Cuboxi: Kernel 4.14.y does not compile, failing to compile imx6dl-cubox-i.dtb
I'm trying to build the next kernel (4.14.y) for Cubox-i, but the process fails here:
  DTC     arch/arm/boot/dts/imx6dl-cubox-i.dtb
Error: arch/arm/boot/dts/imx6qdl-cubox-i.dtsi:261.1-9 Label or path vcc_3v3 not found
FATAL ERROR: Syntax error parsing input tree
scripts/Makefile.lib:317: recipe for target 'arch/arm/boot/dts/imx6dl-cubox-i.dtb' failed
make[1]: *** [arch/arm/boot/dts/imx6dl-cubox-i.dtb] Error 1
arch/arm/Makefile:348: recipe for target 'dtbs' failed
make: *** [dtbs] Error 2
make: *** Waiting for unfinished jobs....
When I compiled the kernel approx. 2 months ago (4.15.?) I did not get that error.
Any ideas?
  • gkkpch changed the title to Cuboxi: Kernel 4.14.y does not compile, failing to compile imx6dl-cubox-i.dtb
51 minutes ago, gkkpch said:
Any ideas?
None without providing build logs. I was able to build a kernel without any problem:
dpkg-deb: building package 'linux-dtb-next-cubox' in '../linux-dtb-next-cubox_5.52_armhf.deb'.
dpkg-deb: building package 'linux-headers-next-cubox' in '../linux-headers-next-cubox_5.52_armhf.deb'.
dpkg-deb: building package 'linux-image-next-cubox' in '../linux-image-next-cubox_5.52_armhf.deb'.
dpkg-genchanges: warning: unknown substitution variable ${kernel:debarch}
dpkg-genchanges: warning: package linux-libc-dev-next-cubox in control file but not in files list
dpkg-genchanges: info: binary-only upload (no source code included)
dpkg-deb: building package 'linux-source-4.14.55-next-cubox' in '/home/igorp/master/.tmp/linux-source-next-cubox_5.52_all.deb'.
[ o.k. ] Kernel build done [ @host ]
[ o.k. ] Target directory [ /home/igorp/master/output/debs/ ]
[ o.k. ] File name [ linux-image-next-cubox_5.52_armhf.deb ]
[ o.k. ] Runtime [ 12 min ]
You can find them under debug subdirectory.
7 minutes ago, gkkpch said:
question: does it have an influence that you are building version 5.52 and mine was 5.51?
5.52 is a development branch which is changed only for Allwinner and Odroid XU4, which are under some heavy changes. I also tried to build on a master branch (5.51) and it also builds. I also notice that you are using Ubuntu Xenial builds host. That should not affect this ...
Try removing the cache directory, mainly sources, and try again. Also, a clean build script would be a way to go.
It looks as if the Armbian imx6dl-cubox-i.dts dtsi includes do not have the vcc_3v3 regulator defined.
When I replace imx6qdl-sr-som.dtsi with the one from the SR 4.9.y kernel, then imx6dl-cubox-i.dts compiles without issues.
But, then it fails on one of the next dts:
arch/arm/boot/dts/imx6dl-hummingboard2.dts:46:10: fatal error: imx6qdl-sr-som-brcm.dtsi: No such file or directory
 #include "imx6qdl-sr-som-brcm.dtsi"
compilation terminated.
scripts/Makefile.lib:317: recipe for target 'arch/arm/boot/dts/imx6dl-hummingboard2.dtb' failed
make[1]: *** [arch/arm/boot/dts/imx6dl-hummingboard2.dtb] Error 1
I don't know why you don't get an error...
I am looking into this ... but since I am not in the office, this takes much more time with lots of interruptions. :huh:
On my test Ubuntu Xenial, I am getting strange compiler errors (arm-linux-gnueabihf-gcc: internal compiler error: Killed (program cc1)
) when compiling modern kernels (which can be also related to some KVM bugs, hard to say) ... while Ubuntu Bionic host doesn't produce those errors. Since I am unable to look more into this and since recommended host Bionic works, I can only point you to start with Bionic ...
I just finished a compile without the dts patches, that compiles OK (because the vcc_3v3 regulator definition is in imx6ql-sr-som.dtsi).
Nevertheless it is a good thing to setup a Ubuntu Bionic machine and take it from there.
Unfortunately Ubuntu Bionic does not work for me, tried in a VM and on a laptop, it throws the follwoing error while running the compile script:
./compile.sh
[ o.k. ] Using config file [ config-default.conf ]
[ warn ] This script requires root privileges, trying to use sudo
[ o.k. ] This script will try to update
remote: Counting objects: 31418, done.
remote: Compressing objects: 100% (9720/9720), done.
remote: Total 31418 (delta 21787), reused 30834 (delta 21269), pack-reused 0
Receiving objects: 100% (31418/31418), 228.85 MiB | 5.76 MiB/s, done.
Resolving deltas: 100% (21787/21787), completed with 323 local objects.
From https://github.com/armbian/build
   0a54d03e..32bf59de master     -> origin/master
 * [new tag]           s500-eol    -> s500-eol
 * [new tag]           v2015.01-rc -> v2015.01-rc
 * [new tag]           v2015.12    -> v2015.12
 * [new tag]           v2016.02    -> v2016.02
 * [new tag]           v2016.06    -> v2016.06
 * [new tag]           v2016.08    -> v2016.08
 * [new tag]           v2016.09    -> v2016.09
 * [new tag]           v2017.01-rc -> v2017.01-rc
 * [new tag]           v2017.07    -> v2017.07
 * [new tag]           v2017.11    -> v2017.11
Updating 0a54d03e..32bf59de
Fast-forward
 lib/configuration.sh | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
Already on 'master'
Your branch is up to date with 'origin/master'.
[ o.k. ] Preparing [ host ]
[ o.k. ] Build host OS release [ bionic ]
[ o.k. ] Syncing clock [ host ]
[ .... ] Downloading [ gcc-linaro-arm-linux-gnueabihf-4.8-2014.04_linux ]
-=O=-    #    #    #    #
curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to dl.uk.armbian.com:443
-=O=-   #   #    #    #
[ .... ] Verifying
grep: gcc-linaro-arm-linux-gnueabihf-4.8-2014.04_linux.tar.xz.asc: No such file or directory
md5sum: gcc-linaro-arm-linux-gnueabihf-4.8-2014.04_linux.tar.xz.asc: No such file or directory
[ warn ] Verification failed
[ .... ] Downloading [ gcc-linaro-4.9.4-2017.01-x86_64_aarch64-linux-gnu ]
-=O=-   #   #    #    #
-=O=-   #   #    #    #
[ .... ] Verifying
grep: gcc-linaro-4.9.4-2017.01-x86_64_aarch64-linux-gnu.tar.xz.asc: No such file or directory
md5sum: gcc-linaro-4.9.4-2017.01-x86_64_aarch64-linux-gnu.tar.xz.asc: No such file or directory
[ .... ] Downloading [ gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabi ]
-=O=-      #    #    #    #
-=O=-            #    #     #     #
[ .... ] Verifying
grep: gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabi.tar.xz.asc: No such file or directory
md5sum: gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabi.tar.xz.asc: No such file or directory
[ .... ] Downloading [ gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf ]
-=O=-    #    #    #    #
-=O=-              #    #     #     #
[ .... ] Verifying
grep: gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf.tar.xz.asc: No such file or directory
md5sum: gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf.tar.xz.asc: No such file or directory
[ .... ] Downloading [ gcc-linaro-5.5.0-2017.10-x86_64_aarch64-linux-gnu ]
-=O=-      #    #    #    #
-=O=-   #   #    #    #
[ .... ] Verifying
grep: gcc-linaro-5.5.0-2017.10-x86_64_aarch64-linux-gnu.tar.xz.asc: No such file or directory
md5sum: gcc-linaro-5.5.0-2017.10-x86_64_aarch64-linux-gnu.tar.xz.asc: No such file or directory
[ .... ] Downloading [ gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi ]
-=O=-    #    #    #    #
-=O=-   #   #    #    #
[ .... ] Verifying
grep: gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz.asc: No such file or directory
md5sum: gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabi.tar.xz.asc: No such file or directory
[ .... ] Downloading [ gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabihf ]
-=O=-      #    #    #    #
-=O=-    #    #    #    #
[ .... ] Verifying
grep: gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabihf.tar.xz.asc: No such file or directory
md5sum: gcc-linaro-5.5.0-2017.10-x86_64_arm-linux-gnueabihf.tar.xz.asc: No such file or directory
[ .... ] Downloading [ gcc-linaro-6.4.1-2017.11-x86_64_arm-linux-gnueabihf ]
-=O=-   #   #    #    #
-=O=-    #    #    #    #
[ .... ] Verifying
grep: gcc-linaro-6.4.1-2017.11-x86_64_arm-linux-gnueabihf.tar.xz.asc: No such file or directory
md5sum: gcc-linaro-6.4.1-2017.11-x86_64_arm-linux-gnueabihf.tar.xz.asc: No such file or directory
[ .... ] Downloading [ gcc-linaro-6.4.1-2017.11-x86_64_aarch64-linux-gnu ]
-=O=-        #    #    #     #
-=O=-      #    #    #    #
[ .... ] Verifying
grep: gcc-linaro-6.4.1-2017.11-x86_64_aarch64-linux-gnu.tar.xz.asc: No such file or directory
md5sum: gcc-linaro-6.4.1-2017.11-x86_64_aarch64-linux-gnu.tar.xz.asc: No such file or directory
[ .... ] Downloading [ gcc-linaro-7.2.1-2017.11-x86_64_aarch64-linux-gnu ]
-=O=-    #    #    #    #
-=O=-                                                           #    #  #  #
[ .... ] Verifying
grep: gcc-linaro-7.2.1-2017.11-x86_64_aarch64-linux-gnu.tar.xz.asc: No such file or directory
md5sum: gcc-linaro-7.2.1-2017.11-x86_64_aarch64-linux-gnu.tar.xz.asc: No such file or directory
[ .... ] Downloading [ gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf ]
-=O=-              #    #     #     #
-=O=- #   #    #    #
[ .... ] Verifying
grep: gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf.tar.xz.asc: No such file or directory
md5sum: gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf.tar.xz.asc: No such file or directory
[ .... ] Downloading [ gcc-linaro-7.2.1-2017.11-x86_64_arm-eabi ]
-=O=-        #    #    #     #
-=O=-    #    #    #    #
[ .... ] Verifying
grep: gcc-linaro-7.2.1-2017.11-x86_64_arm-eabi.tar.xz.asc: No such file or directory
md5sum: gcc-linaro-7.2.1-2017.11-x86_64_arm-eabi.tar.xz.asc: No such file or directory
I will have to stick to the version without the imx6dl-cubox-i.dts patches as it seems I can build a correctly working volumio image with it.
Perhaps sometime the dts issue will be resolved ;)
output.log
Try now
Thanks, that did the trick!
However, the dts problem is still there.
And it would to be, because the vcc_3v3 regulator definition IS really missing from imx6qdl-sr-som.dtsi after patching.
Just check it out when you have time.
(still worth the effort, now I have a clean Ubuntu Bionic dev environment)
What would I loose when compiling from the SR 4.9.y kernel repo directly, apart from not having the latest wifi stuff?
Btw: In general, would you have issues with us (Volumio team, mainly me) to use your kernels/ uboot for some of the boards you support with Armbian?
It is what I tried for cuboxi here, but got a little stuck because of the issues mentioned.
Those BSP kernels are usually in a pretty bad state. You can only expect more troubles and certainly less support than here. Kernel 4.14.y works well and also SPDIF, which I assume has some value in this case, while it is (was?) broken in more recent kernels.
I will try to check later today again what is causing this problem.
@IgorThanks for the fix, the kernel build script now works without any issues, much appreciated!!
A volumio version with it, main focus SPDIF, works perfectly with excellent eth0 and usb performance.
Tested it with a cubox 2iex, waiting for confirmation that i4pro also boots (expected as such, but did not work for a previous 4.15.<something>),
In that case further u-boot patching will be required. It's important to catch serial console logs in case it doesn't boot. We might fix that too.
