I tried compiling Debian 9 Full OS Image with Desktop using BRANCH=next and default kernel configs for
* NanoPi K1
* Rock64
* OrangePi Plus 2E
And all failed at the end:
Errors were encountered while processing
 /tmp/apt-dpkg-install-LTKPXl/621-numix-icon-theme_0.3+922~201711061547~ubuntu16.04.1_all.deb
E: Sub-process /usr/bin/dpkg returned an error code (1)
[ error ] ERROR in function create_rootfs_cache [ debootstrap-ng.sh:213 ]
[ error ] Installation of Armbian packages failed
[ o.k. ] Process terminated
[ error ] ERROR in function unmount_on_exit [ image-helpers.sh:59 ]
[ error ] debootstrap-ng was interrupted
I am using the 18.04 minimal image in a virtual box. It worked a month ago. It works today for Ubuntu Full OS image with Desktop and BRANCH=next.
Thanks.
Remove cache/rootfs and try again. (i will try to recreate the problem in the mean time)
same error.
I did:
rm -fr cache/rootfs
./compile.sh CLEAN_LEVEL=make,images,alldebs,cache,sources,extras BRANCH=next
and got the same error
Thanks
Deboostrap failing at icon-theme(s) hunts me for a long time. I thought I found/fix the problem, but it looks like it was yet another random "fix". :angry: Now searching for another workaround ... at Bionic we have also gnome-icon-theme failing, which is stock desktop dependencies ...
Hi Igor.
Yes. That builds now. At least for K1. I will try on other boards tonight. I compiled, burned to uSD and booted on board. Basic stuff seems to work so far.
Thanks
