Possible to see available wifi while being acess point? Orange pi zero
Orangepinoob
I'm using an Orange pi zero H2 and currently have the pi configured as an access point.  I want to be able to SSH into pi using access point wifi, then switch pi onto my home wifi network.
When I use the "nmtui" utility I no longer see any available wifi networks.  Is it possible to see available wifi networks when I am using the pi as an access point?
Thanks,
orangepi noob
XR819 is the WiFi chip used on OPiZeroH2+. Most Armbian hate that chip since it provide poor performance, and driver is a bit crappy.
STA means STATION and AP means AccessPoint. So, if you wish to have both at the same time, I doubt the driver and/or chip support both mode at the same time ...
What you can do is attach a second WiFi thru USB.
