, onoff=0
dldo4_vol = 3300, onoff=1
eldo1_vol = 1800, onoff=1
eldo2_vol = 1800, onoff=0
eldo3_vol = 1800, onoff=0
fldo1_vol = 1200, onoff=0
fldo2_vol = 1100, onoff=1
gpio0_vol = 3100, onoff=0
vbus not exist
no battery, limit to dc
run key detect
no key found
no uart input
DRAM:  2 GiB
fdt addr: 0xb6ebce80
Relocation Offset is: 75f0f000
In:    serial
Out:   serial
Err:   serial
gic: sec monitor mode
[      1.219]start
drv_disp_init
init_clocks: finish init_clocks.
enable power vcc-hdmi-33, ret=0
drv_disp_init finish
boot_disp.output_disp=0
boot_disp.output_type=3
boot_disp.output_mode=10
fetch script data boot_disp.auto_hpd fail
disp0 device type(4) enable
attched ok, mgr0<-->device1, type=4, mode=10
[      1.587]end
workmode = 0,storage type = 1
[      1.591]MMC:        0
[mmc]: mmc driver ver 2015-06-03 13:50:00
SUNXI SD/MMC: 0
[mmc]: start mmc_calibrate_delay_unit, don't access device...
[mmc]: delay chain cal done, sample: 185(ps)
[mmc]: media type 0x0
[mmc]: Wrong media type 0x0
[mmc]: ************Try SD card 0************
[mmc]: host caps: 0x27
[mmc]: MID 02 PSN 9c0001b2
[mmc]: PNM SA08G -- 0x53-41-30-38-47
[mmc]: PRV 0.4
[mmc]: MDT m-1 y-2010
[mmc]: speed mode     : HSSDR52/SDR25
[mmc]: clock          : 50000000 Hz
[mmc]: bus_width      : 4 bit
[mmc]: user capacity  : 7604 MB
[mmc]: ************SD/MMC 0 init OK!!!************
[mmc]: erase_grp_size      : 0x1WrBlk*0x200=0x200 Byte
[mmc]: secure_feature      : 0x0
[mmc]: secure_removal_type : 0x0
[      1.778]sunxi flash init ok
** Unable to use mmc 0:1 for loading the env **
Using default environment
--------fastboot partitions--------
mbr not exist
base bootcmd=run mmcbootcmd
bootcmd set setargs_mmc
key 0
recovery key high 12, low 10
fastboot key high 6, low 4
no misc partition is found
to be run cmd=run mmcbootcmd
update dtb dram start
update dtb dram  end
serial is: 64107884c8080c2e060f
check for ANX9807
get Pine64 model from DRAM size
DRAM >512M
Pine64 model: pine64-plus
no battery exist
sunxi bmp: unable to open file /boot/bootlogo.bmp
[      2.069]inter uboot shell
autoboot in 3 seconds, Press s or <Esc><Esc> to abort
4984 bytes read in 24 ms (202.1 KiB/s)
Booting with script ...
## Executing script at 41000000
166 bytes read in 19 ms (7.8 KiB/s)
69613 bytes read in 38 ms (1.7 MiB/s)
4353809 bytes read in 374 ms (11.1 MiB/s)
12636952 bytes read in 1002 ms (12 MiB/s)
Image lacks image_size field, assuming 16MiB
## Loading init Ramdisk from Legacy Image at 45300000 ...
   Image Name:   uInitrd
   Data Size:    4353745 Bytes = 4.2 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 45000000
   Booting using the fdt blob at 0x45000000
   reserving fdt memory region: addr=41010000 size=10000
   reserving fdt memory region: addr=41020000 size=800
   reserving fdt memory region: addr=40100000 size=4000
   reserving fdt memory region: addr=40104000 size=1000
   reserving fdt memory region: addr=40105000 size=1000
   reserving fdt memory region: addr=45000000 size=12000
   Loading Ramdisk to b6a8f000, end b6eb5ed1 ... OK
   Loading Device Tree to 44fea000, end 44ffefff ... OK
Starting kernel ...
[mmc]: MMC Device 2 not found
[mmc]: mmc 2 not find, so not exit
INFO:    BL3-1: Next image address = 0x41080000
INFO:    BL3-1: Next image spsr = 0x3c9
I've also tested the Armbian_5.51.180709_Orangepiwin_Ubuntu_bionic_dev_4.18.0-rc3.img, this image shows output through hdmi but the boot stops sometimes. I've managed to boot this image but sometimes when it boots it freezes soon after I do the login. Usually console output when it doesn't boots looks like this:
U-Boot 2018.07-rc1-armbian (Jul 10 2018 - 00:17:35 +0000) Allwinner Technology
CPU:   Allwinner A64 (SUN50I)
Model: OrangePi Win/Win Plus
DRAM:  2 GiB
MMC:   SUNXI SD/MMC: 0
Loading Environment from FAT... Unable to use mmc 0:1... Failed (-5)
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
230454 bytes read in 31 ms (7.1 MiB/s)
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3090 bytes read in 21 ms (143.6 KiB/s)
## Executing script at 4fc00000
U-boot loaded from SD
Boot script loaded from mmc
153 bytes read in 17 ms (8.8 KiB/s)
13616 bytes read in 35 ms (379.9 KiB/s)
** File not found /boot/dtb/allwinner/overlay/sun50i-a64-fixup.scr **
 ** fs_devread read error **
** File not found /boot/uInitrd **
** File not found /boot/Image **
## Loading init Ramdisk from Legacy Image at 4fe00000 ...
   Image Name:   uInitrd
   Data Size:    8056392 Bytes = 7.7 MiB
   Verifying Checksum ... Bad Data CRC
Ramdisk image is corrupt or invalid
SCRIPT FAILED: continuing...
Device 0: device type unknown
... is now current device
** Bad device usb 0 **
No ethernet found.
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
Any hints on this? It's an issue or am I missing something?
Thank you!
Support for A64 boards is not the best but not this bad. Most of the images from the download sections have been tested. I can't double check ATM but I am almost sure the problem is not on our side.
Boot bootlogs indicates troubles related to boot media. I would choose some other SD card brand, double check powering, ... https://forum.armbian.com/forum/31-sd-card-and-power-supply/
Thank you, I'll do more testings on this.
For now I guess I can say that the Armbian_5.51.180709_Orangepiwin_Ubuntu_bionic_dev_4.18.0-rc3.img is working, I had some freezing issues on the first and second times I've booted it, but now it seems to be working fine (need more testing to say for sure), but eventually I get the "No ethernet found." on the console and then I need to reset to get it working.
I would expect the other way around. Old kernel (3.10.y) images are tested and they should work, while automated build images from latest trunk (4.18. ATM) can work or not ... but they also lack features and can be unstable. They are made for development purposes. To hunt bugs.
Yes, I also thought it would make more sense that the stable version would be the working one. I'll try with other sd cards, but the two I've tested showed the same console message:
1 hour ago, evilm said:
Starting kernel ... [mmc]: MMC Device 2 not found [mmc]: mmc 2 not find, so not exit INFO: BL3-1: Next image address = 0x41080000 INFO: BL3-1: Next image spsr = 0x3c9
Just tried the Armbian_5.41_Orangepiwin_Ubuntu_xenial_default_3.10.107_desktop.img with a brand new Sandisk Ultra 32gb micro sd and got the same console output as reported earlier in this post. Here is my log:
HELLO! BOOT0 is starting!
boot0 commit : 045061a8bb2580cb3fa02e301f52a015040c158f
boot0 version : 4.0.0
set pll start
set pll end
rtc[0] value = 0x00000000
rtc[1] value = 0x00000000
rtc[2] value = 0x00000000
rtc[3] value = 0x00000000
rtc[4] value = 0x00000000
rtc[5] value = 0x00000000
DRAM driver version: V1.1
rsb_send_initseq: rsb clk 400Khz -> 3Mhz
PMU: AXP81X
ddr voltage = 1500 mv
DRAM Type = 3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM clk = 672 MHz
DRAM zq value: 003b3bbb
DRAM single rank full DQ OK
DRAM size = 2048 MB
DRAM init ok
dram size =2048
card boot number = 0, boot0 copy = 0
card no is 0
sdcard 0 line count 4
[mmc]: mmc driver ver 2015-05-08 20:06
[mmc]: sdc0 spd mode error, 2
[mmc]: Wrong media type 0x00000000
[mmc]: ***Try SD card 0***
[mmc]: HSSDR52/SDR25 4 bit
[mmc]: 50000000 Hz
[mmc]: 30436 MB
[mmc]: ***SD/MMC 0 init OK!!!***
sdcard 0 init ok
The size of uboot is 000e8000.
sum=edd51168
src_sum=edd51168
Succeed in loading uboot from sdmmc flash.
boot0: start load other image
boot0: Loading BL3-1
Loading file 0 at address 0x40000000,size 0x0000a200 success
boot0: Loading scp
Loading file 2 at address 0x00040000,size 0x00019a00 success
set arisc reset to de-assert state
Ready to disable icache.
▒▒▒▒ɽ▒▒▒▒5R▒NOTICE:  BL3-1: v1.0(debug):3cdc5c3
NOTICE:  BL3-1: Built : 13:03:37, Jan 10 2018
INFO:    BL3-1: Initializing runtime services
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x4a000000
INFO:    BL3-1: Next image spsr = 0x1d3
[      0.368]pmbus:   ready
[      0.370][ARISC] :arisc initialize
[      0.700][ARISC] :arisc_dvfs_cfg_vf_table: support only one vf_table
[      0.827][ARISC] :sunxi-arisc driver startup succeeded
[      0.861]PMU: AXP81X
[      0.863]PMU: AXP81X found
bat_vol=258, ratio=100
[      0.869]PMU: dcdc2 1100
[      0.872]PMU: cpux 1008 Mhz,AXI=336 Mhz
vbus not exist
run key detect
no key found
no uart input
DRAM:  2 GiB
In:    serial
Out:   serial
Err:   serial
[      1.683]start
drv_disp_init
[      2.052]end
[      2.056]MMC:        0
SUNXI SD/MMC: 0
[mmc]: delay chain cal done, sample: 192(ps)
[mmc]: MID 03 PSN 212062df
[mmc]: PNM SU32G -- 0x53-55-33-32-47
[mmc]: PRV 8.0
[mmc]: MDT m-9 y-2013
[mmc]: user capacity  : 30436 MB
[      2.246]sunxi flash init ok
mbr not exist
key 0
update dtb dram  end
check for ANX9807
DRAM >512M
no battery exist
[      2.528]inter uboot shell
166 bytes read in 18 ms (8.8 KiB/s)
69613 bytes read in 33 ms (2 MiB/s)
4353898 bytes read in 259 ms (16 MiB/s)
12636952 bytes read in 676 ms (17.8 MiB/s)
   Image Name:   uInitrd
   Data Size:    4353834 Bytes = 4.2 MiB
   Loading Ramdisk to b6a8f000, end b6eb5f2a ... OK
Starting kernel ...
Also, I've tried to boot the board with this sandisk ultra using two different power supplies. They are rated as:
5v@2A -> Measured output voltage on load: 5.01V
5v@2A -> Measured output voltage on load: 5.04V
Any ideas on what is going on? I have nothing connected to the board besides the micro sd card and an ft232rl to catch the console output. There is no keyboard, mice or hdmi monitor connected.
I've used etcher to burn the images to the micro sd card, it always finishes fine. At the end of flashing, it does the verification an says that the flashing process was sucessful. Tried 4 different sd cards and the only image that worked was the developers one (Armbian_5.41_Orangepiwin_Ubuntu_xenial_default_3.10.107.img).
I'm suspecting that this issue I'm facing is power related. When I get back home I'll do some testing and let you guys know about.
Thank you for the help.
Hello guys, firstly I want to apologize for creating a big post without taking proper care of my setup, I guess it was a power related issue at all. I`ve managed to boot all the images (current stables, and developers one).
I`m posting this from the Orange Pi Win Plus with the current desktop stable image (Armbian_5.41_Orangepiwin_Ubuntu_xenial_default_3.10.107_desktop.img) and it`s working great. I`ll do more testings and share my finds with you.
I`ll use the server version, but wanted to try the desktop image.
My problem was inside the power jack plug, it was someway loose inside and thus not offering proper contact with the central pin of jack (plus) off the board. The connection between the plug and the board was pretty fit so I didn`t thought that this would be the origin of my issue. I discovered this because I decided to power the board using some testing logic clamps I have laying around instead of the plug itself and then the board booted flawlessly with all the images and with all micro sd cards I have.
I thought the problem would be a bad solder joint on the plug itself, but in fact it was a problem inside the jack`s barrel. I crack it open to see what was going on and the metal connection inside the barrel was broken and barely making contact, it was only "working" because when I plugged it onto the board the pressure between the metal parts and the central pin of the board provided some contact.
Thank you guys for the responses.
  • evilm changed the title to SOLVED (POWER RELATED ISSUE) - Orange Pi Win Plus not booting with current stable Armbian Xenial
I has a similar problem.
my Armbian_5.57_Orangepiwin_Ubuntu_xenial_default_3.10.107.img is always loaded.
my Armbian_5.57_Orangepiwin_Ubuntu_xenial_next_4.17.14.img was loaded after the third reset.
now I build Armbian_5.59_Orangepiwin_Ubuntu_xenial_next_4.17.17.img
is loaded much more often 4.17.14,
but periodically "** fs_devread read error **" (in different places) and loading stops.
maybe this the SD card issue or in the cooper wire in power cable.
until I can't understand, so just report too.
need help ))  .. resolved with  BOOTBRANCH='branch:pinebook-wip-20180909',
i has orange pi win plus, serial date at sticker 20170509
when i build with default kernel v3.10.107 - my board always boot OK
when i build with next or dev kernel - uboot stops in 30-60%.
always ** fs_devread read error **" in console.  https://pastebin.com/prwdGXtS
(error - always different !!!)
i change 3 SD card,  used 4A PSU, usb tester in USB and watt metter at input.
so, i want ask.
1) someone else had a fs_devread read error problem with next or dev kernel ?
perhaps just my orange isn't compatible with the new UBOOT.
2) sorry for my illiteracy, can I combine the stock uboot with dev or next kernel
apt install ./linux-image-pine64_5.59_arm64.deb at dev kernel - not work.
3) how to enable DEBUG for uboot ?   i want see more debug info in console. message like
debug(" <" LBAFU ", %d, %d>\n", sector, byte_offset, byte_len);
but armbian stop compile SPL
I didn't find anything else, and use userpatch for add DEBUG in /include/log.h
diff --git a/include/log.h b/include/log.h
--- a/include/log.h
+++ b/include/log.h
@@ -130,7 +130,7 @@
 #define debug_cond(cond, fmt, args...)			\
 	do {						\
-		if (cond)				\
+		if (1)				\
 			printf(pr_fmt(fmt), ##args);	\
 	} while (0)
and get this error on dev uboot:
  CC      spl/lib/rand.o
  CC      spl/lib/strto.o
  LD      spl/lib/built-in.o
  LD      spl/u-boot-spl
/home/peter/armbian4/cache/toolchains/gcc-linaro-7.2.1-2017.11-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-ld.bfd: u-boot-spl section `.rodata' will not fit in region `.sram'
/home/peter/armbian4/cache/toolchains/gcc-linaro-7.2.1-2017.11-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-ld.bfd: region `.sram' overflowed by 1192 bytes
scripts/Makefile.spl:353: recipe for target 'spl/u-boot-spl' failed
make[1]: *** [spl/u-boot-spl] Error 1
Makefile:1507: recipe for target 'spl/u-boot-spl' failed
make: *** [spl/u-boot-spl] Error 2
[ error ] ERROR in function compile_uboot [ compilation.sh:173 ]
[ error ] U-boot compilation failed
[ o.k. ] Process terminated
oh, play few week with this case and old kernel,
change uboot to BOOTBRANCH='branch:pinebook-wip-20180909',
and no any fs_devread read error  for 20 startup.
