I'm just trying to create a new image for the ClearFog Pro, b/c I need some special kernel modules built-in. Compiling kernel 4.4.4 with my settings works great, but I have problems to boot the image.
This is my build command:
sudo ./compile.sh BRANCH=next BOARD=armada KERNEL_ONLY=no BUILD_DESKTOP=no PROGRESS_DISPLAY=plain RELEASE=jessie
But u-boot complains about starting with the following message. Even the u-boot `help` command doesn't work.
Board configuration detected:Net:
|  port  | Interface | PHY address  |
| egiga0 |   RGMII   |     0x00     |
| egiga1 |   SGMII   |   In-Band    |
| egiga2 |   SGMII   |   In-Band    |
egiga0 [PRIME], egiga1, egiga2
Hit any key to stop autoboot:  0
Unknown command 'ext2load' - try 'help'
Unknown command 'source' - try 'help'
Unknown command 'tftpboot' - try 'help'
Unknown command 'setenv' - try 'help'
Unknown command 'bootz' - try 'help'
Marvell>>
When I'm using the latest available download image `Armbian_5.00_Armada_Debian_jessie_4.4.1.zip` then u-boot works and the image is booting well.
Same problem occurs when I'm creating the kernel and u-boot packages only and install the u-boot package within the running `Armbian_5.00_Armada_Debian_jessie_4.4.1.zip` image:
dpkg -i linux-u-boot-next-armada_5.05_armhf.deb
reboot
Any help or pointers greatly appreciated.
I'm running running Ubuntu 14.04.4 LTS 64-bit in Vagrant 1.8.1 (Virtualbox Version 5.0.14 r105127) on OS X.
Compiler: gcc version 4.8.4 (Ubuntu 4.8.4-2ubuntu1~14.04.1)
Check with different SD card ... I have to double check.
Hello, I don't want to hijack this thread but yesterday I've build two images, that did not boot. Instead the server logged some tftp requests. It was the first time I used EXTENDED_DEBOOTSTRAP="yes".
The stuff that belongs to /boot was in /boot/boot. After copying the content from /boot/boot to /boot and setting the links, the images work as expected.
Quintus23M may have the same problem, see: "Board configuration detected:Net:" in his first post.
My configuration:
BUILD_DESKTOP="no"
BOARD="bananapim2" ### 2nd board is a BPi-M1
BRANCH="next"
RELEASE="jessie"
PROGRESS_DISPLAY="plain"
PROGRESS_LOG_TO_FILE="yes"
Configuration is similar to Quintus23M: Ubuntu 14.04, Virtual Box, OS X
Server log:
tftpd[1359]: tftpd: trying to get file: AC100202.img
tftpd[1357]: tftpd: serving file from /srv/tftp
dhcpd[955]: DHCPDISCOVER from xx:yy:...
tftpd[1359]: tftpd: trying to get file: boot.scr.uimg
tftpd[1359]: tftpd: serving file from /srv/tufts
mounted image:
$: ls boot/
boot
$: ls boot/boot/
bin	  boot.scr	      script.bin	      zImage
boot.bmp  config-4.4.4-sunxi  System.map-4.4.4-sunxi
boot.cmd  dtb		      vmlinuz-4.4.4-sunxi
Thanks for the report, this will be fixed shortly
This problem only occurs when I'm using my 2014 MBP (with VirtualBox). On an Window 7 PC with VMware Workstation 10 it produces a correct U-Boot package with exactly the same Vagrantfile and provision script...
So, I do have a workaround now.
That is odd. Virtualbox has issues ... actually hard to say where the issue is. I experienced once corruption similar to this but (host too) reboot solved it.
Just checked it with using VMware Fusion 7.1.3 on my MBP, same problem as with VirtualBox 5.0.14. U-Boot binary seems to be corrupt. Maybe this Mac is quite too fast...
U-boot code is somehow fragile. We needed to patch it for first u-boot build and if you are using different / newer compiler ... you need to patch it again. I haven't dig into more. I hope it will be possible to merge upstream to latest mainline u-boot.
