shardwick Posted August 16, 2018 Posted August 16, 2018 Hi, I've a small amount of linux knowledge... enough to be dangerous but not enough to understand fully what's going on. I'm learning slowly but have reached a frustrating failure with my A95x revision 2 set top box. It's running "ARMBIAN 5.41.1 user-built Debian GNU/Linux 9 (stretch) 4.17.0-rc3-next-20180430-amlogics905x" I have a behringer UCA202 USB soundcard - it uses standard texas instruments chipset so should just be plug and play. But there's a gap in my knowledge and in the process of getting the soundcard to detect within Armbian. lsbusb outputs.... Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 003: ID 08bb:2902 Texas Instruments PCM2902 Audio Codec Bus 001 Device 002: ID 2500:0020 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Relevant lines from dmesg are: [ 1.420548] usbcore: registered new interface driver usbfs [ 1.420620] usbcore: registered new interface driver hub [ 1.420714] usbcore: registered new device driver usb [ 1.422003] Advanced Linux Sound Architecture Driver Initialized. [ 3.034073] hub 1-0:1.0: USB hub found [ 3.037122] hub 1-0:1.0: 2 ports detected [ 3.041352] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 3.046493] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 [ 3.054088] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [ 3.060691] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 3.069177] hub 2-0:1.0: USB hub found [ 3.072406] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19) [ 3.129093] ALSA device list: [ 3.132447] No soundcards found. [ 3.375015] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 3.739136] usb 1-2: new full-speed USB device number 3 using xhci-hcd [ 3.952146] input: Burr-Brown from TI USB Audio CODEC as /devices/platform/soc/soc:usb@c9000000/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-2/1-2:1.3/0003:08BB:2902.0001/input/input0 [ 4.072254] hid-generic 0003:08BB:2902.0001: input: USB HID v1.00 Device [Burr-Brown from TI USB Audio CODEC ] on usb-xhci-hcd.0.auto-2/input3 aplay -l shows aplay: device_list:270: no soundcards found... I've done a lot of googling and tried various potential solutions none of which seem to make ALSA see the soundcard even though it seems to be detected at a USB level. I'd be extremely grateful if anyone can help guide me through this? Thanks Simon
arox Posted August 16, 2018 Posted August 16, 2018 On 8/16/2018 at 3:19 PM, shardwick said: Hi, I've a small amount of linux knowledge... enough to be dangerous but not enough to understand fully what's going on. I'm learning slowly but have reached a frustrating failure with my A95x revision 2 set top box. It's running "ARMBIAN 5.41.1 user-built Debian GNU/Linux 9 (stretch) 4.17.0-rc3-next-20180430-amlogics905x" I have a behringer UCA202 USB soundcard - it uses standard texas instruments chipset so should just be plug and play. But there's a gap in my knowledge and in the process of getting the soundcard to detect within Armbian. lsbusb outputs.... Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 003: ID 08bb:2902 Texas Instruments PCM2902 Audio Codec Bus 001 Device 002: ID 2500:0020 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Relevant lines from dmesg are: [ 1.420548] usbcore: registered new interface driver usbfs [ 1.420620] usbcore: registered new interface driver hub [ 1.420714] usbcore: registered new device driver usb [ 1.422003] Advanced Linux Sound Architecture Driver Initialized. [ 3.034073] hub 1-0:1.0: USB hub found [ 3.037122] hub 1-0:1.0: 2 ports detected [ 3.041352] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 3.046493] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 [ 3.054088] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [ 3.060691] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 3.069177] hub 2-0:1.0: USB hub found [ 3.072406] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19) [ 3.129093] ALSA device list: [ 3.132447] No soundcards found. [ 3.375015] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 3.739136] usb 1-2: new full-speed USB device number 3 using xhci-hcd [ 3.952146] input: Burr-Brown from TI USB Audio CODEC as /devices/platform/soc/soc:usb@c9000000/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-2/1-2:1.3/0003:08BB:2902.0001/input/input0 [ 4.072254] hid-generic 0003:08BB:2902.0001: input: USB HID v1.00 Device [Burr-Brown from TI USB Audio CODEC ] on usb-xhci-hcd.0.auto-2/input3 aplay -l shows aplay: device_list:270: no soundcards found... I've done a lot of googling and tried various potential solutions none of which seem to make ALSA see the soundcard even though it seems to be detected at a USB level. I'd be extremely grateful if anyone can help guide me through this? Thanks Simon Expand Can you see (lsmod) the kernel module 'snd_usb_audio'. (Try modprobe if not)
shardwick Posted August 16, 2018 Author Posted August 16, 2018 On 8/16/2018 at 8:25 PM, arox said: Can you see (lsmod) the kernel module 'snd_usb_audio'. (Try modprobe if not) Expand Thanks Arox... no snd_usb_audio listed on lsmod and when trying modprobe (assuming I did it right) modprobe: FATAL: Module snd_usb_audio not found in directory /lib/modules/4.17.0-rc3-next-20180430-amlogics905x So the n00b question is where and how do I get the module I'll do some further research and learning about modules in the meantime. Thanks all!
arox Posted August 16, 2018 Posted August 16, 2018 Try : zcat /proc/config.gz | grep -i USB_AUDIO If you dont see CONFIG_SND_USB_AUDIO=m then I think you may need to recompile the kernel ...
shardwick Posted August 16, 2018 Author Posted August 16, 2018 zcat /proc/config.gz | grep -i USB_AUDIO gives... # CONFIG_SND_USB_AUDIO is not set
arox Posted August 16, 2018 Posted August 16, 2018 Maybe @igor could have a look because I think no external usb sound card can run ?
Igor Posted August 16, 2018 Posted August 16, 2018 On 8/16/2018 at 9:25 PM, arox said: Maybe @igor could have a look because I think no external usb sound card can run ? Expand Not build from the official tree. In any case, it goes this way -> edit configuration, config/kernel/this-kerne.conf and submit a PR https://docs.armbian.com/Process_Contribute/
shardwick Posted August 20, 2018 Author Posted August 20, 2018 This all looks very complex and I'm out of my depth with pull requests! Is there an earlier version of the kernel that supports USB soundcards? Could I download that and change kernel without affecting the work I've already done on my a95x? If so, are there any step by step guides anywhere? Thanks Simon
Igor Posted August 20, 2018 Posted August 20, 2018 On 8/16/2018 at 3:19 PM, shardwick said: ARMBIAN 5.41.1 user-built Debian GNU/Linux 9 (stretch) 4.17.0-rc3-next-20180430-amlogics905x Expand This means somebody made an Armbian image by using our tools. That's all I know.
