0
Orangepinoob
Possible to see available wifi while being acess point? Orange pi zero
I'm using an Orange pi zero H2 and currently have the pi configured as an access point.  I want to be able to SSH into pi using access point wifi, then switch pi onto my home wifi network.
When I use the "nmtui" utility I no longer see any available wifi networks.  Is it possible to see available wifi networks when I am using the pi as an access point?
Thanks,
orangepi noob
Share this post
Link to post
Share on other sites
XR819 is the WiFi chip used on OPiZeroH2+. Most Armbian hate that chip since it provide poor performance, and driver is a bit crappy.
STA means STATION and AP means AccessPoint. So, if you wish to have both at the same time, I doubt the driver and/or chip support both mode at the same time ...
What you can do is attach a second WiFi thru USB.
Share this post
Link to post
Personnally, I don't know which ones since I've never use such configuration.
But you can leave the internal XR819 as AP while adding an USB WiFi dongle for the STA, you will then get both wlan0 and wlan1.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
0
