Hi all,
My Armbian hangs (freeze) after 1-2 hours. Below dmesg
Aug 17 19:10:39 localhost kernel: [ 1666.194984] WARNING: CPU: 0 PID: 693 at lib/iov_iter.c:695 copy_page_to_iter+0x21d/0x35c
Aug 17 19:10:39 localhost kernel: [ 1666.194987] Modules linked in: tun xt_nat xt_tcpudp iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack iptable_filter snd_soc_hdmi_codec rc_cec dw_hdmi_i2s_audio dw_hdmi_cec evdev sun8i_dw_hdmi dw_hdmi cec ir_lirc_codec lirc_dev pl2303 usbserial sun4i_i2s sunxi_cir sun8i_codec_analog sun4i_gpadc_iio sun4i_codec sun4i_tcon sun8i_mixer snd_soc_simple_card snd_soc_simple_card_utils snd_soc_core snd_pcm_dmaengine snd_pcm snd_timer snd soundcore sun4i_drm uio_pdrv_genirq uio 8189fs cfg80211 rfkill ip_tables x_tables pwrseq_simple sy8106a_regulator uas realtek
Aug 17 19:10:39 localhost kernel: [ 1666.195093] CPU: 0 PID: 693 Comm: nfsd Not tainted 4.14.18-sunxi #24
Aug 17 19:10:39 localhost kernel: [ 1666.195095] Hardware name: Allwinner sun8i Family
Aug 17 19:10:39 localhost kernel: [ 1666.195117] [<c010db15>] (unwind_backtrace) from [<c010a0d9>] (show_stack+0x11/0x14)
Aug 17 19:10:39 localhost kernel: [ 1666.195128] [<c010a0d9>] (show_stack) from [<c0868f69>] (dump_stack+0x69/0x78)
Aug 17 19:10:39 localhost kernel: [ 1666.195139] [<c0868f69>] (dump_stack) from [<c011a233>] (__warn+0xaf/0xc0)
Aug 17 19:10:39 localhost kernel: [ 1666.195148] [<c011a233>] (__warn) from [<c011a2f5>] (warn_slowpath_null+0x19/0x1c)
Aug 17 19:10:39 localhost kernel: [ 1666.195156] [<c011a2f5>] (warn_slowpath_null) from [<c0565759>] (copy_page_to_iter+0x21d/0x35c)
Aug 17 19:10:39 localhost kernel: [ 1666.195170] [<c0565759>] (copy_page_to_iter) from [<c01d8543>] (generic_file_read_iter+0x303/0x740)
Aug 17 19:10:39 localhost kernel: [ 1666.195183] [<c01d8543>] (generic_file_read_iter) from [<c024e2ab>] (generic_file_splice_read+0x83/0xd8)
Aug 17 19:10:39 localhost kernel: [ 1666.195193] [<c024e2ab>] (generic_file_splice_read) from [<c024e68d>] (splice_direct_to_actor+0x89/0x17c)
Aug 17 19:10:39 localhost kernel: [ 1666.195203] [<c024e68d>] (splice_direct_to_actor) from [<c03271e9>] (nfsd_splice_read+0x59/0x74)
Aug 17 19:10:39 localhost kernel: [ 1666.195212] [<c03271e9>] (nfsd_splice_read) from [<c0327671>] (nfsd_read+0x22d/0x234)
Aug 17 19:10:39 localhost kernel: [ 1666.195222] [<c0327671>] (nfsd_read) from [<c0325825>] (nfsd_proc_read+0x81/0xe8)
Aug 17 19:10:39 localhost kernel: [ 1666.195231] [<c0325825>] (nfsd_proc_read) from [<c032424b>] (nfsd_dispatch+0x83/0x114)
Aug 17 19:10:39 localhost kernel: [ 1666.195243] [<c032424b>] (nfsd_dispatch) from [<c084f66b>] (svc_process_common+0x29f/0x440)
Aug 17 19:10:39 localhost kernel: [ 1666.195252] [<c084f66b>] (svc_process_common) from [<c084f8df>] (svc_process+0xd3/0x138)
Aug 17 19:10:39 localhost kernel: [ 1666.195259] [<c084f8df>] (svc_process) from [<c0323e55>] (nfsd+0xad/0xfc)
Aug 17 19:10:39 localhost kernel: [ 1666.195271] [<c0323e55>] (nfsd) from [<c0131a91>] (kthread+0xfd/0x104)
Aug 17 19:10:39 localhost kernel: [ 1666.195282] [<c0131a91>] (kthread) from [<c0106719>] (ret_from_fork+0x11/0x38)
Aug 17 19:10:39 localhost kernel: [ 1666.195286] ---[ end trace 8b890c497145bf7b ]---
11 hours ago, Fazik83 said:
My Armbian
On which hardware, how it is powered, did you try recommendation for such cases?
Orange Pi Plus 2E
Linux orangepiplus2e 4.14.18-sunxi #24 SMP Fri Feb 9 16:24:32 CET 2018 armv7l GNU/Linux
I didn't try any recommendation. Could you send me link?
EDIT.
Today morning I try to log in Armbian via Putty and I can't. When I insert password, terminal do nothing. I can't log in via SSH and probably here is fault. Could someone help me?
8 minutes ago, Fazik83 said:
You didn't help me
I did. Googlefu consulting is not part of this help. If you are unable to use a search engine or invest your own 10 minutes to browse for results, there is nothing more I am willing to do for you. One more hint: A10, A20 and H3 uses the same kernel and might share some problems.
I didn't know.
I spend a lot of time to configure my Armbian and I know google and You didn't have to teach me in this topic.
And I fresh Armbian freeze after 1-2 hours, then... something wrong in image. Why image is still on upload? If is fix, why fix is not pinned? Att Debian_stretch_next.7z dated 27.01.2018.
If this happens only to you, this is your problem. Since I saw some others complaining about similar issues it is possible that the problem is not yours. If you are not able to find them on a forum and attach your complains there, the problem is still only yours and thus not worth any attention.
I am also frustrated that I need to point out/teach you things which should be obvious.
Spent 10 minutes on search. You will be amazed at what can be found.
