Jens Bauer Posted August 19, 2018 Posted August 19, 2018 I've been seeding torrents on my CubieBoard2 earlier; in Juli I moved to one of my EspressoBIN boards. I allocated 128GB for the torrents (since it was stated that I needed at least 60GB for Armbian). -But now Armbian seem to take up 123GB on my dedicated transmission partition: $ df -h . Filesystem Size Used Avail Use% Mounted on /dev/sdc13 128G 123G 4.5G 97% /transmission It seems I have 388 completed Armbian files (and no other files). -Does this mean that something went out of control - like files not being deleted - or does it mean that the torrents use this much space now ?
Igor Posted August 19, 2018 Posted August 19, 2018 3 hours ago, Jens Bauer said: Does this mean that something went out of control - like files not being deleted - or does it mean that the torrents use this much space now ? It should be 378. It's some time since 60GB was set Everything is fine. Many new boards and Bionic as a test option on some ... with some cleaning and with some additional logic, this could be brought down. But its some work. 1
Jens Bauer Posted August 19, 2018 Author Posted August 19, 2018 34 minutes ago, Igor said: It should be 378. It's some time since 60GB was set Everything is fine. Many new boards and Bionic as a test option on some ... with some cleaning and with some additional logic, this could be brought down. But its some work. Alright- 378 ... That means I have 10 files more than I should have. I'll add an additional drive, the next time I get over to my server; it's more important that you spend time making more images available than keeping the number of files down; worst case would be that I transfer the files to my local Espressobin and let it handle it until I get more space. Perhaps I'll need to make a split disk-image in order to solve the problem that the partition will soon be full. (By making a split disk-image, I mean spreading disk images over several partition and setting them up in RAID0; this works fine and can be mounted in fstab too. It's also possible to mix images with real partitions).
Igor Posted August 28, 2018 Posted August 28, 2018 On 8/19/2018 at 5:44 PM, Jens Bauer said: I'll add an additional drive, the next time I get over to my server; No need. I did some cleanup and we are back down to 210 files or 63G. It was a part of a preparation for the next major update. 1
Jens Bauer Posted August 30, 2018 Author Posted August 30, 2018 On 8/28/2018 at 4:12 PM, Igor said: No need. I did some cleanup and we are back down to 210 files or 63G. It was a part of a preparation for the next major update. Thank you, sir! :) I've cleaned my drive, so I now have a clean download of the files. I'll check now and then if files get deleted or if the usage grows, because I sense something might have gone wrong with file-deletion. While I remember ... I've set up transmission to have a 'completion directory' which is different from the 'in-progress' directory. Would this cause any problems ?
Igor Posted August 30, 2018 Posted August 30, 2018 3 hours ago, Jens Bauer said: I've cleaned my drive, so I now have a clean download of the files. If you are using our cronjob script, it should remove unneeded files automatically. 3 hours ago, Jens Bauer said: I've set up transmission to have a 'completion directory' which is different from the 'in-progress' directory. I don't think so.
Jens Bauer Posted September 2, 2018 Author Posted September 2, 2018 On 8/30/2018 at 7:38 AM, Igor said: If you are using our cronjob script, it should remove unneeded files automatically. OK, I'll probably make a simple systemd service that logs disk-space or something and send me an email if a high-watermark is reached. :)
