Hi guys,
first of all I want to thank all of the users so far contributing to these armbian images. The images are extremely stable and my personally preffered platform for Smart Home installations.
Unfortunately started using the 1-Wire BUS I am experiencing issues with the current kernel. At least this is what syslog entries let me assume.
Everything seems fine for some hours or sometimes even days. Then suddenly (often at night) the USB Hostadapter seems to get disconnected and the system need to be rebooted completely to get 1-Wire to work again. I already searched the net a bit and found many users having those issues with several usb devices, not only 1-Wire. The syslog entries are always very similar and all deal with "ohci-platform" before usb devices stop to work.
This is my sylog from last night:
Jul 28 04:14:25 localhost kernel: [398581.169308] ohci-platform 1c14400.usb: frame counter not updating; disabled
Jul 28 04:14:25 localhost kernel: [398581.169321] ohci-platform 1c14400.usb: HC died; cleaning up
Jul 28 04:14:25 localhost kernel: [398581.169410] usb 3-1: USB disconnect, device number 2
Jul 28 04:14:26 localhost OWFS[937]: DEFAULT: ow_reconnect.c:(70) Failed to reconnect DS9490 bus master!
Jul 28 04:14:31 localhost OWFS[937]: DEFAULT: ow_reconnect.c:(70) Failed to reconnect DS9490 bus master!
Any idea how this can be fixed. Or is there a bug in armbian kernel?
Best regards,
Artur
Edited by Cleveres-Heim
Hi!
I have found additional information. There is a post in ubuntuforums.org (https://ubuntuforums.org/showthread.php?t=2342985&p=13655958#post13655958)
They are talking about "hid-quirks.c of the kernel source" and the fact, that some "usbhid devices need to be always polled to prevent a buffer overflow".
Any possibility to contribute idVendor and idProduct from the 1-Wire USB Hostadapter?
Bus 003 Device 002: ID 04fa:2490 Dallas Semiconductor DS1490F 2-in-1 Fob, 1-Wire adapter
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.00
  bDeviceClass          255 Vendor Specific Class
  bDeviceSubClass       255 Vendor Specific Subclass
  bDeviceProtocol       255 Vendor Specific Protocol
  bMaxPacketSize0         8
  idVendor           0x04fa Dallas Semiconductor
  idProduct          0x2490 DS1490F 2-in-1 Fob, 1-Wire adapter
  bcdDevice            0.02
  iManufacturer           0
  iProduct                0
  iSerial                 0
  bNumConfigurations      1
Best regards,
Artur
22 hours ago, martinayotte said:
It seems that hid-quirks.c exist in 4.14.y but not in 4.17.y !
I don't know if this could be fixed easily ...
So, as this is a known issue also with many other vendors and products, how this is solved in 4.17.x kernel versions?
How can i contribute to the list? Pull Request for Armbian kernel 4.14.x?
