  On 7/24/2018 at 2:23 PM, ramawatar said:
what difference between armbian and debian Linux
Sent from my Redmi Note 4 using Tapatalk
Expand
2
I am not sure if this is what you want to know, but:
- Debian.org or Ubuntu.com officially does not support any of those boards/boxes,
- Armbian userspace has many small but vital performance or security adjustments,
- Armbian fancy some kernel development and a lot of its maintaining. Debian relies on upstream sources for ARM hardware which can be years behind and/or lack of many functions,
- Armbian userspace is lean, clean but 100% Debian (or Ubuntu) compatible
- many stock Debian bugs are fixed on the way, "better than original :)"
- a build system is a central part of this whole ecosystem. You can DIY. Debian much harder.
- dedicated support forums per boards/boxes
- plug and play vs. complicated install scenarios on Stock Debian
- unified development scenarios and user experience vs. mess of different setup instructions scattered all around
I must have forgotten many other important points :)
  • Igor changed the title to What is the difference between Armbian and Debian Linux
  • Igor pinned this topic
  • Werner unpinned this topic
  • Werner locked this topic
